Question about Gevalia 35411 / 50433 Coffee Maker
CM500 My lower heating element is out...can you ship me a new one...I know how to install it.
  • Anonymous Aug 19, 2008
    Mine burned out too after only 1 yr. of use. To me this is not acceptable and there should be some sort of element available for these machines.
    I have checked the switch and voltage with a Volt meter, checked resistance as well. The element shows an open circuit in it.
  • 625 Answers
I checked the gevalia site and they said your type of coffee machine has been discontinued as well as the company does not stock parts anymore. sorry
Posted on Sep 10, 2007
SOURCE:
Why is my oven not heating properly? After a loud POP! and a tripped circuit breaker, the oven does not heat properly. I suspect the lower heating element is not functioning although the top element
Does your lower element light up when it is heating? If not, time for a new element which is really easy to install - you pull it straight out and then install a new one. With the make and model number you should be able to easily fine the right element online.
Jan 09, 2018 | Kitchen Ranges
Oven won't heat, all burners work
I suggest that you remove the upper and lower heating elements to the oven, turn the oven switch to on, then use a good digital voltmeter, and check the plug that the lower heating element was in. If you have good (200 volts or more) then purchase and install new heating elements. Turn the oven switch to Broil setting and check the same way for the top heating element.
May 09, 2011 | Maytag Kitchen Ranges
How do you replace the heater coil on this unit
First of all you did not even begin to mention a model number. They are not all the same. Having said that the concept of changing a heating element is pretty much the same for those with through the lower tub mounts.
1. Turn off all power to the unit
2. Open the lower kick panel
(It is usually in 2 pieces) The top piece being fixed and the lower piece being adjustable to the floor. Remove BOTH panels.
3. Locate the 2 heating element terminals that pass through the bottom of the tub and disconnect the wires.
4. Losen the retaining nuts on the heating element. Push up on the elment to make sure it is free before totally removing the nuts.
5. Remove the nuts and then lift out the old element by opening the door and lifting out the element.
6. Note the position of seals and washers on the OLD element
7, Assemble the new element with the tub side seals and washers. Leave the under side washers off until after you place the new element in the dishwasher.
8. Install the underside seal and washer then install the nuts loosely.
9. Check the position of the element inside the tub. (Align as necessary)
10. Tighten the heating element retaining nuts on the under side of the tub. (DO NOT over tighten as you can damage the element.)
11. Install the 2 heating element terminals makeing very sure the connections are TIGHT. A loose connection will cause the new element to fail prematurely.
12. Connect power and test for leaks.
13 Leak test complete install both lower kick panels.
Task Complete!
Thanks for choosing FixYa,
Kelly
Oct 04, 2010 | Kenmore Dishwashers
How do i change the heating element.
The heating element is accessible through the lower front access panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Remove the two screws attaching the bottom of the lower front access panel to the cabinet then slide the panel down then off the cabinet. The heating element can now be accessed and repalced.
Remove the screws securing the heating element to the heater box then pull down the heating element to remove it from the heater box.
Disconnect and label the wires for the heating element and the components. Remove the components from the old heating element then transfer it to the new heating element.
Slide the new heating element up into the heater box and secure it in place. Align the slots on the top of the lower front access panel with the locating tabs on the front access panel then slide it into position and secure the bottom of the lower front access panel to the cabinet.
Apr 13, 2010 | Amana DLE330RAW Electric Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Heat element shorted out saw arching from element itself
An Easy Task.  Unplug stove. Remove old element by disconnecting the wires. Purchase new element and install. Plug stove back in.
Dec 20, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
My 7 year old Malber WD 1000 won't dry - Where to order heating element?
pete5runner back again: The check you should make is to disconnect the two wires to the heating element carefully (with unit unplugged). Then connect a 110 voltmeter to the two wires. The plug in the machine and start a dry cycle. If you see 110 volts on the voltmeter, then you know that power is getting to the heating element, and you have isolated the heating element as defective. If you need a heating element, I got one in NY by calling 718-767-7396. New element was $29, shipping included. I don't know if he will ship to where you are located. Good luck, and let me know what happens.
Mar 10, 2008 | Malber WD1000 Front Load Washer/Dryer
Heating elements
The upper element for AS690 is part# 512623
Thw lower element for AS690 is Part# 512624
Available at www.nelsonappliance.com/Toaster+Oven+Parts.html
or
http://abtecparts.com/delonghi_toaster_oven_elements.htm
Jan 03, 2008 | DeLonghi AS690 Airstream Stainless Steel...
Gevalia 35411 / 50433 Coffee Maker Logo
213 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Marvin
Marvin
ka4iup
ka4iup
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
