Question about Jl Audio 500/1 Car Audio Amplifier
No sound the light on the amp is green, i checked the rca's and the sub its hooked up too. i cant get any power to my sub
    Problem Solver:
  • 11 Answers
If tghelight is green the power is there...but themost common problem s power return..meaning that you might have a bad ground. i wouldsuggest inspecting your ground cable..it should be 6awg minimum and make sure that its grounded to either the frame or negative battery terminal. nothing painted and nothing that doesnt eventually connect to the frame.
Posted on Sep 06, 2007
Subs not working
has everything been hook up correctly more specifically the RCA,s.make sure theres a source. If u sure everything is fine check ur subs with a dmm
Apr 27, 2010 | Car Audio & Video
Power light comes on but no sound :(
Good amp but gave me nightmares because of cliping and power protect. if wired correctly then your sub might be blown check subs by using a multimeter and check ohms. No ohms means its blown. Ohms vary between subs. double check Rca inputs as well I just hook up my comp speakers to do this.
Mar 23, 2010 | Quantum Audio QSA1500D Car Amp
The light on my amp is green but no sound
have you got the auto ariel lead from the head unit connected to the remote connection on your amp?
if not then that is your problem, it turns the power on when you turn on the unit. and turns it off when you switch unit off.
hope this helps
Mar 18, 2010 | AudioBahn A2300HCT Car Audio Amplifier
I have checked all connections to my amp battery,head unit,remote or trigger wire,fuses,power cable,rca leads,ground wire,amp has a green led light on it indicating if it works ok,red if it`s not,light...
Your amp could be in protection mode! Sometimes turning up to high or wires touching will put in protection mode! It will have to be unplugged for a day or two to drain all power out of the memory. Leave accessorie/ignition wire hooked up, just not power and ground wiring. It should reset itself.
Jan 22, 2010 | Lightning Audio B4.250.2 Car Amp
Audiobahn amp help...
You have a Direct Short in the System Between the Head Unit and the Amp. Check the Ground on the Amp and then Check all the Wires behind the Stereo and the Common Ground There. You could even have a Spot in the New RCA Cables that is Touching Metal Somewhere. Please Rate My Response! Thanks!
Feb 09, 2009 | AudioBahn A2002T Car Audio Amplifier
Sony xplode 1000w amp has green light puts out no power to subs
may haveto turn sub on through the stereo itself if rca cables are good.
Jan 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Kicker 750.1 Amp wont play music
it is probably the rca inputs on the amp may have fried. was your cd decked turned up loudly before the power went out? did any wires accidently touch each other? If had worked fine and then suddenly stopped, than either a wire came loose or the inputs fried. try using different cables and I also suggest disconnecting power for 24 hours and then reconnect. If the green light is on then it is getting power and the problem is in the rca cables or the inputs
Jun 03, 2008 | Kicker 06ZX750.1 Car Audio Amplifier
Jl 500/1 no sound, green light
This is an indication that the MOSFETs are ok but the driver stages may have a problem. Get a schematic find the pre-amp stages and test the voltages levels there as compared to the schematic. I do believe that you will find the problem in the pre-driver pre-amp atages.
Sep 03, 2007 | Jl Audio 500/1 Car Audio Amplifier
Jl 500/1 no sound
If all of your connections are correct you may have sustained damage to the driver amplifier that controls the subwoofer. If you have electronics experience and can get the schematic, you may want to trace the audio signal to see where it drops off. it is my guess that it will either a one of the pre-driver transistors, or at the main power driver MOSFET devices. In any event they will need replacing if they are bad. I don't they are bad because the light does not remain red so it might be on of the pre-driver transistors.
Sep 03, 2007 | Verge VGA300M Car Audio Amplifier
Rockford Fosgate P3002 Amp
what are the color of the lights that stay on.red= protect/ green=on.if the amp has little sound it probably still working,check deck output volume(rca)
Aug 22, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
125 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
