Question about Samsung HL-P4667W 46" Rear Projection HDTV
Samsung DLP I go to turn the TV on. I hear the circuit pick up, but after about three seconds it clicks off. The lamp doesn't try to come on at all. IT just clicks on and then clicks off after a few seconds. Any ideas?? Cuz I am lost. Thanks
    Problem Solver:
  • 24 Answers
Change the lamp.
Posted on Sep 03, 2007
SOURCE:
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Samsung DLP not turning on
usually the colorwheel will prevent the set from powering up when all three lights blink. Diagnosis assistance is available for free from www.tvrepairworld.com
Jun 15, 2012 | Samsung HL-S5086W 50" HDTV
My Samsung 60 inch DLP TV turns its self off several times an hour. Eventually is stays on. What's the problem?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.Have a bless one!
Apr 20, 2010 | Samsung Televison & Video
Just replaced the lamp and the tv turns off after about 60 seconds
First. Did you reset the lamp timer on your tv after replacing the old lamp? This is important to keep track of the life of your lamps. Dust off internally, dust tends to affect the temperature of internal parts. Do you hear any other noises? ex: buzzing, clicking, could be your ballast. If you hear any winding, whirling or screeching noise could be your color wheel.
Jan 28, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV, no picture, has sound
Try replacing the ballast next. Its the small circuit board directly underneath the lamp housing. You can access it through the lamp door. If the ballast is overheating or has a leaking capacitor, the tv won't stay lit for more than a minute or two.
Mar 12, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung dlp turns on for few seconds and shuts off
lamp shuts off first..with sound still on and black screen.then turns off and has three blinking lights on front panel.
Jan 10, 2009 | Samsung DLP HL-P5663W 56" TV
STANDBY LIGHT TURN ON
when turning on the set will go three startup cycles about 2-3 min. then all three leds will blink/ possible causes /lamp/ballast/dmd board check or purchase the dmd board last (costs) also listen for arcing from the ballest at startup and fan noise if you can and color wheel noise also.if you hear the ballast arcing and trying to fire the lamp look at the lamp.
Jun 15, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5063W. . .no lamp!
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-P4667W 46" Rear Projection HDTV Logo
94 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
