SOURCE: can not install sound card on Asus F5R
alrighty, check your bois see if your audio device is disabled, also check in device manager if theres any multimeda devices that have no drivers, then go to sounds and audio devices in controll panel and select the device and theme for your pc some times Windows has a dedede moments hope this helped ^-^
SOURCE: My touchpad has stopped working. Device Manager
It may be that it is broken/faulty. Is any mouse usually connected? If yes, install and check all drivers are ok, then connect them one after the other, mouse first maybe then both simulteneously.
SOURCE: my touchpad buttons don't work IBM T42 laptop
In this case you probably disabled it by mistake ..and you need to enable it again ..Go to control panel ..and locate the touch pad..and see if it needs enabling . If this will not work ..you have to download the driver for the touch pad..and reinstall it ..or ..if the driver is still in the system it is enough to get to control panel ..add hardware ..and run the add new hardware wizard..This will search for hardware and show the ones which are not installed or ..if no one is present ..select already added and look for the pad..
Or ..I would option for getting into device manager..(right click on computer ..select properties../hardware /device manager..or direct device manager for win7 ..)
in the device manager select the touch pad..and click right on it ..and select update driver..This will start the wizard and install the missing driver if it is still in the system ..If it isn't you will have to install it manually after you download it from the support site ..or from the disk .
SOURCE: I need a manual for an Asus X54H-SO180V
what exactly are you trying to do? i can't find a manual specifically for your laptop
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Click Start/Control Panel and
look for the Mouse and open it to check the mouse properties. Make sure
you don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on the
button that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upper
left hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press and
Hold the ALT or FN function key located at the lower left portion of the
keyboard, then hit the key that toggles the touchpad. The correct key to
hit will have the icon of a finger pointing at a square that represents the
touchpad.
Download and reinstall the touch pad drivers.
Get online and got to
www.google.com In the google search box type: "ASUS Support"
(without the quotes and put your manufacturer name before Support). Look
for downloads and drivers. Enter your model number and operating system when
requested. Download and install the Touchpad drivers.
