Question about Crown CE1000 2-Channel Amplifier
Channel 1 static and lack of performance
Channel 1 is low on volume and when i turn the gain up and down its gets staticky(sp) and inconsistant. It gets the quietest at about half way up. I know its just channel 1 because i switched the speakers and it changed with the switch. It seems that sometimes it works fine and other times it does this. It is a little dirty from and outdoor event but it had been working fine since til just recently. I also tried pushing the reset button but it didn't seem to do anything at all.
    Problem Solver:
  • 20 Answers
The potentiometer (volume control) is probably dirty. Open the amp and find the "pot" connected to that volume control. You should be able to see small opennings where you can spray electrical contact cleaner inside. Give the knob a few turns and try it out. If it gets better but not perfect, repeat. If several attempts don't eleminate the problem, the pot will most likely need to be replaced. Contact cleaner can be found at any electrical supply store such as Radio Shack. Be sure to use one that says no or zero residue. I use a product called Electrosolve.
Posted on Sep 15, 2007
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
Why would my car stereo sound staticky when i give it volume'',it was not like that earlier
first adjust the fade and balance, checking each speaker for this issue. if they all continue to cause static when turning up the volume, then it is either the connections are crimped poorly, speaker connections are not secure at speaker or just a faulty volume control knob
Feb 23, 2010 | JVC Car Audio & Video
MG100HDFX Amp - crunch setting seems too loud
There are 2 channels, Which means there are 2 sets of knobs ... One for clean and one for crunch. Start out with a low master volume and set up the crunch, Then the clen and switch between the 2 and make adjustments until they match volume wise ... Then turn the master up.
May 12, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
I'm looking for the manual for a Mitsubishi VCR HSU447 with the remote control RM75502 so I can program my TV to it. Thanks
1.- Turn off your TV
2.- On the remote control, set the VCR/TV slide switch to TV position.
3.- While holding in SP/EP button, press the code button listed below that corresponds to the brand of your TV
4.- Press TV POWER on the remote control. Once your TV has turned on, your remote is set up to operate your brand
TV.
Brand of TV Brand Code Button
Mitsubishi 1,2,3
Fisher 0
G.E. VOLUME UP
Goldstar 2,9
Hitachi 8
JVC MUTE
Magnavox 4
NEC 2,9
Panasonic CHANNEL UP, CHANNEL DOWN
Pioneer 6
Philips 4
Proscan VOLUME UP
Quasar CHANNEL DOWN
RCA VOLUME UP
Sanyo 0
Sharp 3,5
Sony VOLUME DOWN
Toshiba 7
Zenith INPUT
I finnaly found my VCR Manual, and I'm glad to share this info with you, because I was looking for the manual all
over the web and FOUND NOTHING!. Bye!
Mar 15, 2009 | Mitsubishi Televison & Video
Amp volume problem
Sounds like you have a bad or dirty gain potentiometer. Try turning the gain up and down with the volume at a moderate level. If u hear static, it is possible the potentiometer is bad or dirty. Replace with one of the same value and see if that solves your problem.
Jul 15, 2008 | Rockwood Car Audio & Video
Pcchips A13G+ motherboard sound issues
You may not have a choice. The jack could be loose or have a bad solder joint. If the microphone is "staticky" on this system but not on another, then increasing the volume will only increase the static.
You can try a condenser microphone. Condensers require their own power (battery) and output a MUCH higher signal. High enough for the Line-In jack.
If you are using the microphone for voice chat or internet phone or gaming or similar, I STRONGLY suggest a USB headset, such as you can get from Logitech. You wouldn't believe the quality difference.
Jul 06, 2008 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
Channel 2 volume is very low
You can check if channel 2 is blown by switching around your RCA plugs. If you are using the speaker wires as high power inputs you can change them. I.E. swap the left channel with the right one. I assume you checked the gain control on the amp. If channel 2 works with channel 3's inputs then its your head unit or the wiring. If you are lazy take the amp to a car audio store and ask them to bench test it for you. Hack
Jul 13, 2007 | Nakamichi PA-504 Car Audio Amplifier
Crown CE1000 2-Channel Amplifier Logo
179 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
