Question about Akai LCT2701TD Television
Not turning on
Tv was running then made a small pop noise and screen went black but the little red lite just keeps flashing but the set will not turn back on. I tried unplugging, did not work. There is also a cd now stuck in the built in cd player. Looked for some kind of reset button on back but could not find anything. Light just keeps flashing. Left if off for hours and tried again but still nothing. PLEASE help - no 800 number in booklet for Akai
Sounds to me like something blew inside and you may need to get service. By the way, I need a manual for the Akai LCT701AD. Do you happen to have one in PDF. If anyone reading this has this manual or user guide, would you kindly email it to me at nrhs58@earthlink.net . Appreciate assistance.
Posted on Sep 05, 2007
Panasonic big screen TV will not turn on. I need to know what part to order
The power supply board is the most likely failure. What is the vintage of the TV?
It may be possible to repair the TV by replacing possible failed capacitors, or you could replace the entire board.
https://en.wikipedia.org/wiki/Capacitor_plague
Apr 28, 2016 | Panasonic Televison & Video
We heard a "pop" noise
The pop noise could be a capacitor poping its top up.This is a common problem to most TV sets today. Usually located at the power supply board.Once this parts give up it usually shorts the circuit and blows a fuse.Replacements of these parts mentioned will often remedy the problem.Flashing power indicators indicate a problem.If you have the chance of counting how many the blinks are I could have told you the problems code are and the source of the problem.
Dec 05, 2010 | Akai PT46DL10 46" HDTV-Ready Television
Tv was working went off LAMP flashing and would not come on.
Lets go back to the beginning... What were the original symptoms? Was it just the clicking or were the lights on the front of the set flashing too? With the new lamp, is there any thing else other than the clicking? If not, then the problem is likely to be the ballast. The clicking could be the lamp attempting to "fire". With a defective ballast, the lamp won't fire and the set won't come on. If you choose to replace the ballast, DO NOT use the old lamp. It is relatively common for a defective lamp to smoke the ballast under certain conditions. Also, it is possible that the original cause was the ballast that failed and took out the lamp with it.
Please keep us posted.
Thanks,
Dan
Jul 25, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
2005 52in Panasonic rear projection
Try either cleaning the filter.......or check the bulb.....it may need to be replaced.
Oct 26, 2008 | Televison & Video
Tv black, no sound
is there any led or small lights on front panel ... red green or flashing
Aug 08, 2008 | Toshiba 46H84 46" Rear Projection...
Sony bravia
what model of Sony is it? On many of the Sony projectors, a 3 flash error code indicates the lamp is not properly seated/installed or the lamp door is not closed properly
May 15, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Televison & Video Logo
120 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
