Question about Samsung HL-S4266W 42" HDTV
I am hitting the power button on the tv but it won't turn on
I hit the power button on the tv and it will not turn on - the standy red letters are lit
    Problem Solver:
  • 24 Answers
NEED NEW LAMP
Posted on Sep 03, 2007
SOURCE:
Sylvania plasma tv will not turn on
power supply board has defective components,check for swollen capacitors and replace them,if problems still not solve email me at [email protected] .for further instructions
Aug 14, 2014 | Sylvania 6842THG 42 in. Plasma HDTV
I have a Panasonic HDTV 1080p and it won't turn
You have a 5 year old projection TV with power supply trouble
Jul 13, 2013 | Televison & Video
My remote won't change from AUX to Tv and all of the buttons don't work on AUX except for the volume and mute, how do I get it back on tv? Thank you
Try to push the TV button that is lit red at top middle of remote for 5 seconds in stead of hitting input. In other words by holding the tv button down it might trigger it to respond better. Thanks Mike
Apr 07, 2013 | Televison & Video
Missing code for comcast remote to work new rca tv
Hit tv then hold the setup button untill in flashes....then you type in 991 and then hit tv power tv power.... untill your tv turns off when it dose hit setup to lock the code
Jun 11, 2009 | RCA L32HD31 32 in. LCD HDTV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
My tv is turn to red light when i hit the power button
Some circuit in secondary power has a leak or shorted parts need to replace it. thats why your tv comeback to red ligth signal. need a technician.
Jun 08, 2008 | Sharp 20K-S100 20" TV
Power LED on but no boot up
it could be your power switch, veriy that it isnt the power supply by
1.) un-plug it from the main board
2.) look at the main board connector(one coming of the power supply)
3.) you should see green wire and next to it a black one
4.) using a paper clip bridge the too wires
5.) if it works proceed to net step if not get a new power supply
to check case switch and board switch
1.) plug in power supply to main board
2.) look at the pins where the power button connects to
3.) using a metal object (blade screw driver) bridge the pins
if the board should start up>
then its your power button on the case that is bad, you can try to repair it, chage it or buy a new case,
if it doesnt work.
1.) ensure that jcms(jumper to flash the bios) is set correctly
2.) unjack each drive one at a time to see if any is causing stalling
3.) get a new main board
Jan 02, 2008 | EliteGroup L7VMM2 Motherboard
Need codes for the RC450 remote
took me awhile but I figured it out
ok
Put your TV/DVD/VCR on
hold in what you want to program TV/DVD/VCR BUTTON
(you dont need codes or anything)
then while holding in what you want to program (TV, DVD, VCR) hold in ON/OFF
both at the same time
when the light comes on and stays on
keep hitting ON/OFF BUTTON
do it slow, when the TV turns off hit the STOP button at the bottom
then hit the button you just programed
then hit the ON/OFF button, the TV/DVD/VCR will turn on
if it doesnt work, repeat. make sure you hit the stop button when the TV/DVD/VCR shuts off, if you hit it an extra time while the TV/DVD/VCR is off it wont work.
took me about 30 mins to figure it out.
I lost my codes too, but I wanted to help all you other people too.. now since I helped you.. check my band out... www.myspace.com/jumpercablenj
Nov 13, 2007 | RCA RCR450 Remote Control
Its the Mother Board..I had the same problem and had to have a new MB put in
Feb 17, 2007 | Gateway (4000811) Motherboard
Samsung HL-S4266W 42" HDTV Logo
108 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
