Question about SmartDisk FireLite 40 GB Hard Drive
My computer stopped detecting my hard drive
I plugged the hard drive into the computer but the computer refuses to detect the hard drive-- i tried on my laptop as well and its the same problem. i even thought it was the wire that may be defected so i went to best buy and the geek squad ppl plugged in a new wire to their computer and it didnt detect there either... i dont know what to do!
  • 7 more comments
  • sunfish2 Dec 26, 2007
    I have the same problem with a SmartDisk Crossfire 160GB (both USB/Firewire enabled). I've submitted a support request with SmartDisk and it's still pending.
    When I first got this external hard drive, it was easy to use: just plug it in to my laptop or my desktop. Both PC's were running Windows XP and automatically recognized the drive. I was able to do a backup using the software that they included (Bounceback Express).
    Then the second time I plugged it, it was not mounted as a drive on one of my PC's. And now, it won't mount on either PC.
    I've tried different cables (both USB and firewire). I've also tried it on 3 other PC's running Windows XP, Windows 2000, and Windows Vista, respectively. The same problem occurred.
    On my laptop, when I connect it (either USB or Firewire), it actually shows up as a device under My Computer--> Management-->Device Management. However, it does NOT show up under My Computer-->Management-->Disk Management. Only disk drives show up there: my internal hard disk and my CD/DVD drive.
    This drive is basically brand new, having been used only twice. It's been well-treated, never dropped or anything like that.
    I think I've seen similar problems with the SmartDisk listed by other users on FixYa, and not just with the CrossFire but also the FireLite and other models.
  • mattomega Jan 03, 2008
    I used to be able to plug my 80 gig FireLite in my computer and have it detected without a problem, but now when I plug it in, it powers up, but it doesn't get read on my computer.
  • SamUK Jan 03, 2008
    I have the same problems with my 40G FireLite on my Mac. It worked for a little while but then started playing up. Seems like the more data I store on it the worst it got. Now it doesn't show up at all on my computer - still lights up though.
    I'm completely at a lost to know what to do. Can anyone help, please?
    SamUK
  • bellaluna123 Apr 11, 2008
    I have a Mac and when I went to the Genius bar they noticed that I needed to reformat my HD for Mac. It was automatically formatted for PC. If you take it somewhere for someone to do it for you make sure you have backed up your information because they will have to erase it. It shows up on my desktop now.
  • Anonymous Apr 13, 2008
    I haven't resolved the problem. went to control panel, printers and other hardware. (See also) on the left, add hardware. Connected the hardware.USB mass storage comes up with a yellow icon, saying something about stage 10.
  • Anonymous May 06, 2008
    I have had a FireLite external hard drive and suddenly my laptop quit recognizing the drive when i plug it in. The drive lites up so it is energized. Same problem as others have described. I can plug it into another computer and it comes up okay.
  • margcrft Aug 18, 2008
    I have 3 firelight fwfl40 drives and none of them are showing up on my MAC running 10.4.11. They do show up on other computers running older versions.
    What can I do to fix this problem?
    Thanks,
    Marge
  • jhawkfitness Dec 10, 2008
    Same problem as other users posted. I plug in the USB cord, in my case I can feel the HD spinning but the blue light on top does not illuminate.
  • techmanc6c7 Mar 09, 2009
    I have the same problem i have been using it and it works great for a long time. My little brother flipped the switch on the back from "USB" to "EXT" when it was off and not plugged in. I switched it back before i plugged it in. However now my computer and the others i tried it on wont work. It shows up in device manager and makes the beep noice when plugged in but doesnt show up in my computer. in device manager it says it is "Not Initialized" I have tried re-installing drivers, rebooting, starting my computer up with it plugged in, not plugging in until booted up. Help please i am running Windows Vista (32 bit).
    Problem Solver:
  • 11 Answers
In control panel/hardware and sound/device manager under disk drives, while firelite is plugged in right click on firelite and delete driver. unplug firelite, reboot then plug it back in. It should reinstall the driver and harddrive should work again...
Posted on Aug 10, 2009
    Brigadier General:
  • 6,966 Answers
Hi, Based on your post/description: 1. Tried on 3 different computers - no go, so it's not a PC problem; 2. Tried replacing the cable - no go, so it's not an interface problem; 3. That leaves you only with the Firelite itself. An external hardrive would consist of 2 main parts, the electronic board and the hard disk itself. The board seldom (if ever) fails. Its function is to provide conversion/interface from the SATA/IDE connectors of the HD to the out USB/Firewire. The HD more often than not fails. Most external storage uses a standard HD inside the enclosure. Your possible options: a. Claim warranty/replacement; b. Replace the HD only; c. Physically remove the HD and connect it direct to a desktop either as IDE or SATA and run manufacturer's diagnostic and/or third party recovery software; d. Seek services of professional data recovery firms (if data/files are mission critical); Hope this be of some help/idea. Post back should you need further information. Good luck and kind regards.
Posted on Sep 03, 2007
SOURCE:
My dell leptop refus starting i got message : Primary hard disk drive not found , CDBOOT ; Memory overflow error
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Feb 16, 2012 | Dell Latitude C800 Notebook
Have seagate free agent go window 7 not reconizing the unit. please help.
You can try to use a different usb port of your computer check if it will be detected or try to plugged a different usb device see if it will be detected by the computer.If you have a different computer try to check if it will be detected. If the computer detects a different device it only means that the hard drive that you are connecting to the computer is faulty.
Thanks for using Fixya.
Jan 27, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Western Digital USB powered WD600U017 drive Does not appear to be spinning up. This drive has been in use for 2 years When plugged in the drive makes 3 beeps 2 low ones followed by a higher one. It...
The first thing I'd recommend is to check Disk Management, to see if the computer is detecting is as a hard drive. ( Right click on my computer, hit manage, and under Storage, select 'disk management').
From there you'll be able to see how it's detecting the hard drive.
Even if Device Manager detects it, if Disk Management does not, you know it's not being 'properly' detected.
From Disk Management, you can format the drive, or reassign a drive letter (if needed).
I've had a similar issue where the problem was the power connector to the hard drive. If you have important data on the hard drive, you could open the external case, and attach the hard disk with a separate usb device, such as http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=3276554 . Good Luck.
Nov 16, 2010 | Computers & Internet
When i plug the hard drive my computer wont detect. only the bios can detect.and i cant reformat it it says.a problem has been detected. i boot it from cd and after the windows setup it displays" a...
This usually happens when u fit any hardware to the system....The information which u gave seems its "Blue Screen of Death" or "BSOD" ........ if u have seen this screen only after u plugged in yr HDD, try with other HDD. Perhaps there might be an error with the HDD which u have plugged in.
Jun 13, 2010 | Seagate U6 (ST340810A) 40 GB Hard Drive
My Apollo 250GB USB hard drive can't be detected
It should be in My Computer after you plug it in. If not, then go to control panel and search for new hardware. Click on system in control panel it should be listed under usb. Maybee it needs a new driver.
May 17, 2010 | Imation Apollo (27223) 250 GB USB Hard...
Windows wont start. dont know how it happened.
press F2 to go to the system setup, then press arrow down to highlight Standard CMOS feature, then press enter. Verify if the hard drive is detected, mostly it is installed in SATA 0 and you should see like a serial no of the Hard drive. If the hard drive is not detected, you might need to reseat the cables of the hard drive inside the computer. Make sure that all the cables at the back of computer is unplugged to be safe. After you reseat the hard drive cable, plug cables at the back of the computer then turn on computer and press F2, verify if the hard drive is detected, if still not, try to swap the connection of the hard drive and the dvd drive of the computer. Plug back the cables and turn on comp and press again F2, this time the the dvd drive should be on the SATA 0 and hard drive should be on the oter SATA port. If the hard drive is still not detected, you need to replace the hard drive, but if the hard drive is detected on the other SATA port and the dvd drive is not detected on SATA 0 then you need to replace the mother board.
Mar 16, 2010 | Dell Inspiron 530 Desktop Computer...
Cant detect my western digital hard drive help! philippnes!
Shut down the computer.Disconnect the ide cable from hdd .Just connect using primary hdd and boot the computer. Shut down the computer. Connect the secondary hdd both IDE and power cable. Restart the system and go to bios . Check if the both hdd are detected in bios. If detected boot to desktop. If not detected reset bios settings to default.Restart computer and check. IF still not detected shutdown computer.Disconnected secondary hdd and primary hdd,connected secondary hdd to primary ide connecter and check in bios. If still not detected try connecting secondard hdd on different computer and check.
Aug 17, 2009 | Computers & Internet
PC wont detect external hard drive
Does the drive have a socket for external power?  or do you have a USB cable with 2 usb and 1 mini usb?
Sounds like it needs external power.
May 28, 2009 | Western Digital Passport WDXML800UE...
StoreJet 2.5 Spinning properly(sounds) but not detected
try the drive in a new case. if that dosent work the drive is dead.
May 07, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My computer has stopped recognizing the 160 GB portable hard drive (plug and pray)
better plug it to another pc and observe if it would be recognized by the pc. well, sometimes, portable hard drives takes time to be detected by PC specially when it comes to age, better observe it for about 3-5 mins, and if its not detected, try to touch the usb cord of your portable hard drive connecting to your pc and make some adjustments to it.
Mar 14, 2008 | Computers & Internet
SmartDisk FireLite 40 GB Hard Drive Logo
1,417 people viewed this question
Top SmartDisk Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
