Question about Carrier 38CKC036 Air Conditioner
Carrier air conditioner
I lost power to the unit. No circuit breakers were tripped. It is a hot day and it appeared the air conditioner wasn't cooling. The temperature on the control said 81 and the unit was set for 74 degrees. I tried moving the arrow up towards 81 degrees and as soon as it hit 81 with the indicator, all power shut off. I have no lights. How do I reset the A/C. I tried to reset the circuit breaker in my garage, but it did nothing. I also found a switch and circuit breaker in the closet where the unit is and it was indicating on and the circuit breaker does not appear to be blown. It is a Carrier heater/air conditioner. Do not know the model
  • inbegee Sep 06, 2007
    It turned out to be the tripped circuit breakers. I later discovered I had lost lights in my hall and laundry room. I had to turn off the main power to the house, then reset the circuit breakers after turning it back on. (I had reset the circuit breakers without turning off the circuit breaker to the whole house and this did not work.) Thanks for your assistance.
  • 1,420 Answers
Sounds like you either blew a transformer, have a bad circuit breaker or blew the main fuse in the outside disconnect. If the indoor unit is still blowing air (no matter what temperature) start looking at the power supply to the outdoor unit. From the circuit breaker, the power will go to a small box located within a few feet from the outside unit. This box will have either a lever on the side or you will be able to open the box and pull out the fuses. From this box the power goes to the condensor. The first thing you should do is to turn off the breaker to the outside unit. Flip it back on and if you have a call for cooling, after about 3 minutes the outdoor unit should start. If it does not, shut off power again to the unit by switching off the breaker, go outside and pull out the fuses in the disconnect box. Using a multi meter, check for continuity thru the fuses. If you have continuity, call your technician. If one or both fuses show no sign of continuity, replace the fuse(s). Make sure that the thermostat is working and sending a signal to the indoor air handler. You may be able to check this by turning the fan switch to "Fan" and see if the blower turns on. You may just have a bad thermostst. Caution should be used anytime you are near electrical components. If you do not have the skill-set required to test electrical equipment, leave it to a proffessional.
Posted on Sep 04, 2007
I have nothing on my thermostat. I was going to install a programable thermostat so I disconnect my old one. When I couldn't use the new one I reinstalled the old one and now it's like there is no power to it. Checked circuit breakers and found none tripped and tried thermostat in upstairs since I have two thermostats and it works fine there What next???
Posted on Jul 22, 2009
SOURCE:
I have a carrier air conditioner 38TKB024. About 15 years old I think. Accidentally ran it with the cover still on after the winter. shut it off after about a day when I realized. Went to try it the...
You probably just blew the fuses or tripped the circuit breakers. There may be fuse right beside the unit in a box with a door on it. The fuses will be in a cartridge inside the box. You will need to change them both unless you have a ohm meter to check them. Also check your circuit breakers. The will more than likely be in your main circuit box. It will be two joined together, probably 20a or 30a. Trip them all the way back and then forward and try the unit again.
Jun 11, 2011 | Carrier KCA101P Air Conditioner
My unit is tripping the main breaker what should i look at first
With this cold weather, -- it is not likely tripping off because it is too hot!
Are you familiar with the history of this unit?-- Like has it tripped in the past during HOT weather?
This might be a clue, that the circuit is really loaded close to its limit--
This leads to the next possibility: That the breaker is getting weak (They do after many hard starting loads!
Now-- If you can get the system to start and run for just a few seconds-- can you put a Clamp around Amp meter on the wires?-- and read the full load current?
How close is this to the rating of the circuit breaker?
Is the breaker, and the wire size marginal?
Another thing to look for, is loose lug screws at the main fuses, and the Main contactors, and the motor leads--- for loose wires result in overheating, which raises the current, and leads to tripping, too.
How long ago was the condenser cleaned-- this leads to high amp draw too.
But the first thing would be to learn more about the age of the Main Breaker, and what the 'normal' run current is for that system.
Mack B
Dec 28, 2010 | Carrier 38CKC036 Air Conditioner
ON excessively hot days, the outside heat pupmp trips the circuit breaker. Most times it is only once, I turn the breaker to "on" and it works fine. Some days it pops two or three times. When the outside...
Hello I would add a HARD START KIT to the run capasitor (if there is not one already).This makes the compressor come on easy.If the breaker trips during running time the pressures are too high,hose off the condenser coil (fins).The unit might be slightly overcharged but I would be careful before adjusting the freon at all.
Sep 02, 2010 | Carrier 38CKC036 Air Conditioner
I have a Carrier AC unit with a heat pump. I noticed that it wasn't cooling and the circuit breaker had tripped. When I reset the breaker and try to start it again, it trips againafter 10 seconds. The...
Check with your contractor to see if their repair is warrantied. If it is not call someone who carries a warranty and satisfaction guarantee on repairs. It is likely that you got a bad capacitor, however, this typically will not trip a breaker. It's possible that other issue(s) caused the capacitor failure.
How old is this unit?
Aug 26, 2010 | Carrier 38CKC060 Air Conditioner
Central AC unit replaced breaker trips after running 20min
Unit is drawing two may amps for the breaker. Could be compressor sticking.
Jul 22, 2009 | Weather King 10AJA6001AH Air Conditioner
Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 10, 2009 | Dometic Rooftop RV Air Conditioner
42 degrees outside and air conditioner is blowing hot air!!
turn the unit off at the main circuit breaker or isolating switch, to reset the unit it has tripped out on its high pressure safety. to stop this problem happening on 42 plus days hose down outdoor coil with water
Jan 29, 2009 | Heating & Cooling
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Carrier unit won't go on
It may have simply lost power. First try to check any receptacles, breakers and fuses before calling in a technician.
Jun 08, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier 38CKC036 Air Conditioner Logo
701 people viewed this question
Top Carrier Heating & Cooling Experts
Felizardo Erilla
Felizardo Erilla
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
