Question about Akai LCT3201AD 32 in. LCD Television
AKAI LCT3785TA I am getting two white pixelated vertical lines on the screen when I am using DVD or non-HD channels. The PC input and HD channels do not have this problem.
    Genius:
  • 1,139 Answers
I am leaning towards scanning on this problem but you should have a schematic and the proper equipment to rtest this problem, I would suggest taking it to a TV repair shop of look for one on FixYa that can look at your system.
Posted on Sep 09, 2007
SOURCE:
I HAVE AN AKAI PT5598HD READY . PICTURE ROLLS VERTICALLY ONLY ON NON HD CHANNELS. MY HD CHANNELS ARE OK. HOW CAN I FIX IT?
try to check first the systems set up like for example PAL or NTSC system because if it not set to the right broadcast system the picture might be roll or sometimes black and white.
Jun 28, 2011 | Akai Televison & Video
Hooking up a dvd
You want to hook up the cables to any of the VGA input sets. Red= right audio channel, White= left audio channel, Yellow= Video. Don't plug them into the sets that have Red, , Green, and blue inputs. Just the set with red, white and yellow. Now you won't get HD from this since it's not bluray or HD-DVD. Just be sure you select the corresponding input on the TV when you want to use the DVD player. For example, select input 1 from the on screen display if that's the one you plugged it into.
Nov 07, 2008 | Sharp Aquos LC-32GD6U 32 in. HD-Ready LCD...
Problem with my Akai PDP4225M Plasma
I fixed it without having to PAY someone to tell me how!
Sep 27, 2008 | Akai PDP4225M 42 in. Plasma Television
HDMI INPUT FOR NON HIGH DEF CHANNELS WILL NOT DISPLAY FULL SCREEN
if you have a cable box then it is probably the resolution settings in the cable box, what type of cable box do you have
Jun 30, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Picture issues
Greetings caesar975,
Unfortunately if you chose to view the non HD channels in wide screen format, you are going to have the top and bottom of the screen cut off. Eventually this will not be a problem when everything goes to digital. However presently non HD channels are presented in 3:2 ratio where as HD is 16:9, So your choice really is to view them with the lines on either side for now.
I do not have an answer for the white flickering lines.
To get the BEST picture out of your 1080p unit I highly recommend using HDMI cables to hook it up.
I hope some of this helps.
Sincerely,
Dorothy
Go Ahead. Use Us.
Jun 11, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Green line
sharp is very aware of the panel and main video processor problems.They should give you no problems on the repair.It sounds most likely you have a main video processor problem.
Mar 13, 2008 | Televison & Video
Vertical lines on my laptop screen
white vertical line on my screen of my laptop..how can i fix t
Oct 26, 2007 | Compaq Presario M2000 Notebook
Akai LCT3201AD 32 in. LCD Television Logo
83 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
