Question about Sony Cyber-Shot DSC-P71 Digital Camera
P71 Bought a new 512 Pro Dou memory stck for my P71. When Installed , all i get is a memory stick error flashing on my screen. Any ideas? Thanks
  • Anonymous Jun 22, 2008
    need a memory stick compatible to dsc p71
  • Anonymous Dec 23, 2008
    it cant take more then 256 mb memory stick
This camera cant take more then 256 mb of mamory thats how it was designed go to sony.com and check it i have the same camera
Posted on Dec 23, 2008
Dscp71 only supports up to 256 and not pro or produo. acording to lexar or sandisk.
Posted on May 17, 2008
I have the same problem with my cybershot p 71. I wasted money on two memory sticks.
Posted on Apr 16, 2008
  • 641 Answers
Does your camera works fine with the previous memory card?
Posted on Sep 03, 2007
6ya staff
SOURCE:
Lost driver & installer
hello
due to the fact that this memory card is no longer available, Kingston does not have drivers fo this card . As a matter of fact SD cards normally do come with drivers , as they are conformed in a way that operating systems recognise them once you plug them into the SD slot
i hope this inofrmation helps you make a decsion
some background on this particular SD memory card you have
SDCZ2-512-A10-KT (Discontinued) Description: 512MB USB 2.0 DataTraveler I write up to 3MBps Discontinued Additional Info: DataTraveler I USB 2.0 Flash Drive Write up to 1.5MBps Read up to 6MBps Mfgr's System P/N's: SDCZ2-512-A10 (Kingston) Form Factor: USB Flash Memory Warranty: 5 Yrs†
here are some solutions .
When the problem occurs is a clue as to the cause.
For example, your response to a memory error message depends on whether:
  1. You have just bought a new computer.
  2. You have just installed new memory.
  3. You have just installed new software or a new operating system.
  4. You have just installed or removed hardware.
  5. Your computer has been running fine and you've made no other recent changes.
UNEXPECTED PROBLEMS
If your system has been running fine, but suddenly starts to produce memory errors, and crash or lock up frequently, the chance of a hardware failure is more likely, since configuration and installation problems show up as soon as the computer turns on. Sometimes you can get memory problems if your computer is overheating, if you are having a problem with your power supply, or if corrosion has developed between the memory module and the socket, weakening the connection.
HANDLING SPECIFIC PROBLEMS
Here is a list of the most common ways the computer informs you of a memory problem.
  1. The computer won't boot, merely beeps.
  2. Computer boots but doesn't recognize all the installed memory.
  3. The computer boots but the screen is blank.
  4. The computer reports a memory error.
    1. Memory mismatch error
    2. Memory parity interrupt at xxxxx
    3. Memory address error at xxxxx
    4. Memory failure at xxxxx, read xxxxx, expecting xxxxx
    5. Memory verify error at xxxxx
  5. The computer has other problems caused by memory.
    1. The computer intermittently reports errors, crashes frequently, or spontaneously reboots.
    2. Registry Errors
    3. General-protection faults, page faults, and exception errors
Nov 07, 2010 | Kingston (SDCZ2-512-A10-KT)...
I have a memory stck inserted i formatted it on my psp
that is it . there is no enough space for your demanded progress . that means you should buy more space next time . rate please !
Jan 11, 2010 | Sony 1GB Memory Stick PRO Duo Memory Card
Can't use memory stick pro with my camera sony sybershot dsc-p71
its not compatable in the sense of its too much memory for the camera try getting a stick that is smaller in size instead of gb go fro mb
I’m happy to help further over the phone at https://www.6ya.com/expert/alex_32392698f23d119d
Jul 08, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Memoy stick pro dou and my p900
SE P900 does not support memory stick pro duo. it' s only support MEMORY STICK DUO (w/o PRO). i have the same problem too. my p900 only live with 32MB MS DUO and there are no more MS DUO in my city (even SE's service center)
if you wanna use your MS DUO PRO, then you'll need to upgade to P990i or P1i. that's much better then P900i (newer OS, more ROM, new keypad, plus WiFi) :D
Dec 24, 2008 | Sony Ericsson P900
64mb to 2 G memory stick dou
The 2 GB memory stick should work in your P990 and not cause any noticeable slowdown.
May 01, 2008 | Sony Ericsson P990i Cellular Phone
Problem accessing memory stick
I had the same problem. I bought a 2 gig memory pro-duo with the adapter and it gave me that error even though it fit just fine. I then tried a 512 memory stick and a 1 gig memory stick and neither one worked it gave me the C:13:01 error code. So I found out the hard way that the camera will not read it. The Sony DSC-S85 will not take memory above a 128. Try the Lexar 64MB memory stick. I just bought 4 and they work perfectly fine.
Nov 02, 2007 | Sony Cyber-Shot DSC-S85 Digital Camera
Memory stick
Sep 03, 2007 | Sony Cyber-Shot DSC-P71 Digital Camera
File error
I was having the same problem with my 4GB memory stick pro duo, when i took more than 50 pictures with my camera (dsc-w90) i would get the blue screen with the file error message. I'm guessing you bought the memory stick on ebay right? I bought mines there and it turns out it's a fake one. If you also bought it there then you most likely have a fake memory stick because I found out that most of the memory sticks sold on ebay are fake, to help you figure out if you have a fake one or not check out this guide or google fake memory stick pro duo. http://reviews.ebay.com/FAKE-Sony-Memory-Stick-Pro-Duo-MagicGate-Cards-Exposed_W0QQugidZ10000000001236041
Dec 25, 2006 | Sony Cyber-shot DSC-W50 Digital Camera
Neither my camera nor my computer with XP PRO OS can identify this memory stick
You will need to reformat the card: 1. Place the card in the reader 2. Right click on the drive letter for the reader 3. Choose format 4. Choose full format with no label 5. Finish the format 6. Test card. It should now be working correctly. Note: Certain cameras may require that you also format the card in the camera.
Oct 20, 2005 | SanDisk Memory Media
Sony Cyber-Shot DSC-P71 Digital Camera Logo
167 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
