Screen flickers on / off when run through receiver
I have an Onkyo TX-SR605 that I just purchased and have connected it to my Panasonic plasma TV. When I'm watching standard TV (cable box connected to the receiver via HDMI input and the TV is connected to the receiver via HDMI output)the picture looks normal but then it will black out for a second or two and then come back on ....be fine for a 10 seconds or so and then black out again for a few seconds. Then sometimes it will fade in and out fairly quickly. But when I play a DVD it doesn't flicker. Both HDMI cables worked fine prior to the install...maybe they crapped out that's all I can think of....and advice
  • 1 more comment
  • vstanfor Sep 25, 2007
    Thanks for the input. I forgot to update the solution. Turns out the cable box HDMI port decided to crap out during the installation process. I took the cable box back to Time Warner and got a new one. Everything works fine.
  • Dre Day Nov 04, 2007
    Both Motorola Cable Box and Oppo DVD flicker when hooked up (HDMI) thru Yamaha RX-V2700. No problem when hooked (HDMI) directly to Panasonic Plasma.
    Any solution to this problem ? I see lot of post for this problem on the web.
  • subb Feb 09, 2008
    i have cable vision and i restarted the cable box. It works fine now. This started happening after we had a power outage. A restart of the cable box fixed the problem
Just restart the cable box this will fix the problem. My problem started after a power outage and it was fixed by rebooting the cablebox
Posted on Feb 09, 2008
Many people say that the problem lies with the cable box and that many receivers switching capabilities are too advanced for the cable box.. try hooking the cable box straight to the tv via hdmi cable. although if you want surround sound you will have to use additional audio cable to you receiver and do the swithing manually
Posted on Dec 17, 2007
No solution, but I have the same problem with my Panasonic plamsa TH-50PE700U with a Yamaha RX-V2700 receiver. I don't think the cables are a problem. If I turn the TV on and off about 20 times the system stabilizes until I turn it off.
Posted on Sep 25, 2007
2 Suggested Answers
  • 155 Answers
SOURCE: unable to connect a blu ray dvd player to onkyo
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Posted on Apr 13, 2011
Tip
Onkyo TX-SR605 Manual Download
Download Onkyo TX-SR605 Manual
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
________________________________________________
RC-682M Remote Code List & Programming Guide Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Tip
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR605 Receiver
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
I want to control my Sony Bravia KDL-46VE5 TV with my Onkyo TX-SR605 remote controller. I cannot find the Bravia remote control code.
Sony TV codes for the Onkyo TX-SR605 are : 0000, 0650, 1100, 1167, 1300, 1505, & 1651.
Instructions for the Onkyo RC682M and more remote codes are available here. The Onkyo TX-SR605 manual is available here.
I hope that helps.
Dec 27, 2009 | Onkyo TX-SR605 Receiver
Tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
I hope that helps.
Download Onkyo TX-SR605 Users Manual Here.
Tip
I hope that helps.
Audio cuts of during graphics, Onkyo TX-SR706
I have a TX-SR505 and the same thing has been happening on mine since I bought it. I am also hooked up to a Panasonic Plasma, using the optical cable to the receiver. It's been perplexing me. I have noticed it typically during commercials, not during normal programming. If I turn up the volume on the Panasonic TV, I can hear the audio, so I know it's not a problem with the over the air signal. It must be something wrong with the reciever. Would love a fix to this!
Oct 06, 2009 | Onkyo TX-SR605 Receiver
1080P video via HDMI generates awful interference
Your Plasma's native resolution is 720P. Go into the Blu Ray's output setup. you can choose 480p 480i 720p 1080i and 1080p. Set it for 720p that should clear up the issue.You may have to run Component directly to the TV since you only have 1 HDMI input and you can run Digital coax or optical to your AV receiver for audio. On a 50" TV the difference between 720p and 1080p using "GOOD" cables cannot be seen by the human eye. Above 50, yes it is noticeable.
Hope this helps.
May 22, 2009 | Onkyo TX-SR705 Receiver
Cable connection to Onkyo TX-SR605 7.1
You will have to connect your coax to the tv coax input.You can view cable this way.To use the hdmi input to tv,you will have to change your input settings back and forth on the tv menu from hdmi to rf input.There is no way to hook your cable to the txsr.
Oct 22, 2007 | Onkyo TX-SR604 Receiver
1,186 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
