Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Washing machine - door problem
When i load the machine and shut the door I select the cycle and press start. The machine keeps beeping and the display says "door open" - the door is not open!
  • vert75 Sep 03, 2007
    thanks - the problem is no one in New Zealand seems to know hotpoint appliances so I am a bit stuck on parts!!
It sounds like door mechanisim has fallen off.remove the top of washer/dryer and look down the front to where the door catch shuts and see if there is anything attached to it.if not your have to reconnect it.Let me know and ill give ya more details
Posted on Oct 13, 2007
  • 291 Answers
It maybe a bad door switch the program maybe picking it up as a door open
Posted on Sep 03, 2007
  • Mike Johnson
    Mike Johnson Sep 03, 2007
    wow guess shipping from the U.S. would be like buying a new appliance... Good luck
SOURCE:
Electrolux ewf1074
check the micro switch on the door
Jan 24, 2014 | Washing Machines
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
GE WCVH6800 Pressing start results in two short beeps. The pause/start button keeps blinking and it will not start a cycle.
Is the door lock button on, but the door not actually locked? Our door lock switch keeps going out. We have replaced it 4 times in the last 3 years.
Jan 16, 2011 | GE WSXH208A Front Load Washer
Cycle starts but shuts off. timer keeps running. when we press option select we get LOC. when we hold start/cancel button we get 5 beeps and ESE
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 14, 2010 | Frigidaire GLTF2940ES Front Load Washer
END OF CYCLE KEEPS BEEPING WHILE WASHING
Maybe the machine is telling you that your load is uneven, When going through a spin cycle it will detect if the load is too heavy on one side. Just open the door and spread the load evenly. good luck.
Jan 26, 2009 | Whirlpool LHW0050PQ Front Load Washer
Won't Start - Beep-beep-beep
unplug it then plug it back in to see if it helps
Jan 16, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cannot get washer door to open.
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Annoying beep when wash cycle finishes on bosch classixx 1400 express
Starting with the rotary switch in the off position, turn it one click clockwise, press and hold on the bottom right hand button, turn the rotary switch one more click CW and release the button. The number displayed is the volume for button presses, press the centre right hand button to increase/turn off (0). Turn the rotary switch one more click CW to select end of cycle volume, agjust and set the rotary switch to off to leave set up mode.
Dec 06, 2008 | Washing Machines
Whirlpool Duet washing machine will not start a cycle.
sounds as if its a door latch/lock issue, not recognizing the door closed will simply beep 3 times when the start button is depressed. try unplugging and replugging after 2 min.
Nov 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
295 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
