After connecting my pen drive to my laptop , system is asking to format my pen drive. I have data in it. So, I cannot format it. I would like retrive my data before i go to formatting my pen drive. Any help would be appreciable.
Try it on another usb port..or If the windows can't format try formatting it from the command prompt if it's not working than must be pendrive.. i think there's no problem with other pendrives.. or the one that you have
Hi, Try to format it using the method describe below: May be it will help Go Start>Setting>Control Panel> Or Start>Control Panel> Then open> Administrative Tools>Computer Management> Then select In the left Column Click disk management Then locate your pen drive and try to format with fat file system Also you can try to remove the partition and create new one ok... Regards Uttam
(WARNING: After running this low level format tool, the whole USB flash disk surface will be fully erased. Therefore, data restoration will be impossible after using this utility!)
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
do you still have warranty for the Pen drive, suggest you take it to the shop you bought it. you seem to have got a defective ped drive. also if you have the serial numbers, check online with Kingston to see if you have got a genuine kingston product.
I Have Cruzer micro (8Gb) pen drive When i Insert pendrive And open Show
message (Pls Insert Disk) When I try to format Pen drive Show message
(There is no disk in drive G) G Drive Right click And go properties Show
0byets Pls solve the problem Regards, Prashant
opening pen drive, it shows 'please insert the disk' & it shows 0 bytes & while trying to format it shows the same message again , i am using 2 gb pendrive of trancend.
