Question about Canon BubbleJet i560 InkJet Printer
Canon i560 --No color!
I just replaced the color catridges in my Canon i560, but when I tried to print out a color photo, no color came through. The cartrdges were prepared and inserted correctly, and the ink seems fresh. Any answers to this problem? Thanks.
    President:
  • Canon Master
  • 2,022 Answers
See you removed the seal of catridge nozzel like stiker of catridge and also check whethre your pring mode is color not a grayscal. bye
Posted on Sep 22, 2007
SOURCE:
My ink cartridge is stuck. I tried to turn it off and on again and to push the paper leveler down but nothing helps.
My Canon Selphy CP740 start to jam ink ribbon and ink - Fixya
www.fixya.com/support/t10013530-canon_selphy_cp740_start
Jan 4, 2013 - My Canon Selphy CP740 start to jam ink ribbon and ink cartridge is blocked and cann't be removed from printers. ... Question about Canon SELPHYCP740 InkJet Photo Printer .... SOURCE: CP760 SELPHY CP760 COMPACT PHOTO PRINTER Thermal: ink cassette stuck in the canon selphy printer CP7.
Selphy CP740 - Catridge Eject Solution - YouTube
? 0:46
https://www.youtube.com/watch?v=9TqHINBmbgQ
Sep 11, 2013 - Uploaded by Mahadhir Shaarani
Selphy CP740 - Catridge Eject Solution. Mahadhir Shaarani ...Replacing Ink for Canon Selphy - Duration: 6:23. Jenuine Crafts... How to Print Different Sizes with the Canon Selphy Printer - Duration: 12:08. Janet Wakeland ...
Color ink cassette stuck in canon selphy 'Canon SELPHY ...
Feb 03, 2016 | Canon Selphy Cp800 Compact Photo Printer -...
My i560 Canon printer prints all colors but not the black ink
after a month of not using the printer, most probably the print head is clogged.. try using the printer utility to clean the print head.. it's under the printer properties.. normally that should resolve the print missing issue...unless your print head is really clogged up...
some would suggest to partial soak the print head onto warm water..but it doesn't work everytime..
May 24, 2010 | Canon BubbleJet i560 InkJet Printer
The canon i560 does not print at all eventhough the ink catridges are full and new. we have cleaned it and stil nothing is shown on paper. could you help?
You either have a bad printhead or purge resevoir.
Can you take out the head and see if there are any colors coming through?
If not remove the inkand head and try to take a solution of 15-20% ammomia and warm water to soak the head to cover the ink inlets.
Let sit for 45-60 minutes and clean all the moisture from the electrical contacts and re-install.Run a nozzle check by holding the resume button until it flashes twice.
If you are now getting some ink out the head is still clogged reclean with a little stronger solution and warmer water.
If not satisfied with the nozzle check then you need a new head or printer.
Jul 21, 2009 | Canon BubbleJet i560 InkJet Printer
Quality of colour
hi! there, well in connection to your poor printed color there posibility that ink was insufficient to distribute to you photo to print try to visit your ink status, black color is sepated to 3 color catridge.if there's a insufficient ink in catridge,replace or refill any thing as long there is much ink in your catridge,if ok and print still not good,try to clean your printer headdont use any thing to clean your printer herad,the printer will clean your printer head,on maitenance menu,click clean,try several time,also try to align your printer head,click aligned,t check the pattern of your printer,click pattern test.if ok try toprint if the color print is balance,try to print.check the preview before you print adjust the quality color as in yout tate before printing.regards and have a nice day.
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Green hue to photos
Canon, in its infinite wisdom, markets two sets of inks with the "part" number 3e. One of these, labeled simply with the color, is suitable for the i560 printer. The newer inks, labeled as "Photo" + the color, are not. Silly me. I just looked at the number and bought the wrong stuff.
Apr 24, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Apr 16, 2008 | Canon BubbleJet i560 InkJet Printer
Won't print black text
dear
it isalways header printing problem or some time ,checkcatridge assembly stacking or not if stacking replace,or catridge ink flow late,means in between catridge and printing head,conduct with paper. replace head assembly.
by.by
Jan 10, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon BubbleJet i560 InkJet Printer Logo
151 people viewed this question
Clive
Clive
old marine
old marine
Ekse
