this is a standing vornado fan with full variable speed control. The blade assembly (looks like one piece) slides from one end to the other of the shaft about a 1/2 inch to an inch. More accurately put, the shaft slides in and out of the motor about that much. The fan always makes a vibrating noise unless tilted up so the fan blades are slid down towards the motor. Any suggestions on how to take out the slack or whatever the problem is?
Comments:
Sep 10, 2007
- Found another solution as Vornado does not sell parts. I used an external homemaid bushing to act as a spacer to prevent shaft from sliding in and out of motor.
on the inner part of the motor [fan side] look for an external snap ring and a fiber spacer. the armature fits all the way into the rear part of the housing, the other housing goes over the motor shaft and must press against the snap ring and fiber washer.
I have an older Vornado 280B (it looks just like the current 730 series with the small stand). I've...
(More)
I have an older Vornado 280B (it looks just like the current 730 series with the small stand). I've been able to remove the front grill & clean it and the blades, but now I'd like to remove the rear grill from the motor so I can clean the rear grill. How do I do this? Thanks!
I have a vornado fan on a pedistal that's about 13 years old. Have to twirl the blades manually to...
(More)
I have a vornado fan on a pedistal that's about 13 years old. Have to twirl the blades manually to get it to start. Acts like the blades bog down and won't turn after turning off the fan for the night. Have cleaned it but still won't start without spinning the blades manually. Do I need to oil the shaft or what?
