The reason is the shaft at the balance wheel end is dry of oil and the only way to oil it is to take the balance wheel off or at least pull it out enough to spray some oil onto the shaft, I would suggest undoing the small screw on the stop motion wheel, unscrew the stop motion, you will see a three pronged washer, remember which way it goes on, take it of, tilt the machine on it's end and pray a few drops of wd40 on the end of the shaft and let it work it's way down for a minute
SOURCE: can't get the clutch to disengage so that I can wind the bobbin
Where is the model number on Kenmore machines?
SOURCE: singer quantum cxl sewing machine needle hitting metal
Your needle is probably to long or you need to open it more
SOURCE: Locking disk on handwheel won't lock and I can't wind a bobbin
If the stop motion wheel is stuck and you can't free it the best way to do it is to stand at the end of the machine, get something that looks like a chisel or something that has a flat end even a screwdriver, put the end of the screwdriver in a slot on the left hand side of the stop motion and give it a sharp thump down, it worked for me for years, the only problem you may have is if you do not have any slots or grooves to put the screwdriver in.
