A device does not have to be registered for a warranty. The latter is good for stated period after date of purchase - that is why you keep a receipt. If not under warranty and you cannot print out a test pattern after cleaning, the head is fubar and will need replacement at considerable expense compared to the cost of a new printer. Your choice.
SOURCE: error code 1203
To determine whether this error is due to a cartridge failure or a hardware problem with the printer, do the following: Make sure the printer is powered on. Open the printer's top cover. The print cartridge carrier moves and stops at the loading position. Press down on the cartridge lever to raise the cartridge lid. Remove the cartridges. With the cartridges out of the printer, close the top cover. Power the printer OFF and then back ON. Check the operator panel to see if the 1203 error has returned or if a new message is displayed. If the message displayed is 1203, there is something wrong with the printer hardware. Please contact Lexmark Technical Support. If the message is Cartridge Missing, reinstall the cartridges into the printer. Insert the black cartridge in the left carrier. Insert the color cartridge in the right carrier. Snap the lids closed. Close the top cover. Check the operator panel. If the 1203 message is still present, you need to insert one cartridge at a time to determine which cartridge is producing the failure. With one cartridge in the carrier, close the top cover and check the operator panel. If the 1203 message is displayed, that cartridge is producing the error. If Cartridge Missing is displayed, the second cartridge is the defective item. Please replace the defective cartridge.
SOURCE: I have a Lexmark 7170--it
Here's the complete rundown on the error. It offers some solutions to try as well...
http://support.lexmark.com/perl/support/support.cgi
SOURCE: I have a lexmark prospect
Updating the firmware for your Lexmark Pro200 series will help fix this problem. You will need to get rid of the error first before you can successfully update your printer. Follow these steps:
1. Open the cover of the printer > Remove the printhead. If the printhead will not go to the center, turn off the printer and pull the printhead to the center.
2. Once you have the printhead removed, close the cover of the printer and turn on the printer.
3. It will ask you to "Open Cover to Install the Printhead". Press the Cancel (Red X) button.
4. It should take you back to the "Copy" menu.
5. Proceed with the firmware update. Just go to http://bit.ly/p205fw. There'll be more than one download for your model, try the top download first.
6. Once the firmware update is successful, reinsert the printhead by following the steps on your printer screen.
Source: There is a Problem with the Printhead
SOURCE: the control panel on my lexmark all-in-one
wlutter... thanks a tonne man... i have a S600 lexmark.. and it was stuck too..
the pushing of the 3 riidges under the printer control panel solved it
SOURCE: How can I obtain a User's Guide for a Lexmark X6650 all in one printer?
You can download the Lexmark user manual and printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://support.lexmark.com/index?page=home&locale=EN&userlocale=EN_US&segment=DOWNLOAD
After successfully updating your printer, run the Deep Clean Printhead function on your printer.Press the Setup button > Maintenance > Deep Clean Printhead.
If you're still having problem, please scan and email us a test page (Setup button > Maintenance > Print Test Page) to [email protected].
However, if your device is displaying a 'printhead error' on the
hardware and/or you are suddenly experiencing a print quality issue, please
contact the Lexmark Technical Support Center at 1-800-539-6275.
Lexmark agents are prepared and able to help diagnose and resolve your issue. This may involve updating your printer firmware and/or replacing the printhead for your printer, at no charge to you, our customer. Installation is quick and easy for any customer to perform.
