FixYa.com
Tags:
MagLite - Mag Charger System 110v  Model - RX1019
Frozen tail cap
posted by sragni on Sep 03, 2007
Tail cap is frozen and will not turn. Have tried pliers, rubber jar turner. It won't move.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 23, 2007
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Sprayed penetrating oil all the way around the end cap at seal area. Layed flashlight on it's side on a plastic block & tapped on housing just below the end cap with composite mallet while rotating. Then used aluminum jaws in a vise to hold housing while turning end cap with large pliers.
Once cap is off, clean corrosion with automotive battery cleaner & soak inside with more penetrating oil to remove batteries.
Tonka Roy at Rosell Infiniti
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Tools and Hardware problems?
Tools and Hardware
Electric Ryobi String Trimmer
Where can I find a Repairman? Answer This...
Tools and Hardware
crosman 760
i need a clear diagram on how... Answer This...
MagLite - Mag Charger System 110v (M) Model -...
charger is not working
dear sir my maglite cradle... Answer This...
Mag lite
I have corroded batteries in a... Answer This...
Rechargeable maglite
Light comes on in vehicles... Answer This...
Repair Service
Find Tool and Hardware Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
