Question about Motorola Mobility i860 Cellular Phone
Direct Connect option
Out of nowhere the DC ability just ceased, one day it was working the next day it wasn't. There doesn't seem to be any physical damage to the button itself as I never dropped the phone. It's not sticking, I even compared the feel of the button with my girls i870 and they feel the same. All other features work fine, cellular works and I can receive alerts, but cannot respond. Can you help?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 9 Answers
Take it to service center, they should be able to fix it for you within 15 minutes. Or you can purchase back housing from Motorola and fix it your self.
Posted on Nov 17, 2008
SOURCE:
How do i connect my fitbit device to my verizon tablet.
Syncing Your Data
  • The Tracker will upload your data every 15 minutes provided you are within range of any plugged in base station (about 15 feet for direct line of sight), the computer is on and not in sleep or hibernate mode, the software is installed and running, and you have an active internet connection.
  • While out of range, the Tracker will look for a base station every minute until it syncs your data, after which it will wait 15 minutes before searching again.
  • You can see when the last successful sync occurred by viewing your main page at www.fitbit.com. Near your profile picture, you will see Synced with a time and date of your last sync.
  • If you want to force the Tracker to upload its data, place the Tracker on the base station.
  • While we recommend you sync your data regularly, the Tracker has the ability to store 7 days' worth of detailed, minute by minute data. It will store summary data (calories, distance, and steps) for the trailing 30 days. If you wait longer than 7 days before syncing, you will not see your minute by minute graphs (except on the most recent 7 days).
  • Your Tracker is able to sync from multiple computers, as long as each computer has the Fitbit software installed and a working base station is plugged in. You don't need to physically connect the devices. Simply down load the app and upload your info.
Sep 17, 2014 | Fitbit Ultra Tracker
Do I need special physical ability to participate in archery?
Generally, you don't need any special physical abilities or natural talents to participate in archery. Anyone can quickly become proficient to a level of being competitive at an entry level.
Aug 26, 2012 | Betsey Johnson Archery
99 mercury cougar replaced power window motor and switch window still does not work
That doesn't seem possible does it ?
You remove the inner door panel
You think the motor may be bad,so you unplug it,
knowing it is a DC Motor & can be hooked up either
way & will run in either direction
You put 12 volts to it. Doesn't work ,sounds bad,you
install a new one
Now you need power from the switch to run the new motor,
so you work on that
The switch can be disconnected & tested with an OHM Meter
& if worn,you replace that
You checked the fuse before you started & knew that wasn't an issue,
because all the other windows worked
So what did you mis ,short of having no wiring diagram, to make
things a lot easier?
Aug 04, 2011 | 1999 Mercury Cougar
I stored my lawnmower on an angle all winter. Yesterday when I tried to start it oil came out of the exhaust. Today it started with alot of blue smoke, of course. what's my next step?
Just make sure the oil level in the crank case is OK, then just run it. The smoke will burn off once the muffler heats up, but it may take a while. The smoke is annoying, and not all so environmentally friendly, but it won't do the mower any harm. Just because the oil leaked into where it wasn't supposed to be, it doesn't mean that you have increased the ability for oil to leak that way. Good luck, Al K
May 19, 2011 | Briggs & Stratton Briggs Stratton...
Will not duplex - fails duplex quick test
Hello.
Here are some suggestions from Lexmark as to why the printer will not duplex:
The ability to select duplex printing requires the following:
  • -The printer must recognize the physical duplex option.
  • -The duplex option must be recognized by the driver under Properties > Install Options.
  • -The selected Paper Type must not be:
    -Transparency
    -Labels
    , or
    -Cardstock/Extra Heavy Paper.
  • -Under Page Layout > More Page Layout Options, the following options must not be selected:
    -Booklet printing
    Poster printing
Printer recognition of duplex option Some printers and MFPs have the duplex option built into the physical printer while others require physical connection of the duplex option or tray.
To check for an installed duplex option:
Print a Menu Settings page and check for DUPLEX under Device Information > Installed Features. (The embedded web server path is Reports > Device Settings > Device Information > Installed Features.)
If DUPLEX does not appear as an installed option, consider the following possible reasons: -The duplex drawer or tray is not properly connected to the printer. Try reseating the printer onto the duplex option so that the duplex option's upper auto-connect connector is properly aligned with the printer's bottom auto-connect connector. NOTE: A "982 duplex error" may also result from this condition.
-Turn the printer off for about 15 seconds, and then turn the printer back on. If the printer was quickly turned off and on, a low-voltage power condition could prevent the peripheral from being acknowledged during the initial printer start-up.
-The auto-connect connector is damaged on the printer or duplex option.
Software driver recognition of duplex option - reinstall driver.
Hope these suggestions help.
Nov 27, 2009 | Lexmark E450dn Laser Printer
Where can buy replacement DC power coupler for
Ebay seems the cheapest option - plenty of replacement spares for HG10.
Otherwise you can try ordering direct from Canon spares, but chances are it will be expensive.
Good luck,
Raf
Nov 08, 2009 | Canon HG10 HDD Camcorder
Touchpad & Keyboard unresponsive
please replaced the laptop ,other option u r put the button & clean the button
Mar 16, 2009 | Acer Aspire 5720 Notebook
Keyboard connected to base, but won't type
install driver for it again by this
  1. right click on my computer
  2. click on properties
  3. click on hardware
  4. click on device manager
  5. click on mic & other pointing device
  6. click on(+)
  7. then right click mouse
  8. click on update driver
  9. select second option in window(advanced)
  10. then click on( search removable.......)
  11. then insert driver cd in cd rom
  12. And click on Next option
If you have done this then do this(next step of above process)
  1. select third option(Don't search.I will...............)
  2. And click Next option
  3. click Next option in next window.Thats it
Hope this solution works
process-
Mar 09, 2008 | Logitech diNovo LX300 Keyboard/Mouse
Motorola Mobility i860 Cellular Phone Logo
35 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
