Question about Garmin Nuvi 660 GPS Receiver
Vehicle icon tracking on route
The vehicle icon does not track the route on screen,,,it is far left or far right never down the center of the proposed route therefore it is continuelly reculating route....plaese help me with this
  • 174 Answers
Under settings, Navigation, verify that Vehicle is set to Car/Motorcycle.
Posted on Jan 31, 2008
SOURCE:
When steering is centered the left wheel is out to the left and the right is straight
Unless you have had an accident or Kerbed the wheel it is probably your tracking is out/ track rod end loose!
Sep 10, 2015 | Cars & Trucks
E44 on left screen, 123 on right screen of ironman 150t teadmill
I am trying to track down a similar solution, with no luck so far. I will keep you posted. Am trying to clear a message regarding perform maintenance. The machine will not run at all.
Feb 28, 2014 | Ironman 150t Incline Motor
Wiring 1122 switches for crossover
Question is unclear. But if you want both switches to throw at the same time all you need to do is connect the 3 terminals on one switch with the matching terminals on the other switch. Run a wire from left to left, center to center and right to right. If the switches do not switch into the same track just reverse the right and left wires on one of the switches.
Nov 27, 2013 | Lionel 40 Watt Transformer Train Set Track...
Thomas the train misty island deluxe set instructions
Starting at the wood cut tower moving clockwise. Tower is 6. 6 to 7 to 8, L2, 9, L4,10,L5,11,fits into tree trunk, 14, (12 connects to the junction) 1, 2, (joins to 13 from the log over.) L5, 3, L4, 4, L4, 5, connects to 6, the tree tower.
The logging tower rails. Connects from 4 to 18, then the tall tower, the rail, the small tower, 17, L2, 16, L4, 15, the tall tree tower, 14, L4, 13 and that connects to No. 2.
L2 is the lowest support. L4 is the middle size. L5 is the tallest.
Nov 28, 2010 | Toys
Records & shows only sound in the left or right side per track.Help? Adobe only records the left or the right side per track.How do i get it to record both sides per track.This is a nightmare for...
right next to the track u just recorded like to the left should be a box that says In 1L.. press it and on the left of the new screen fill in LEFT CHANNEL .... 16 BITS.... SAME FOR ALL TRACKS
Sep 17, 2010 | Adobe Audition 1.5
The track is off to the side about an inch or little more how do i straighten it back out?
Centering the belt.Tension adjusters are at the front of the track( as you get on)
If the belt is to far to the right ,use an allen key, or the allen wrench that should have been supplied, in the right hand side tension bolt and turn it clock wise 1/4 of a turn at a time until the belt runs and remains in the center. And if its the left hand side turn the left hand tensioner bolt 1/4of a turn clock wise until it runs in the center.
Feb 15, 2010 | Icon Image 17.5 S Treadmill
The address icon does not initiate on the home screen. However, I can access a contact database in the search mode.When the track ball is depress nothing happens over the contact icon.
Try going into your applications screen, Which can also be the home screen if you have your theme set for it. Try clicking on your blackberry button, the one to the left of your trackball, which will bring up a small menu, scroll to show all and click your track ball. Then you need to find the address book icon and click your blackberry button. If hide is checked in the menu uncheck it by clicking your track ball again. This should unhide it and make it available on your screen again.
Mar 30, 2009 | Verizon Communications BlackBerry Pearl...
Locked out of vehicle Broke out sliding center section
Put the top part first, and the lift it until you can put the lower part in and lower it.
Mar 29, 2009 | 2005 Dodge Ram 2500 Truck
SD Card slot Garmin nuvii 260
I have found that waypoints, routes and directions work only when I load it on the unit itself as opposed to the SD card. The SD card works more like an expansion slot for pictures or maps.
When you open up Mapsource you'll see the map on the right and the pane on the left, above the pane there are 4 tabs (Maps, Waypoints, Routes and Tracks). As you select a map or create a waypoint, route or track. It will put a number in parenthesis which will increase in numbers as you add an item corresponding to each category, for example if you create a waypoint. So once you have done that, click on the TRANSFER tab in the Menu selection bar and choose SEND TO DEVICE. A window will pop up that will say...Device: with a drop down menu if your Garmin unit has an SD card in it, if not it will just show the Garmin unit. Then right below that there will be a section that says WHAT TO SEND with 4 check boxes that will say Maps, Waypoints, Routes and Tracks. Make sure that you have selected the Garmin unit, not the SD, and the waypoints, routes or tracks you want to send. I hope this solves your problem or at least points you in the right direction...
Jun 20, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
80 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
