Question about Whirlpool 26.6 cu. ft. Side-by-Side Refrigerator ED27PQXF
Squeeled, then hot on exterior
My refrigerator made a squeeling sound, coming from the freezer side, about mid-way between the top and bottom. I turned off the ice maker and after awhile it stopped squeeling. After a few hours, we noticed that the side of the refrigerator at about the same spot is hot on the exterior. The gasket is warm on the refrigerator part too, at about the same height. Any help?
  • 290 Answers
If you are getting heat around doors, You need to check the condensor fan. Remove toe panel and you should feel air blowing out. Clean the condensor coils if they are clogged. If you don't feel air coming out, pull unit out and remove back cover. You will see the fan that keeps the compressor and condensor cool. It should be running any time the compressor is running.
Posted on Oct 03, 2007
  • Anonymous Oct 17, 2007
    Just wanted to follow up on your refrigerator and see what you found.
    Thanks/Mike
  • 291 Answers
Normally squeeling sounds from the freezer is evapurators fan motors... need to pull back panel off freezer and check out fan motor
Posted on Sep 03, 2007
SOURCE:
My Whirlpool side-by-side refrigerator/freezer (Model # ED5PHAXSQ00) has power and lights but will not cool or freeze.
Replace the main control board located on the left rear mid side.you can get the board from a local appliances parts store. They will need the model and sereal numbers
May 15, 2016 | Whirlpool Refrigerators
Hot on top, cold on the bottom on both sides
Mine did the same thing and the circuit board that controls the fans had gone bad . It could be that or the fan itself.
Jun 06, 2012 | GE GSL25JFPBS Side by Side Refrigerator
Freezer has warm spots. All around freezer is hot to the touch. Compressor is hot, coils are clean, condensor fan is running.
Thats normal.
The condenser coils are located just inside of your exterior cabinet walls on the sides and top.
So the freezer gets cold inside and heat has to be released from the condenser coils.
If this is something new, you may have a problem with the defrost timer
Sep 11, 2011 | Kenmore Side by Side Refrigerator
Fridge part of product is not working
i have a admiral serial # 1142843us, model # hmg211771. freezer at top freezes. hot at bottom. motor sound like it roars. frost inside frrezer at top.
Apr 09, 2009 | Refrigerators
WHIRLPOOL TOP FREEZER ET1WTKXKQ01. NOT COLD ENOUGH
You need to look inside the freezer at the rear wall cover and see if it is frosted over. If your refrigerator is not defrosting that can cause the refrigerator side and the freezer side also not to cool to the desired temp.
Mar 30, 2009 | Whirlpool ET1WTKX Top Freezer Refrigerator
We have a whirlpool freezer on top but the bottom of the fridge is freezing
Set both freezer and fresh food controls to their mid position.
If after 24 hours the temp is still too cold replace the thermostat aka cold control.
Feb 21, 2009 | Whirlpool ED2FHEXN Side by Side...
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Side by side refrig, exterior walls of freezer are suddenly hot to the touch
Your subject line was too long; 'exterior walls of freezer are . . .' ??
Apr 28, 2008 | Whirlpool GS6SHEXNL Side by Side...
Ge after replace fan still fan not working
Something to check for. Is the top of the refrigerator door lower than the freezer door? If so the ref. light may not be turning off all the time. Pull bottom panel off to expose hinges. The ref hinge should have an adjuster. Adjust door up to be level with freezer.
Aug 03, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
128 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
