Question about Nokia 7370 Cellular Phone
Broken Screen Nokia 7370 I dropped my phone yesterday and now the screen is white, I can still receive calls and make calls if I can remember the numbers and the sequence of buttons to push on the phone. I guess I will need it repaired. question is do you have any idea how much it might cost or would it be cheaper to buy new phone.
  • MsBaugh Jan 03, 2008
    i never dropped my phone but it was open while it was charging and the screen image became distorted or it was just a white screen. I can still send and recieve calls but i am not able to view menu options. Is the screen broken or is the phone beyond repair?
  • musicalhetti Oct 21, 2008
    I have never dropped my phone, but the screen is white with a big black line at the top. I can still make calls and stuff, but even when the phone is turned off the big black line is still there...
I have been getting the white screen of death on my Nokia 7370 on occasion, which started happening immediately after it took a tumble. It goes through the Nokia startup screen and then goes white either immediately or after a few minutes. Does some strange things, re-recieving messages.
I have just discovered this seems to be linked to a full phone memory. The strategy to get around it is to remove the sim card so that the phone no longer downloads messages, startup and connect via usb to the computer. Using PC suite, clean out the contents of the phone.
This may not be the same problem as others have had but hope it's of use to someone.
Posted on Jan 21, 2009
    Sergeant:
  • 452 Answers
The thing is that the display pannel of ur phone have been damaged , get it replaced from nokia care centre , this might cost u from 1000 - 1500 rupees...
Posted on Oct 22, 2007
SOURCE:
My phone's screen is black
sir if you can call and received a call ,your lcd is need to replace...sometimes it cause by lost connection but the best way is replace it lcd..
Jun 06, 2010 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Screen does not swivel
better to service of your phone from a mobile repair shop and never try to dry with hair drier or under sun light or any other type of heat because water dries inside with some white calcium so hurry before water dries inside
May 02, 2010 | Nokia 7370 Cellular Phone
Nokia 6210 black screen
the most possible answer is that your screen has broken or the cable that connects the screen with the board is cut. refer to the nokia service for change
Oct 01, 2009 | Nokia 6210 Navigator Cell Phone
After taking care of my expensive mobile phone Nokia n95 8G for just 7months it turn to blank screen can't received a call or even make a calls or txt. its blank totally disappointed.
the white screen is caused by a broken crystal diode in the lcd screen. replace the lcd screen either at an authorised nokia centre, phone store or buy the lcd screen online and install the parts yourself- tools are provided with the purchase and its a simple DIY task. you'd spend $300+ at nokia centre, $200-$250 max if at a phone store alternatively you'd spend $100-$150 max if you DIY.
cheers.
Aug 03, 2009 | Nokia N95 Cellular Phone
File format not supported 7370
Hi Friend,
Kindly download the themes from the below links and check it out. From the below links u can download the themes,wallpapers,Games,screen savers,software
http://www.mobileheart.com/cell-phone-themes/71-Nokia-7370-Themes.aspx
Regards.,
Ayyasam
May 29, 2009 | Nokia 7370 Cellular Phone
My n70 only shows white screen!!
my cell phone did the same thing, there is no solution-most likly caused by humitity, just send it in for a new cell phone.
May 28, 2009 | Nokia N70 Cellular Phone
Phone screen
hi
u need new lcd for this phone to knw how to replace it ask me.
first purchase one.
tell them i want an lcd for 7370
in any partstore
best regards plz do rate this post
Sep 24, 2008 | Nokia 7370 Cellular Phone
N80 White Screen
white screen?? but still your phone boots fine?can you still receive call or text msg? if soo, your only problem is the lcd of your phone,
but if your phone freeze on white screen and didn't continue to boot up, try reformatting it
by
key combination which is used to hard reset the phone (similar to #*7370). It is useful in some cases, for example when the phone cannot reboot.
The trick is
Switch off the phone.
Hold down the following three buttons: Green (call answer) button, * button, and ‘3′ button
While holding these buttons, press the power button and switch on the phone
When the message ‘Formatting’ appears on the screen, release all of the buttons...
but all your data will lost
Sep 01, 2008 | Nokia N80 Cellular Phone
Broken screen
I have the same problem......I NEED HELP!
Jun 09, 2008 | Nokia 5300 Grey Cellular Phone
Nokia 7390
update the software of latest version of nokia 7390.
Nov 03, 2007 | Nokia 7390 Cellular Phone
Nokia 7370 Cellular Phone Logo
138 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
