Question about Magellan RoadMate 700 GPS Receiver
Magellan 500 HELP, I have a system I bought off E-Bay, regretful yes, no codes, no cables sold. Lesson learned, bought cables USB/ camera, bought 2 gig CF. Now, no codes, can you help where to go to load maps. asking for codes? can you help?
I'm on my 17th call. I have all the information for patches sent to m except 1 main unlock code. I have been trying since March, 07
Posted on Jan 09, 2008
  • 50 Answers
Call the magellan company they will help you with any questions that you have and register your unit on the magellan website for any software or firmware that you my need.
Posted on Jan 08, 2008
Lost remote for dynaudio sub 500 need code
that could be a hard one you have to find the search procedure to each remote and try searching the code the other thing you can do is buy a Sony learning remote and go to where that sub is sold borrow their remote for a minute and have the sony remote learn the commands that the sub remote has by putting them together with the remotes learning procedure. Or just buy a remote for that sub if they sell the remote by itself. their phone is (630) 238-4200
Apr 07, 2014 | DISH Network IR Remote Control
Drivers for detecting 4gb kingston SDHC
SD vs SDHC is a question I get alot. First let me explain your issue. Unless your CARD READER is rated for SDHC chances are its an older model and cant handle the card, even with driver updates. You will need to check the manufacturers website of the device you are using as a reader to see if there are newer drivers. If its a laptop go to the manufacturers page and and be sure and choose Windows XP as your OS. Ok, now to the difference. SD cards are called solid state memory. The internal workings of each hasnt changed much except that the SD card used standard file formatting that was understandable in Windows XP and earlier operating systems. the SDHC (HC stands for High Capacity) uses the same architecture in teh card but changes the way data is stored and read that enables it to hold more data on same size device. (note architecture means design of card type not inside guts) Thus your system and Operating system may not be capable of addressing the new coding and file system changes on teh SDHC cards. Many older cameras (2008 and before) dont recognize SDHC cards either. Good news is they make an SD card (plain) in a 4 gig and you may be able to replace yours at the retailer with teh correct one needed (unless you bought via ebay or other method) Yours is a good question and is often asked, so dont feel bad in anyway. Just look at it this way.. you learned the lesson recently when the pricing between the two is about the same.. I learned the lesson 2 years ago when an SDHC cost about 80$ compared to 19 $ for a normal SD... SMILE!
Jun 28, 2010 | Kingston 4GB Secure Digital High Capacity...
SimpleTech 80 GB Portable HD Won't Read
It sounds like a problem with the board inside the case,- the actual hard drive is probably OK. Opening the case will void any warranty but there may not be much left anyway. There should be 4 screws in the bottom of the drive,- front 2 may be hidden under a sticker. Try installing the drive in your new case or an empty drive bay inside your computer. I have had external hard drive cases fail before and the actual hard drive was ok.
Jan 23, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Magellan Triton 500 value bundle
magellan has a big problem in the past with the Canada Value Pack. It did not work with the Triton. It was only made to work with the older Magellan GPS units.
Best to contact Magellan and see if they will give you a new one.
Dec 29, 2008 | Magellan Triton 500 Handheld GPS Receiver
Maxtor 3200 usb personal storage
Like many others, I had problems with the drive and tried some obvious solutions like swapping the old USB cable with a new one, trying different computers with XP, Vista, etc. and nothing worked. One solution I found was to open the HD case and swap the drive into a spare bay on your PC tower. I didn't want to go there since the case is very hard to open and I didn't want the hassle. So, the solution I tried was to replace the power supply. I saw this solution a few times in some forums so I figured to give it a try. I Googled the exact specs and found a comparable power supply at 12V Adapters (Aurora CO). It is not a Maxtor supply but I figured as long as the output was correct it may work. Just got the adapter today, plugged in the HD, and YES, IT POWERS UP and the XP at my work recognizes the drive! Now I have all my files available and accessible. Good luck to all, I hope this works for you. By the way, one lesson learned: BACK UP BACK UP BACK UP! Drives are so cheap now there is no reason not to (except for being lazy)!
Sep 14, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Problem with datalogic magellan 1000i barcode reader
hi
the cable is USB?
if you have usb cable, you read the manual paper "default".
if you have cable rs232 you must install on a PC emulator "softwedge". Open icons and set a comm. Prefer you answer. bye Roberto
May 16, 2008 | Datalogic Magellan 1000i Hands Free...
Magellan Maestro 4010
yes ,
but design some external cicuit for voltage control system as pda needs,
but ,irts possible,
THNX
May 16, 2008 | Magellan Maestro 4040 GPS Receiver
Downloading Camcorder to PC
I've learned my lesson and will share it. Use firewire and try WinDV. Best of luck.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Broken connector cable for Pentax Optio 450
Yes. The cables are sold too. I got a deal by buying a dock from compgeeks.com and it was cheaper than just the cable. So, go shopping.
Aug 30, 2005 | Pentax Optio 450 Digital Camera
Magellan RoadMate 700 GPS Receiver Logo
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
