Question about Samsung 94V 19 inch LCD Monitor
Unable to select the correct screen resolution with GeForce 6150
I have Vista Home Premium (italian) and a GeForce 6150LE, embedded with an Asus M2NPV-VM motherboard (nForce 410). My problem is that when I try to use *ANY* driver different than the original Vista WDDM driver (7.14.10.9686), with my Samsung 94V monitor, I can't select any different resolution from 800x600 or 1024x768. The native resolution of my monitor should be 1280x1024. I've installed the latest fix from Windows Update and also the Compatibility patch. I tired to force Windows to use 1280x1024 resolution by changing the system registery but i had no chance... What can I do?
SOURCE:
fossilruins
  • 114 Answers
SOURCE: New Samsung 245/bw monitor w/native resolution of 1920x1200
Ensure that your video setting is at 60hz when at 1920x1200. According to the specs of your monitor, the freq from the video card might be set to something higher.
Posted on Jun 08, 2008
volto
  • 101 Answers
SOURCE: Samsung SyncMaster 915N monitor
Go into advanced settings from the settings tab of "display properties" and select the "monitor" tab, from there, try changing the refresh rate. Toggle "hide modes that this monitor cannot display" if you do not see any other settings in the drop down other than the one that is already selected.
Posted on Jul 16, 2008
  • 1738 Answers
SOURCE: Screen is totally blurry and almost unreadable,
Yes, try going back to windows xp and if you have the DVI port on your video card, try that.
Posted on Nov 15, 2009
  • 561 Answers
SOURCE: Resolution Issue
Hi
Thank you for your query
Please can you advise what graphics card you have, as i dont think you have the latest drivers for it
Posted on Feb 19, 2010
  • 109 Answers
SOURCE: Screen resolution problems since installing latest drivers.
try to revert back to your old nvidia driver, if it works, the latest driver does not support your syncmaster, contact nvidia or samsung..
Posted on May 10, 2010
Nvidia geforce 6100 nforce 405 if i can enable the nvidia it becomes HIGH FREQUENCY in monitor but if can disable its use properly but i can play the games i want.. how to solve this problem?..
dude its prety easy go to control pannel detect the nvidiacontroler there
go to its properties and reduce the frequency to as of the monitor its better make it 60mhz that normally works
Feb 03, 2010 | AMD Asus A8N-VM Dual-Core nVidia GeForce...
Need drivers for dis motherboard m2npv-vm for network conection
You can download the drivers for this MOBO from this link http://support.asus.com/download/download.aspx?modelname=M2NPV-VM&SLanguage=en-us
Jun 14, 2009 | ASUS MOTHERBOARD M2NPV-VM SOCKET AM2 NVI...
I have internet connection but i couldn't connect to that.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2NPV-VM
This is the driver page for Vista 32 bit, you can change the OS if yours is different, towards the top of the page, it sounds like you need the chipset driver for your Board, but this is the manufacturers URL
Mar 25, 2009 | ASUS M2NPV-VM Motherboard
Latest drivers
http://www.driverstock.com/ASUS-M2NPV-VM-driver-download/6-9-10277/index.html
thie above site should have the drivers copy paste into address bar check driver suitable download
Jul 09, 2008 | ASUS M2NPV-VM Motherboard
M2npv-vm motherboard
The board is a mini-ATX board. As such the ASUS M2NPV-VM board is able to fit into any mini-ATX case or bigger.
uATX Form Factor, 9.6" x 9.6" (24.5cm x 24.5cm)
Jan 08, 2008 | ASUS M2NPV-VM Motherboard
IDE ports in asus m2npv-vm & m2n-mx motherboards
hi, i have a couple of those boards. they have 2 ide ports on them and 4 serial ports. if youu do get the m2npv-vm, one thing that is weird about it, one faces up from the board and the other lays flat off the edge. also the ports are right next to each other and the polarity (which side you put the ribbon cable stripe on) is opposite each other. so if you don't use a keyed ribbon cable you might hook them up wrong.
Aug 22, 2007 | ASUS M2NPV-VM Motherboard
Samsung 94V 19 inch LCD Monitor Logo
Top Samsung Computers & Internet Experts
Ekse
asber
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
