Question about HP Pavilion a340n (DQ099AABA) PC Desktop
Internet ISP tech support says that my internet card is bad. Can this be easily replaced??
    President:
  • 317 Answers
Yes it's pretty easy, did you get struck by lightning? It could be bad, but I've known a lot of ISP technicians to say you have a bad card, because they don't want to work on their lines. The good thing is they're pretty cheap. Usually around $20. Just look for a PCI Network Interface Card (NIC). I recommend Linksys, I've always had good luck with them. All you do is open the side panel of your pc, and there should be one screw you take out, slide out the old card, then snap in the new card and put the screw back in. When you start the computer it SHOULD detect and download the drivers for the new card. If not, you'll have to run the cd that came with it.
Posted on Sep 03, 2007
SOURCE:
My internet goes in and out and says i have limited access
Check ALL cables/splitters/connections and reseat. Contact your ISP have them verify the signal. Have a ISP tech come out to analize the signal. It may be outside ISP equipment. It's happened to me on occasion.
Jan 23, 2013 | Microsoft Internet Explorer 7
Router wont give out internet
If you have Checked ALL cables and rebooted both, ISP modem and router, contact the ISP and have the signal analyzed, have a ISP tech come out and verify the signal. It may be a outside equipment issue.
Jan 16, 2013 | Computers & Internet
I cant get internet from my rouder
Wired or wireless? Shut down the computer. Unplug the NetGear. Unplug the ISP modem, remove battery, if applicable, Check ALL cables and connections, reseat ALL connections. plug in the ISP modem, wait for selftest. Plug in the NetGear, wait for selftest. Reboot the computer. Try connecting with a Ethernet cable if you are trying to connect wirelessly to verify. If that fails, contact your ISP to verify signal comming in. Have a ISP tech come out to analyze the signal.
Jan 06, 2013 | NetGear Computers & Internet
I have a surfboard modem cable motorola, and isnt working the internet, i had already put the power off during 30 seconds..
Check ALL cables, splitters, reseat ALL connections. unplug the device, remove the battery, replace battery, plug in , allow it to selftest. reboot computer. If that fails contact your ISP to verify the signal to modem, have a ISP tech come out to analyze the signal.
Jan 04, 2013 | Computers & Internet
My modem can not detect my lan card, i am using presario v3000, what maybe problem?
Greetings - I think you're not clear about how using the Internet works (not many people are - especially starting out).
The modem and the LAN card are TWO DIFFERENT ways of connecting to the Internet. The modem uses a regular phone line and the LAN card uses Ethernet (a different faster way of connecting to the Internet in which needs further hardware such as a cable or DSL modem from your ISP).
Or is it possible you're talking about connecting your LAN card to your cable or DSL modem?
If this is confusing to you please call the tech support of your Internet service provider and they should be able to walk you through getting connected..
Good Luck and Thanks for using Fix Ya.
Mikeywaf
Apr 17, 2011 | Computers & Internet
To stop bad packets from LAN internet using in DELL Inspiron
Scan your computer using a good antispyware. My preference would be Eset. Also check your firewall and check for any suspicious activity using netstat command from command line. You can also configure IPSec policy in your computer. You will find good stuff in internet.
You can try this one :
http://www.tech-faq.com/configuring-and-managing-ipsec.shtml
http://www.petri.co.il/configuring_ipsec_policies_through_gpo.htm
http://www.securityfocus.com/infocus/1519
Nov 20, 2009 | Dell Inspiron 1501 Notebook
How do i turn on my wireless capability?
Are you trying to turn on wireless in a laptop, PC or the modem itself?
Modems have a specific IP address that you can get from tech support of your internet vendor.
Laptops if WIFI onboard should simply have it.
Laptops with WIFI cards need drivers and sometimes software.
PC's with WIFI card or USB WIFI often need software etc.
Once working you then need a WPA or WPE login and password to access the internet. If at home you should have that information or call your ISP.
Oct 19, 2009 | Acer Aspire 5050-3242 Notebook
Y have problem whit the internet it to slow
dude that is in terms if your ISP.
but before you call your isp try to do this:
Scan for viruses ( but first update the antivirus software you use to the most updated virsion )
CMD codes ( Cant connect to Internet )
1. Go to command prompt
2. Type-in Ping 127.0.0.1 = Lan Card address
3. Get the value of the pockets Sent, Recieved and Lost.
4. If the value is ( Sent = 4, Recieved = 4 and Lost = 0% ) Then the lan card and wireless card is working fine and the problem is with the ISP = Contact ISP
OR
No Connection using router
2. Type in ping 192.168.0.1 or which ever the address of your router.
4. If the value is ( Sent = 4, Recieved = 4 and Lost = 0% ) Then the lan card and wireless card is working fine and the problem is within the Router configuration. = Advice the CX to Contact the Router manufacturer or ISP
Aug 21, 2009 | Acer Aspire One PC Notebook
Linksys wireless connected to router, signal fine, no web pages
First thing i would try is power cycling your equipment. Unplug the router and the Modem-
Plug the modem in first and once all the lights come on- plug in your router- then restart your computer.
Apr 09, 2009 | Linksys Wireless-G WRT54G Router
No internet to the computer
If you already created a new connection and went through that process, just simply call your ISP they will easily solve the network issue for you.
Feb 11, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
HP Pavilion a340n (DQ099AABA) PC Desktop Logo
46 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
