Question about Canon PIXMA iP4000 InkJet Photo Printer
Canon iP4000 prints lines
I recently put in new Canon ink cartridges to replace the empty ones. When I use the bottom feed for photo printing on glossy photo paper, the pictures have small lines across the image. I tried the cleaning, deep cleaning, and alignment options, but still have the same problem! Any advice?
    Sergeant:
  • Canon Expert
  • 394 Answers
It sounds like there is a blockage or junk sitting over one or more jets in the printhead.
https://www.youtube.com/watch?v=pEkKGBUSwNg
have a look at this u tube video and you may be able to fix it.
Posted on Feb 13, 2018
5 Suggested Answers
SOURCE:
SOURCE: Canon PIXMA iP4000 Will not print red Deep clean won t work Other colors OK
remove print head assembly. clean off.
print head not on cartridge.
Posted on Jun 21, 2008
whitebirch
  • 433 Answers
SOURCE: Pixma iP4000 pauses to dry colour printing.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
please go to the link above and enter the sentence below.
How do I change the time it takes for the ink to dry?
And it is very, very, interesting...you'll see.
Posted on May 15, 2009
whitebirch
  • 433 Answers
SOURCE: When I print photos, they have uniform vertical streaks.
Issue: Banded or streaked prints
Solution: Change the Print Quality Settings (Windows)
Change the Print Quality Settings (Windows) The Quality setting controls how finely ink droplets are placed on the printed page. Depending on the type of paper being used a higher Print Quality setting does not always insure a better print. Print speed will decrease as the Print Quality setting is increased. Follow the instructions below to change the print quality settings in the Canon printer driver for the Windows operating system through a printing application.
  1. Click 'Properties' in the Print dialog box.
    Note: Depending on the Application software, 'Properties' may be displayed as 'Preferences'.
  2. Set the desired print quality in the 'Print Quality' section.
  3. Select 'High', 'Standard', or 'Draft / Fast'.
To set more detailed print quality settings, follow this procedure:
  1. Select 'Custom' and click 'Set'.
  2. In the Set Print Quality dialog drag the slide bar from 'Fast' to 'Fine' to select the print quality.
    Note: There are five options in 'Quality'. However, selectable options are limited depending on the media type.
  3. Select 'Auto', 'Dither', or 'Diffusion' from the 'Halftoning' section.
komguy
  • 2306 Answers
SOURCE: Using a Canon pixma ip4000 and when printing
You need to replace the printhead, QY6-0049-000. They get plugged and cannot be cleaned. around $40.00
Posted on Jun 30, 2009
Canon Pixma IP4000 - Printer on/off button flashing orange light X 5 and then green. I have just re-newed all the ink cartridges Can you help ? will i be able to re-set printer ?
5 times orange means you need to replace the print head.....if the led are Blinking in Orange and Green Alternately you need to replace the sheet feed unit.
Mar 28, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Just put all new cartridges in my printer and it will not print. paper goes through like it is trying to print. help please
have you remove sticker from cartridges first...if paper is feeding well then that new cartridges is empty or u haven't remove cartridge stickers from cartridges
Oct 26, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Incomplete patchy printing
Please try to do a printer head cleaning. You can do it by getting a small earbud and soak it with a small amount of water. Or try to adjust it by doing an alignment. Usually, the printers have this functionality. Please refer to the user manual.
Aug 13, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Faint rainbow line of blue/orange/yellow at end of printed photo
You might try cleaning or unclogging the print head[s] with a drop of water or two onto the outlet from the print cartridge[s] and a drop of water or two onto the inlet orifice into which the outlet of the cartridge feeds the ink.
May 18, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Not understanding why there's two black ink cartridges
One tank is reserved for colour printing and the other one is for grayscale printing ( Black and white). Watch out as when you run out of ink and you keep trying to print a document with empty tank cartridge it will cause your print head to go bad. The cost of a new canon print head is the same as the cost of a new printer. Canon over priced the print head.
Nov 30, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon pixma mp210 and compatable ink cartridges
Try pushing the reset button for about 5 seconds. This has worked for me.
Oct 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Replaced empt 3E cartridge. Now it won't print
I had removed and reinstalled the empty 3e cartridge. Sorry for the Confusion. I hadn't put a new 3e cartrige in until today. Them I ran " deep clean" twice. The printer works fine. I still don't understand why the printer wouldn't print color, when I was had set the printer to print in color when my 3e cartridge was empty and all colors including the 6 black showed full.
Mar 31, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Printing Problem
Cleaning cycles use ink. So it's no wonder it got worse, the ink level went down. Are you 100% sure that the black cart is full? they can give a wrong reading on occasion. what makes you think its full? Could be also that you need to replace the head- the part the cart fits into. generally they don't last more than 18 months.] Another possibility is that the black is indeed full, but dry. Put a wet sponge to the nozzle, see if it soaks up a decent amount of ink. Good luck
Jun 06, 2006 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP4000 InkJet Photo Printer Logo
87 people viewed this question
Clive
Clive
old marine
old marine
Ekse
