Question about RCA F19436 19" TV
Sparking rabbit ears
While adjusting the "rabbit ears" on the TV one of them touched a floor lamp. The lamp wasn't on, but it's a 3-wire lamp so its exterior is grounded; there was a brief spark and the TV quit. I took the back off the TV and replaced the fuse on the PCB; unfortunately, there must be a bigger problem because the new fuse blew immediately as soon as I pushed the power button.
  • 398 Answers
If the fuse blows the instant the power is switched on, there is most likely a heavy short in the primary side of the power supply. This could be the rectifier diodes or the switching transistor (or IC). If you do not have experience identifying and replacing shorted semiconductors, allow a qualified tech to handle it for you.
Posted on Sep 03, 2007
SOURCE:
How to tune in channels.
Very few TVs have built in antennas (used to be called Rabbit Ears) in this HDTV era. The exception is portable hand hold units. You can experiment with the set by taking a 1-2 foot long piece of bell wire - strip about 1/2 inch of one end and put it in the center conductor of the antenna jack. If you are in a metro area, you will likely scan and get several channels (I get over 20) but you are better to get an amplified portable antenna or better yet, something you can place outdoors. Reception better near windows and upper floors.
Mar 03, 2018 | Computers & Internet
How do you connect rabbit ears to a tv
First you may need a 300 ohm to 75 ohm transformer if you have a flat wire with 2 leads coming out of the rabbit ears..you can get one at walmart, I attached a picture of what they look like...hook the 2 terminals from the rabbit ears to the transformer and plug it into the round terminal of the tv, set the tv to cable or antenna, what ever it has for settings, unfortunately though you may not get all that much with old rabbit ears as they are lower frequency pickup than the new HD channels run on.
aceb6079-dc98-4da7-926e-7d52885feaff_1.13301fb611a36dff57b92b05b4fdcbd5-j2qglkibcccvgpapoz0ib4qd-2-0.jpeg
Nov 08, 2017 | Televison & Video
No reception with rabbit ears
Check to see if you have the "Rabbit ears" plugged into the correct spot and you are on "Analog tv" if you are trying to use digital tv on "Rabbit ears" it can't send out a strong signal like the areal ontop of a house. You may need to get an adapter to broadcast a stronger signal but even better if you can connect to roof antena.
Oct 24, 2012 | Panasonic TH-42PX6U Plasma TV
Want to set this up without cable. Someone told me to go to "air" mode and add rabbit ears and this will work. I cannot find an air mode on this tv. How do you set this one up with rabbit...
You will once again, purchase a converter box to receive an over the air channel. I don't think you will have to really worry about using an over the air mode on the TV. It may be in the menu, but will work otherwise after being placed on channel 3 to receive through the converter box. The rabbit ears will be connected to the converter box itself.
Feb 13, 2011 | Televison & Video
Hi. My name is Nivardo, I’m from México and
In the base of the lamp, cut the 2 wires coming in from the wall.
On one wire from the wall, connect it to the same wire going to the lamp (white wire, if you can tell which is which), AND the white wire from the Zing Ear (3 wires connected together).
For the other wire from the wall, connect it to the BLACK wire from the Zing Ear.
For the remaining wire to the lamp, connect it to the RED wire from the Zing Ear.
You also need to fasten the "TOUCH" wire from the zing ear to the frame of the lamp -- the metal part where you would touch the lamp.
That should do it.
Jun 11, 2017 | Hampton Bay 52 In.Carriage House II in...
Have a Magnavox TV , Rabbit ears
You may have to try a different universal remote control.
Jan 20, 2018 | RCA 3-Device Universal Remote
Digital Converter connection with old Rabbit Ears TV
First, make sure your connections are right. The rabbit ears need to be disconnected from the TV and reconnected to the converter box. Then the output cable from the converter box connects to the TV. Then try turning the rabbit ears or re-locating them near a window if the wire is long enough. You should be able to get some signal. A newer indoor antenna may help you pull in some of the weaker stations.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
We have a new HDLCDVD220 Sansui television. The rabbit ears antennae we were using on our old tv worked ok, but on this one. its awful. There is almost no color and terrible reception. We were told to get...
You mentioned rabbit ears for old tv, how old are the rabbit ears? Time and humidity will make rabbit ears lose connections internally. Also, if your old rabbit ears have the flat cable going to the tv you probably had to add a converter to go to the new tv. The flat cable will lose signal strength were ever the cable touches metal. Also the adapter will cause signal lose. The best bet is to buy an amplified indoor antenna. You also may try a paper clip and about 3to4' of small gauge wire put the paper clip (bend out to fit) into the center of the antenna in on the tv have the wire connected and let it hang or lift it to see how the picture improves. The problem with rabbit ears is that you have to use war time tactics. Crawl on your stomach and adjust to best picture, if you stand and adjust the signal is usually reflected off your body and will be nice until you walk away.
Jan 28, 2009 | Sansui HDLCDVD220 22 in. LCD TV TV/DVD...
Rabbit ears to digital conversion box
Your TV is old enough to have not only screw terminals for the antenna, but it sounds like it has separate UHF and VHF terminals as well. Pick up a 75-ohm to 300-ohm adapter (available at Radio Shack and probably most other places that sell TV's and antennas). This is a small cylinder-shaped part with a threaded antenna connector on one end, and a flat wire with two terminals on the other end. Connect the cable from the converter box to the round connector, hook the two terminals to the VHF antenna screws on your TV, put the TV on channel 3 and you'll be set.
You should also pick up a new antenna designed to work with digital broadcasting. If you use the old rabbit ears you were using before, you will probably not pick up all the channels available in your area.
Oct 31, 2008 | GE 35GT740 35" TV
TV won't work with rabbit ears
You must change the input on the system to be AIR/Antenna , the way it was before was set to cable/dish/DTV.
The tv sees the input different.
Jun 05, 2008 | Philips Magnavox 51MP392H Rear Projection...
RCA F19436 19" TV Logo
54 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
