Question about HP Pavilion zd7020US Notebook
After I installed a new printer I cannot get online.
My wireless connection shows a strong signal but no matter what I do I can't get online. This is the same comcast connection I've been using for years. My wife's Macbook and iMac in the house are still getting online, but my laptop will not. This started after I installed a new printer HP Officejet Pro L7680. I have since uninstalled it, but I still cannot get online. Thanks.
  • Kurk Sep 04, 2007
    I tried everything you suggested, but it still was not working. I finally ended up having to disable my built in wireless and install a new wireless card, and that finally worked. I guess adding the new printr with wifi zapped my computers wireless stuff.
    Thanks for trying to help!
    President:
  • 317 Answers
Do you have a firewall installed? If so, disable it and see if that helps. Try a system restore, Start, programs, accessories, system tools, system restore. It will give you a list of dates to restore to. Put the latest date that you knew that you had a working connection.
Posted on Sep 03, 2007
Dropping Wireless Connection
In some cases it is not always the signal strength as it is the updated drivers necessary to communicate with the computer system. Go to the manufactures web site and look for updates. Make certain your Windows updates are current also. If necessary, delete the Printer and reinstall it again. You may try to go to control panel/ devices. Pull up the Printer line and hit update drivers.
Mar 05, 2014 | Samsung Scx-3405fw All-in-one...
My laptop computer won't connect to the internet
why dont you try to disconnect from the network then reconnect it will reset the wireless connection and give you a better signal
Jul 13, 2010 | Dell Inspiron 1501 Notebook
I INSTALLED A NEW NETWORK ADAPTER D-LINK AND NOW. SHOWS VERY STRONG SIGNAL BUT ITS VERY SLOW TO COME UP OR TO CHANGE FROM 1 WINDOW TO ANOTHER.
this is not the router. if its shows strong signal that means your router is up and running smoothly but when its ran throught your internet it failes to find a good access point. this can be fixed by calling your internet provider and seeing if thier systems are compatable to your router.
Feb 01, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
I use a dl 514 router. the computer shows a wireless connection and a strong signal but i'm not able to get online. now that I'm using a cable, it still shows a wireless connection with a strong signal.
Its quite likely that the router is not connected to your computer wirelessly. Which means, your wireless card is not picking up a IP address. I would suggest two thigns 1. In your wireless utlity , try to repair the connection. 2. Check if you have a static IP address. If you do, remove it.
Hope this helps
Thanks Ranjit
Sep 14, 2009 | D-Link DI 514 Wireless Router (DI-514)
If my pc has a strong internet signal - why can't I go online?
its a wireless signal may have to move it around to get your signal things such as walls ,appliances distance can cause signal loss
May 18, 2017 | Linksys Bundle: BEFW11S4 802.11b Wireless...
My router is hooked up correctly on my desktop and my laptop shows it is connected with a strong signal, but I still cannot get online, any suggestions
If you can't get online on either machine, plug your ethernet cable directly from your cable or dsl modem into your desktop. If it shows a network connection and you still can't get online, it may be a service provider problem. I am assuming that your service provider did not ship you a router, only a modem. Hooking up 2 routers on the same connection can be very tricky.
Jul 30, 2009 | Trendware TRENDnet 4-port Switch - 54 Mbps...
I have a Toshiba L25 laptop and a D-Lin Air DWL-650 wireless card. I'm not getting the best connection with the wireless card while my other computer has a much stronger signal. I'd like a recommendation...
im assuming its a cardbus adapter right? well that model is a wireless b signal, which isnt very strong, so any wireless g model should have a much stronger signal. it doesnt matter which one it is, as long as its wireless g, which most new cards are. hope this helps, goodluck
Jul 09, 2009 | Toshiba Satellite L25-S119 Notebook
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
My wpn824 says I have strong signal but limited access.
u may have a strong signal but in ordet to have a stable connection u should be sure that u r connected to your wireless network
Jan 09, 2009 | NetGear RangeMax WPN824 Wireless Router...
Wireless connection
In order for me to deal with this query for you, could you tell me what brand and model it is the Laptop?
Fran10
Apr 10, 2008 | Dell Inspiron 6400 Notebook
HP Pavilion zd7020US Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
