Question about IBM ThinkVision L170 17" LCD Monitor
LCD image distorted and flickering.
Please take a look at the picture in this URL http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300139559555 The monitor on the right is displaying the symptom that I am looking for opinions on. This has got to be a fairly common issue with these IBM LCDs, as I have 3 of them that are doing it. They will flicker the images for a while and then they might straighten up and work correctly for a while, but they always go back to doing it eventually. Might stay flickering for days, might work for days. One just never straightened back up. I suspect a solder joint issue, or failed/failing component. Any tips on where to start looking on this model? Thanks James
  • 472 Answers
The Thinkvision series has a known issue with capacitors on the power board.
It is an easy repair, though if your not confident with electronics then get your local TV man to have a look.
Your eBay link isn't working by the way.
Hope that helps.
Posted on Apr 10, 2008
Visio Strange Color/Pixel Problem As of now, every time i turn my 32" Visio HDTV (VX32LHDTV10A) on, certain areas and colors are going crazy and it has progressively gotten worse over the past...
The tv main Tuner signal board it is the causes and the problems.The board it is dying and shorting out.U have some mechanicals skills,like take things aparts and putting it back togetther again?Yes.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv main Tuner signal board for the replacement.
Jul 14, 2011 | Vizio L32 32 in. LCD HDTV
Lcd screen flickers in photo mode
If your Canon A85 shows distorted image in live view (camera mode) then its known problem of ccd imager chip failure. Check below image.
canon offers free of cost ccd imager chip replacement in A85 model.
Please confirm if its canon A85 camera or any other model to provide you more info.
Dec 23, 2009 | Canon PowerShot A85 Digital Camera
Sony DSC-t33 lcd monitor is distorted.Pictures
Hi!
It's a faulty CCD imager - a very common problem with the T33 - the imager has to be replaced. You can buy it from http://myworld.ebay.co.uk/toms.rammsteins and replace the CCD yourself (ask seller the instructions).
Tom
Oct 10, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
Picture often flickers and image distorts every few minutes
The trouble is most likely in the Video processor. If the trouble looks like its tearing the video only from side to side it may be the line doubler circuit. Some of these boards are no longer available but a good TV tech may be able to componnent level repair it for you.
Apr 15, 2009 | Toshiba TP50H95 50" Rear Projection...
Screen image appears fuzzy, jumpy and broken up into lines.
gardenman13, I would certainly complain to HP about their w22 monitor!! Find out if the units warranty is still valid and can be swapped-out for a REFURBISHED unit. Your w22 shouldn't be hazy, distorted, or flicker for any reason. My best guess is that it (w22) has problems inside with it's "cold-cathode-fluorescent-lamps" and electronic ballast circuit called an INVERTER circuit, which could also cause the main "switch-mode-power-supply" to go a little NUTS upon STARTUP!! FYI you are dealing with a technology similar to the curlie-Q CFL screw-in light bulbs. Their ballast's are called CONVERTERs (ac to ac) and are cheaper. Your lanps are thinner and straight, hung on rear of your LCD panel. I hope this was informative. Please rate this on fixya. 12fixlouie
Dec 11, 2008 | HP W22 LCD Monitor
Flickering LCD screen on Sony digital camera DSC-T1
Camera has problem in CCD Imager and this part needs to be replaced. Sony has scheme to repair it free of cost. Please click Sony Support for details.
Regards,
Aug 28, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Distorted picture when looking through view finder or lcd screen
the video playback is sampled off the video out and independently processed sorta like a TV signal to project on the lcd screen.
horizontal lines means you lost sync circuit and needs troubleshooting. Hopefully maybe a bad connection with a ribbon cable for the ICs and components are hard to change and jammed tight. I would order a video board.
May 14, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
LCD flashes and flickers, partial display of bootup and then black screen
Try the following:
Sometimes when you press and hold the corners of the LCD area (not on the LCD itself, but on the frame), and see if it gives you a picture (or at least flickers when you do so).
My opinion is that your LCD could need rewiring or replacing.
Dec 15, 2007 | Dell Latitude D505 Notebook
Sony Bravia LCD Flickers/distorts
Wanna sell the tv for parts? Kev0201@yahoo
Sep 14, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
IBM ThinkVision L170 17" LCD Monitor Logo
1,020 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
