Question about Haier hwr10xc6 Air Conditioner
Haier window air conditioner
It had tripped the circuit and when I reset the circuit breaker and tried to turn it back on it wouldn't come on. So on the plug it has a rest and test button. The reset button doesn't work but when you press the test button before you plug it back in the test button works works. But when you plug it back in to the wall it trips the test button and the green light on the plug in doesn't come on...only for a brief second when I plug it into the wall until it trips. It is not my wall outlet because I plugged a lamp in and it works fine. Please help.
  • Ron Cole Mar 10, 2008
    I have a Haier window unit that is about a year old. During a power surge the safety power cord tripped and will not reset. I know the unit still works because when I hold down the reset button on the cord the unit will operate normally. Is there anyway to replace or bypass this saftey device without creating a fire hazard?
I suggest you check the ground of the wall socket. Many three proung sockets are not grounded.
Posted on Mar 31, 2008
Compressor not running.
Haier Air Conditioner Compressor
Using a ohm meter, and the compressor is cool to the touch, and the ac is unplugged, Disconnect the wiring to the ... Failure rate on compressors so far not including. ...Haier 12,000-BTU Energy Star Window Air Conditioner with Remote ESA412K-L. Consumer complaints and reviews about Haier Air Conditioner. Since air .
Jul 21, 2015 | Haier ESA412K Window Air Conditioner -...
Wiring schematic for white-westinghouse window air conditioner/heater selector switch
I'm willing to bet that the heater is grounded. Probably burnt up the original switch, heater wasn't getting power, therefore not tripping the breaker. Now the switch works, heater gets power and immediately trips breaker. Unhook the switch and tape the wires, reset breaker and try in heat and cool. If no problems it's likely the heater.
Apr 20, 2017 | Heating & Cooling
We have 2 breaker boxers for my house. 2 nights ago, a breaker got tripped, (too many air conditioners i'm guessing) and i flipped it back and all we well...almost. The power was lost upstairs and came...
Your main breaker may be problematic... GO to your master panel... the one with the meter, and reset everything, and on any sub panels reset everything.... Good Luck...
Jul 23, 2011 | Challenger Circuit Breaker
Just put air conditioner back in for the summer.. plugged it in and ran a test on it then nothing... any suggestion why it wont turn on..
Could have quite possibly tripped the circuit breaker. If it is a 230volt unit, there will be two breakers, they are usually joined together and probably 20 amp. Trip them all the way back and then all the way forward. If it is a smaller 120 volt unit there will only be one breaker, more than likely a 15 or 20 amp. Hope this works. Also, on newer models the plug may contain a reset button. It will be right on the head of the plug itself.
May 13, 2011 | Haier hwr10xc6 Air Conditioner
Circuit breaker on power cord does not reset
why did it trip? If you push test and it does not trip, check your circuit breaker in your panel
Jun 20, 2009 | Friedrich QuietMaster RS10J10 Air...
Air conditioner will trip breaker when trying to cycle back on
The compressor motor , once warm is grounding out due to wear and is going bad.Have the compressor replace while it is still clean is cheeper and easier that doing it after a burn out,which  will eventually happen,if the compressor is tripping the brreaker as I suspect..
Apr 22, 2009 | Dometic Rooftop RV Air Conditioner
Furnace keeps tripping circuit break
Furnace. To confirm use an Ampprobe or other brand ampmeter and see how much current is being drawn. If it is more that 80% of the breaker rating, it si for sure the Furnace.
Jan 10, 2009 | Haier Energy Star ESA3183 Air Conditioner
The power plug keeps tripping. when i press the button on the plug. it just trips.
Either there is something wrong with the unit or you have something else plugged into the same circuit. Air Conditioning units draw a lot of power and will trip a breaker if there is a moderate load on the same circuit. Try plugging it in to an outlet that you know doesn't have anything else on it. The other thing you can do is see what else turns off when the breaker trips, that will tell you what else is on the circuit.
Sep 15, 2008 | Haier Heating & Cooling
Heat pump trips circuit breaker
I seem to have the same problem. But when I reset the breakers, they won't stay in the on position. They go back to the off position. What gives? It is 95F inside the house.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
883 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
