You CAN you your X4270 with your mac, its just a bit of work.
You may need to download the gutenprint/gimp drivers and install them. Which you can find at this link:
http://downloads.sourceforge.net/sourceforge/gimp-print/gutenprint-5.2.4-rc1.dmg?use_mirror=superb-west
Once these are installed, do the following:
Before attempting this, ensure that your X4270 is plugged into your Mac and powered on.
1: Open "System Preferences" under the Apple menu in the upper left corner.
2: Click on "Print & Fax"
3: Click the "+" to add a printer
4: "Lexmark 4200 Series" should show up under the default tad of add printer, select it by single clicking.
5: If you wish you can change the name and give a location below
6: Where it says "Print using:", select: "Select a driver to use" This will bring up a list of printers
7: Search or scroll until you find "Lexmark Z43-CUPS+GutenPrint", select this by single clicking.
8: Press the "Add" button at the bottom and you should be done, if may
ask you to step through a few more things, but it will be trivial.
Please note that this is not a perfect solution. I seem to have to
print one page at a time, which is a pain, but at least I didn't have
to buy a new printer. This could be a problem with my printer only, or
it might just be a setting that I haven't found yet, so look around see
if you can find it.
Also, you will not be able to use the scanner on your mac as far as I can tell, and I don't remember if the copy/fax works.
What operating system are you using?
