Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Xp home will not boot
System will not boot, not even in safe mode! I can get to the system page but I do not know what to look for here. Can not get to SYSTEM RESTORE.
  • Anonymous Dec 08, 2007
    system will not boot . i have to install windowsxp every time i turn on my pc . t boots up to the sreen showing icons and then shuts down and re boots over and over.
  • 91 Answers
Welll; it sounds to me like there are errors on your hard drive and to fix this problem you are going have to go to bios set the boot device for cdrom and put in the operating system disk it willl scan your harddrive first to see if there are any errors on it and then it will begin to copy the files that are needed and then once alll that is done it will restart your computer but if you have any floppy disks in you will have to take it out and then it will restart it will begin to scan what network devices are on your computer this will take awhile .. once everything is done like your browsing services,control panel,etc you should be finished at this point but you might have to setup your ethernet adapter
Posted on Sep 03, 2007
SOURCE:
Why the system automatically go to safe mode
If you are using Windows XP then you may have the /safeboot set in the boot.ini file which will force XP to always boot into Safe Mode.
When the system has started, click on Start then Run and type MSCONFIG as the command to run.
Open the Boot.ini page tab and make sure that the /SAFEBOOT option is not selected in the Boot options section of the page.
Save the change and restart Windows and it should start normally.
Dec 27, 2011 | Dell OptiPlex 780 Desktop Computer 1 x...
I have received a Blue Screen Error but I do NOT have the XP disk
if you cant get online on your pc you're gonna need to go to someone else's and download a windows boot disk from the ms website then boot your pc from that, choose recovery console then repair boot partition.
Feb 28, 2010 | Microsoft Windows XP Professional for PC
Windows will not start; the computer continues to boot up to the safe mode selection page. None of the options to start in safe mode have been successful. I downloaded the system and do not have it on...
Ughh, I always hated that safe mode. BUT, you should be able to use your login from there. You stated that none of the options work. Same has happened to me. Somehow your operating system became corrupt it sounds.Can you even boot into the very first OS that existed? Get into the BIOS? From there you should be able to "restore settings/config" Try that. What do you mean you downloaded the system? Is it a cracked copy? O-o That could be the problem as it has already detected that it is cracked, as in not a legit copy. Some keygens do not even work. You may have to do a fresh install, and in the meantime, think about buying a legit copy. Because of legalities here Im sure, I cant go into that much further :-P
Dec 03, 2009 | Microsoft Windows XP Home Edition
Went to misconfig to select safe mode boot safe mode starts but window comes up stating no safe mode and is rebooting and it just does this over and over and i cannot get back to sselect misconfig to...
Hello
Thank you for using
FixYa for your problem
The reason you cant get past the restart is because by selecting safeboot on the boot.ini tab, you have now set your computer to boot straight into safe mode (even though you knew your computer couldnt boot to safe mode) :)
Were you having trouble before? Why were you trying to get into safe mode in the first place? it may help with the solution. Were you getting shutdowns or blue screens? Ram problems can cause all sorts of issues.
Do you have your windows cd? If you do then follow the instructions on the link below to replace your boot.ini. file
http://pcsupport.about.com/od/fixtheprob…
Let me know how you get on with that and we will go from there :) (just edit your original post with added detail)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 22, 2009 | Microsoft Windows XP Home Edition
When i restart my computer no icon came out
try rebooting in "safe mode", by holding 'F8' as soon as you start your system, until the black screen with several boot options shows up. Select "safe mode with Networking". If you can boot it up and see your icons again, try a "system restore" to a time when it worked properly -maybe a few days ago?
To do a system restore:
"Start"
"Programs"
"accessories"
"System tools"
"System Restore"
"Restore my computer to an earlier time"
I hopes, please let me know.
Mar 12, 2009 | Microsoft Windows XP Home Edition
Safe mode
You can also force the system into safe mode. You click on startup and type in msconfig. Click the general tab and select diags and the system will reboot to safe mode. Change it back to normal to get your system out of safe mode.
Please rate my response.
Feb 17, 2009 | Microsoft Windows XP Home Edition
Windows xp home edition computer will not start
If the system cannot start on safe mode probably your operating system has gone bad, to check your hard disk you can go use your windows xp disk, to boot from it press f12 choose cd rom keep on tapping enter and dont mind the message that you need to press any key to boot from cd, and then when you are on the welcome to setup page press r for recovery console, once you are there try to type in chkdsk /p and after type in fixboot and press y, and restart your system, if that wont work then your hard drive is bad.
Oct 31, 2008 | Microsoft Windows XP Home Edition
Windows XP won't boot and safe mode doesn't work
Well hate to give you the bad news but it sounds like your hard drive as died. The error code you mentioned (0X000000ED) designates file system damage. (Referenced here http://support.microsoft.com/kb/297185). Your best solution would be to replace the hard drive in a repair shop.
Sep 07, 2008 | Microsoft Windows XP Professional With...
Win xp start up
Yuk...sounds maybe like a virus. When you start your computer, you may be able to hold down F9 or another similar key to enter into a start up mode. Then perhaps you can boot the computer in safe mode or something to at least get into windows. Theres not much you can do if you cant even get into your operating system...may have to have a tech look at it.
Dec 24, 2007 | Microsoft Windows XP Home Edition
WANT TO CHANGE THE PASSSWORD
If its XP Home then you can achieve this by booting into safe mode
Nov 25, 2007 | Acer Ferrari 3200 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
