Question about FIC FR33E Motherboard
Fr33e motherboard I need to see where the wires go, the 2 wire sets that go from the tower to the board, the power, reset, harddrive.etc...
  • 2 more comments
  • cagemed Sep 03, 2007
    no on the plugs, i have 22
    ITS A FR33E BOARD.
    NOTHING IS HAPPENING, COMPUTER IS RUNNING, BUT NO MONITOR. MAYBE A FRIED BOARD / BUT I NEED TO HOOK UP YHE LITTLE WIRES TO FIND OUT, THANKS DENNY
  • docmorbid666 Jul 15, 2008
    the motherboard that i have has a 20 pin hook up which are ten on top three space and six on bottom can you give the schematic for that?
  • Anonymous Jul 15, 2008
    i have the motherboard that has 20 pins for tower buttons 10 on top and 3 then a space and 6 on bottomcan you give me the schematic?
  • malky_b Sep 16, 2008
    trying to add extra usb"s dont know wiring for 9pin anyone help appreciate it thanx in advance
    President:
  • 317 Answers
You should have a plug like this: ::::. Upper 1&2 - Power/sleep LED Lower 1&2 - HDD LED Upper 3&4 - PWR Button Lower 3&4 - Reset
Posted on Sep 03, 2007
  • Peter Burns Sep 03, 2007
    I might be more willing to continue helping you if you wouldn't have given me a "not helpful" rating right away. I probably have the manual for your board, but I'm not going to bother looking for it now. Don't expect anyone else to help you on here either.
  • Peter Burns Oct 11, 2007
    When troubleshooting a problem, it's common to try different solutions.
    Why rate me as not helpful so quickly? Don't you want to try other
    solutions that I have for you?
    Problem Solver:
  • 11 Answers
If you told us what type of board it was we could problably help you better
Posted on Dec 11, 2007
Colored ribbons on motherboard and correct ports
Helps if you post the motherboard manufacturer name, and model number.
OR;
Post the computer manufacturer name, and model number.
This is found on the back of a Desktop PC, next to the Windows product key; or up on the side of the computer tower.
Color of the cables ('ribbons') doesn't matter.
WHAT they are does.
NOW.........I can guide you with plugging in power cables FROM the Power Supply, TO motherboard. Also the different peripherals the power cables plug into. (Harddrive, optical drive, fans, etc)
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front panel go to; is the Front Panel header.
(Power On switch, Power On LED light, Harddrive LED light, Reset switch, etc)
I MAY be able to give you a Front panel header pinout.
We will see about Front USB ports, Front Audio ports, Card Reader, etc.
I CANNOT give you the color code of the wires, coming FROM the Front Panel, TO the Front Panel header.
I CAN give you info on how to find out what each one is, though.
Post in a Comment.
Regards,
joecoolvette
Feb 16, 2013 | Computers & Internet
I am looking for MCP61PM-HM (Nettle) 9 pin front panel power header diagram
This motherboard Adam?
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c00906137
Can't help you.
OH, I'm just KIDDING!
The area of pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
On the motherboard the Front Panel header is marked as PANEL1.
Scroll the page down, until you come to Motherboard layout.
Click on the + sign to the left of it.
Shows an illustration of the motherboard.
Bottom/Right corner is PANEL1. The black rectangle that is sitting vertically, in the motherboard photo.
Motherboard installed in computer case, the Front Panel header is two columns of contact pins.
FOUR on the Right side, FIVE on the Left side.
I don't know the actual numbering of the pins, so I'm going to number them myself;
Starting on the Left side at the Top, going down,
Pins 1, 3, 5, 7, and 9.
Starting on the Right side at the Top, going down,
Pins 2, 4, 6, and 8. There is NO Pin 10.
A) Pins 1 and 3 are for the HarDDrive activity LED (Light)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used. If not, do not connect to them.
C) Pin 9 is N/C. Not Connected. It was a +5 Volt power for the factory.
D) Pins 2 and 4 are for the Power On LED (Light)
Pin 2 is for the Positive ( + ) wire.
If the Power On LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) NO pin 10, just a blank spot.
How to find out what wires are what, in that Front Panel harness connector?
Follow the wires from the connector, up to the Front Panel.
Front Panel removed it is easier to see where the wires go.
You can follow the color code of the wires, and see which twisted pair go up to the Power On switch.
You can also see which ones go to the Power On LED.
(Light Emitting Diode, so it is a light)
Reset switch, (IF there is one), same thing.
The only pair of wires that will be left is the HDD LED wires.
HarDDrive activity LED.
The 9-pin plug will have to be CAREFULLY cut apart. Separate the wires, AND their metal terminals. (WATCH your fingers!)
For additional questions please post in a Comment.
Regards,
joecoolvette
Jul 04, 2012 | Gateway MCP61PM-GM (4006254R) Motherboard
Wiring motherboard to a atx tower
The motherboard manual will give you a breakdown of the cast-to-motherboard connections for the board. They differ slightly from board to board, but the connections are almost always found at the bottom front corner of the motherboard. There will be connections for the hard drive LED, the power LED, the power switch, the reset switch, and on some, the speaker (optional). The power switch and the reset switch connectors , 2-pin plugs, are not polarized, meaning that they can be connected to their pins either way without issue. The Power and HDD LED plugs are polarized, as LEDs have a positive and negative. Get this plug backward and the LED won't work. These are also 2-pin plugs. The power LED usually has a green and white wire (Green is +) and the HDD is usually red and white (Red is +) . Some motherboards have color-coded pins -- DO NOT TRUST THEM IF YOU DON'T HAVE A MANUAL -- they are not always standardized. Some motherboards have small print on the board adjacent to the pins to identify them. You CAN trust these. Otherwise, go to the Motherboard manufacturers site and get the manual for the board. The model number is on the board and can be searched for. If the manufacturer's name is not obvious, Google the model number and it will usually lead you to the manufacturer.
Dec 17, 2011 | Intel Motherboard
Proper installation of tower wires
According to Gateway Support, the Gateway 505GR desktop computer uses an Intel (Ausberg) 915G motherboard,
http://support.gateway.com/s/PC/R/3724/3724iv.shtml
http://www.ascendtech.us/itemdesc.asp?ic=MB4GWAUGSBURG
Scroll down to the photo with the sections marked in red.
In the top link, looking at the motherboard with the computer case open, the USB and Firewire (1394a) cables, can be seen attached to the motherboard near the letters D, E, and F.
In F that red cable is a SATA cable. One end attaches to the back of the SATA harddrive, (The angled end), and the other end of the SATA cable attaches to one of those SATA headers on the motherboard.
(SATA header = SATA connector on motherboard)
Preferred SATA header for the Harddrive is SATA 1.
DOESN'T matter though. That's the beauty of SATA. You can plug the SATA data cable into ANY SATA header on the motherboard, and BIOS will find the harddrive.
In the second link, looking at the motherboard photo shown, and comparing it to the view of the motherboard as mounted in the computer case, the Front Panel header is at the very Bottom Right.
Two rows of pins in a White rectangular shaped header,
(S points to Front Panel header)
[ The plastic front of a desktop computer is the Front Panel.
The area of pins on the motherboard, that the Front Panel wires go to, is the Front Panel header ]
A) Top row has Even numbered pins
B) Bottom row has Odd numbered pins.
http://www.intel.com/support/motherboards/desktop/sb/CS-009016.htm
1) Power LED = Power On LED light
2) Hard Drive Activity LED = LED light that flashes (Usually red in color) when your harddrive is active. Being used.
3) Reset switch = Reset Button. The Reset switch is behind the Reset button. (IF the computer uses a Reset switch)
4) Power Switch = Power On switch
5) Forget about Pin 9. That's for 5 Volts DC - Out. Used by factory.
Which wires coming out of the Front Panel, are the Power On wires, Harddrive LED light wires, Power On switch wires, etc.?
Remove the Front Panel, and trace where the wires end.
IF, the wires already installed coming from the motherboard to the Front Panel, are Too short, you should make notes before you remove them from the motherboard.
Note what color pair of twisted wires, went to where, in the Front Panel.
Compare to the chart of the Front Panel header given above.
(IF any wires are still connected to the Front Panel header on the motherboard)
Once the Front Panel is removed, it's usually pretty easy to trace the two wires up to the Power On switch.
Same for the Power On LED light.
Again, same for the HarDDrive activity LED light.
The SATA harddrive requires a DATA cable, and a SATA power cable.
The connector for a Data cable has 7 contact pins. It is the shorter connector.
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
The connector can be at a 90 degree angle as shown, or a straight connector.
IF the data cable has an angled connector, it plugs into the Harddrive.
Straight connector goes to the motherboard.
The connector for a SATA power cable has 15 contact pins. It is the longer connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note the L shape of the connectors for the SATA data cable, and SATA power cable.
Also;
This is a 4-pin standard Peripheral power cable. Commonly misnomered as a 'Molex' power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
IF, the SATA harddrive has a provision for a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY use just the SATA power cable.
Using both power cables will burn up the harddrive.
May not happen immediately in some cases, but WILL eventually happen.
Regards,
joecoolvette
Nov 17, 2011 | Gateway 505GR PC Desktop
One day, when i clean my system box that i take out the pannel wires from the board .these are power led,hd led etc....after that when i set up those wire i can not use my computer computer .my destop...
Hello aunglina6
As i can see from the picture of your motherboard the connections are at the bottom close to the battery. it looks like this
o o o o 1 2 3 4
o o o o o 5 6 7 8 9
this is just to give you the idea how it is set up.
9 is no connection
8 + 7 is reset switch, 6 + 5 is hard disk LED with 5 the positive of + side.
1 + 2 is power LED with 1 the positive or + side, 3 + 4 is the power switch.
with the reset and the power switch don't worry about the positive or + side. it makes no difference.
good luck.
please leave comment if this was helpful
Jan 01, 2011 | ECS RS400-A (V1.0) Motherboard
FR33E
make sure both power cables are hooked to the mobo. 24 and the 4 pin.
if still no video check all the cables. is STILL no video what may have happened is that during the case switch you may have given the board a static shock thus shorting out the video chipset on the mobo. you may need to replace it.
Aug 18, 2009 | FIC FR33E Motherboard
Need wiring diagram for eMachine 20030812 motherboard!!!
You should be able to see the words/letters that go with the jumpers on the motherboard itself. look around the jumper settings area for power, pwr etc. and match them up with your jumpers which should have what the go to on them.
Apr 10, 2009 | E-Machines eMachines Refurbished EMA...
Wiring off the tower
The 2 grey wires with the 4 pin connectors would be for the USB ports at the front of the tower. They need to be connected to the motherboard usb pin outs. Usually marked on motherboard as "USB1", "USB2" etc. Generally the red wire should be the "power" and goes to pin1 or 2 on the connector. Pin 1 is normally marked by a thick line on the board at that end of the connector, but it's easier to say Pin1 is the opposite end to the single pin on it's own (which isnt used). You really should check the manual for the board to confirm the connections though.
Jan 03, 2009 | ASUS P4P800 SE (890552603657) Motherboard
I am trying to connect my tower connections to my FIC FR33E board
I found the manual for my computer motherboard. Thanks for your help.
Dec 21, 2008 | FIC FR33E Motherboard
MY MONTOR HAS POWER AND IS NOT WORKING.
Hi, dont loose faith. If you look on your mother board along the edge closest to the front of the case you will see a series of pins, usualy about 10 pins. Printed on the board will be the names of the plugs that match. The wires from the front of the case have corresponding names. The power and reset switch will work no matter witch way around you put them. The HDD led and the pwr led will only work one way so if these lights dont work, just reverce the plugs. If desperate you can bridge two pins together at a time until you get the on/off switch. Note you cant hurt anything unless you use a hammer. Regards mistyman
Sep 03, 2007 | FIC FR33E Motherboard
FIC FR33E Motherboard Logo
264 people viewed this question
Top FIC Computers & Internet Experts
David
David
Marvin
Marvin
Jax Planet
Jax Planet
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
