Question about Sungale Progressive Scan 5.1 Channel DVD Player
Removing parental control code
We just purchased this DVD player used and it has a parental control code. How do we remove it? We did not get an owner's manual. Also, do you have owner's manuals to download?
  • 944 Answers
Do you have a model number? here is the link for Sungale support contact; http://www.sungale.com/contact.asp and here for their DVD player support page; http://www.sungale.com/product.asp?anid=64 If you get no luck there then please post back with a model number and I will search elsewhere for you. awaiting your info :)
Posted on Sep 03, 2007
SOURCE:
Purchased the pink Disney Princess DVD player from KMart. When you turn it on and insert a DVD to play, screen comes up saying the Parental Controls have been set (Universal Studios picture in upper left...
lots of electrical items will use a default security code of 0000 or 1234.
if there is nothing in the manual and these codes do not work, then your best option would be to return it to the store for them to find the codes or refund/refpace the item
Feb 28, 2011 | Disney Princess MCP DVD2050P DVD Player
My Memorex 2040 dvd player gives "error parental" when I try to play a dvd. Any idea what this is or how to fix?
The Parental controls for your DVD player has been turned on. The default setting for most Parental Control setup is G rating meaning that anything above a G rating will not play unless the override code is entered. I was unable to locate a copy of your manual, but if you look in your copy for a heading called Parental Controls, it should explain to you what has to be done to either change the rating or remove the control altogether. Unless you have small children that may use your player you can probably remove the controls altogether. Normally you would have to go into your Setup menu, and then look for Parental Controls in that menu. Unless someone setup a code, you should be able to go in and just turn it off. If there has been a code applied and you are unable to find out what it is you will have to contact Memorex support to find out how to remove it. To ensure that it doesn't get turned back on you might want to hide your remote, as you need to use it to turn the feature on and off.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 16, 2011 | Memorex MVD2040 DVD Player
I tried putting a new DVD into my player ( Kenwood DVF-3080) It's asking me for Parental Control Limit code. I've never set parental controls due to the fact that I have no children. Other DVD's play...
If all the other DVD s you have work fine it could be misreading the DVD try fully RESETTING the power to the DVD Player by removing the power plug from the Wall, if the problem is still there and all the other DVD s you have work just fine then the problem is with that one DVD you have let me know if you need any more help.
Jan 23, 2011 | Kenwood DVF-3080 DVD Player
I purchased my playstation 2 used and the date/time are wrong and I would like to turn off the parental controls as well. How should I go about doing this?
Hi, here is the master code for the ps2 parental control follow the instructions below very carefully and this will remove the parental controls ok
1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
let me know if it dont work or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Sep 19, 2010 | Video Game Consoles & Games
JVC XV-M555 DVD player has the parental control set somehow. Need to know how to disable the parental control on this DVD player
Found the manual for the player buried in a box from moving. Procedure is
1) With no DVD in player
2) Press enter while holding down shift to display parental lock menu
3) If you dont remember the password enter 8888 to access the options
4) Use cursor to move arrow to country code option
5) Use right cursor to select country code, then down cursor to move country code to US
6) Use left cursor and down cursor and right cursor to move to set level
7) Use down cursor to toggle through level options. (None removes all blocks)
8) If setting a level toggle down to password and set new 4 digit password.
Jan 01, 2010 | JVC XV-M555 Multi-disc DVD Player
Parent control lock
The parent control lock out code is 1234, you need to press yes then enter the code using the remote type in 1234 then press play button again and it unlocks the parent controls!
Jul 07, 2008 | Disney Princess DVD Player
Parental reset code
Salutations ebarton,
According to the owners manual you should be able to reset your parental control code by using "0711".
If you would like to read the manual you can also find it at Magnovox's support website at:
http://www.m4c.magnavox.com/files/t/ts2746c/ts2746c_dfu_aen.pdf
Happy Channel Surfing.
Jon
Go Ahead. Use Us.
May 20, 2008 | Norcent Technologies DP313 DVD Player
Unlocking parental code
Preset to: 8888
Don't know the customer service #, Sorry.
Jan 26, 2008 | Protron PDV-288 7" LCD Portable DVD Player
Having a problem with my car DVD player
try this code 3308 that worked for me.
Mar 04, 2007 | Farenheit DVD34 Car DVD Player
Farenheit DVD34 Car DVD Player parental control
in the preferences menu - password try 3308. this worked for me. then rest the password to 1234. good luck
Televison & Video Logo
165 people viewed this question
Top Sungale Televison & Video Experts
janman
Argospete
Argospete
Are you a Sungale Televison and Video Expert? Answer questions, earn points and help others
