Question about Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television
Help i cant program the local channels.
  • elida Sep 03, 2007
    l can't program the local channels.
    i'm having trouble in programing the local channels on my Sylvainia
    6842-PEM 42.....if someone can please get back to me A.S.A.P and for an F.Y.I i do not have the manual.
  • 26 Answers
There should be a phone number in the label on the back for assistance in setup.
Posted on Oct 07, 2007
My new HCT LCD TV is not getting my local channels
if your tv is hooked up with cable program as a source their might be problem with the cable provider try to contact for if you just only using the areal antenna as a source try re orient first the proper position of the antenna to receive local channel. channel scan much better also either the manual search or through auto channel search . good luck hope this may help.
Jul 21, 2011 | Televison & Video
Does emerson model #20s5b have a switch to convert from cable to satilite?
It's in the channel programming menu. It should say, "Cable/Ant" or "Cable/Air" If you want a roof antenna with local channels, change it to "Air/Ant" Then click auto program with the antenna hooked to it to scan for free local channels.
Jun 16, 2011 | Emerson Televison & Video
How do u get box 2 program from 1 2 100 i can only get 12 channels
With a DTV Pal, once you scan for your local channels and add them to the receiver, those are the only channels you have available to view. The local channels available are dependent upon your distance from the broadcast towers. I hope this helps.
Ray Calo
DISH Network
May 31, 2010 | DISH Network DTVPal DVR by
Cant program chanels
Make sure that you are not scanning in cable mode, to get the local channels you will probably have to scan antenna, this will be in tuner set-up
Feb 21, 2010 | LG 42LC2D 42 in. LCD HDTV
How to program 50hm66 for cable tv
Are you hooked up to cable box or just straight cable line? You should be able to go into the menu, in setup, and auto program it in the cable mode.
Oct 13, 2009 | Televison & Video
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Can't get the tv to move from the cable mode
Wondering if this is what your asking about, I cant find reference to Cable only mode...
Indicates that all channels are locked except the selected channel.
The following complaints may be generated due to locked channels:
- TV cannot be switched on from standby with the local keyboard buttons.
- “CH+” and “CH-“ buttons on local keyboard do not function.
To disable the LOCK feature:
Select ”FEATURE” menu (with the Remote Control).
Select “LOCK” (with the Remote Control).
Set to “OFF”
Aug 18, 2008 | Philips Magnavox 51MP392H Rear Projection...
Sanyo DS31350 31" TV problem
you need to buy the sanyo remote from
Dec 14, 2007 | Sanyo DS31590 31" TV
Cant get local channels
If you can manually tune to the channels with no problem, then I would go in and add then into memory manually. If not then exchange the set as it might have a bad tuner or an AGC (automatic gain control) issue.
Apr 18, 2007 | Sharp 25H-M60 TV
Sylvania 6842-PEM 42 in. EDTV-Ready Plasma Television Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
