Question about Philips Magnavox 27MS343S 27" TV
DVD VHS recorder
I bought a HDTV and I have Time Warner cable. I have by red, blue, & green cable hooked up from my cable box directly into the TV and also my red, & white cable from the cable box to the tv and I get a picture. I need to know how to hook up up DVD AHS recorder MWD 2206 to play tape and dvd's. When I hook up the cables from the tv and hook them up to the VCR I get no picture nothing at all how do I hook these all up together to get everything to play. I have my red, white, and yellow cables hooked up from the tv to the vcr and still nothing happens The brand of tv I bought is OLEVIA or can bee found at www.olevia.com brand 232. Thanks
    Genius:
  • 1,139 Answers
It sounds like your cables are connceted ok, but what you neede to do is to be able the switch from one video mode to the other so lets go through the cable and vrc conncetions again just to make sure. From your cable set top box connect your component video (RGB) video out to your TV (RGB) video in via the (RGB)cables. From your VCR connect your composite video (yellow) out to your TV composite video in withe the composite video (yellow) cable. From your VCR (Left & Right audio out)connect your left and right audio connections (White and Red) to the Audio in of the TV (Left and Right). Whith this setup you should be able to use the TV to switch between the two A/V inputs using the remote control.
Posted on Sep 20, 2007
I am supposed to be able to record from VHS to DVD and yet I am unable to do so. I asked the question yesterday and did not receive and answer.
Not knowing what components you have makes it difficult to assist you. As a general note, HDMI provides the best connection for video and audio.
HOWEVER, the HDMI source can talk through the cable to the connected device. A cable box, seeing that something other than a TV is connected to it, will turn off the signal rendering the connected device useless.
To get around the problem, cable the devices together using component video and audio cables (5 cables are required). They are typically colored red and white for audio and green, blue and red for video.
Oct 05, 2014 | Televison & Video
I just hooked up my Flat TV to my Panasonic VHS-DVD recorder player and the screen only shows blurry Black and White when displaying or recording, The TV itself is fine.
Sounds as if you hooked up your player wrong. If you are using a composite hook up. You should have a yellow, red and white cable. Make sure it gets hooked into the same on the TV. If it is a component connection, then RED, Green and Blue. It sounds like you have your Yellow composite going through your Green component. If by chance your TV is a new Sony, then you might have to go into the user menu and turn component off and composite on.
Apr 05, 2011 | Televison & Video
How do I hook up the DVD/VCR to cable box and Vizio HDTV?
both should be hooked directly to tv
VCR side of combo should be hooked up with composite video(yellow, red, white wires) to video 1 input
DVD side of combo should be hooked up component video (red, blue, green wires and red white for sound)
cable box should be hooked up HDMI or component to TV if HD or composite video if SD
hope this helps
good luck
Mar 13, 2011 | Samsung DVD-V4600 DVD Player/VCR
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Apr 19, 2010 | Televison & Video
I just purchased a vizio 37 in tv. I wanted to know about the best hook up for the tv to the direct tv box.
If your Direct TV box is HDTV compatible then the best connection would be HDMI, and Componant Cables (Red, Green, Blue, w/Red, White) would be the second choice.
If your Direct TV box is not HDTV compatible only SD compatible, the best connection would be S-Video (S-Video cable with audio cables), Composite Video (Yellow, w/Red, White), or Coax cable.
All of the above cables can be purchased at your local Radio Shack, Best Buy, Walmart etc..
Feb 08, 2010 | Vizio Televison & Video
Connect dvd recorder to cable box and hdtv
I have posted a tip that should help you out with your problem follow the link below but there is one minor variation for connecting to your TV.
On step 3 of the connections section substitute the follow for your situation.
You will need 1 component cable (Red/Blue/Green/Red/White cable)
3) Connect the Green/Blue/Red connectors to the back of the DVR labeled "COMPONENT OUT" matching the colors. Connect the same ends to the input of the back of the TV again matching the colors.
4) Connect the last two connectors (Red/White) to the back of the DVR to the AUDIO IN on the TV.
Other than this variation all shoud be the same.
CLICK HERE for complete tip.
Good Luck...
Jan 27, 2010 | Panasonic DMR-E55 DVD Recorder
Wii hook up to time warner cable box with a dvd
I needed another part... an RCA cable splitter to put two cables into the same TV connection.
Nov 09, 2009 | RCA Televison & Video
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Dvd connection to cable
Connect cable on combo player cable in post to time warner cable box cable out post. and connect the combo player to TV with audio and video patch cords.
Jan 16, 2008 | Samsung DVD-V3500 DVD Player/VCR
Philips Magnavox 27MS343S 27" TV Logo
225 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
