Problem for Washing Machines
Generic problem for all Washing Machines
Hotpoint aquarius1100 electrical prob.
my machine has just been moved from one house to another 4th floor flat today,and upon using it it seemed to work fine then it tripped the switch on that circuit ,it then seemed to work fine to just spin if i put it on that part of the cycle.now about half hour later it trips off immediately that i turn the power on,first time it happened it actually had time and i could hear it start filling then it tripped after 2 minutes or so. Each time i tried after it got shorter and shorter till noe it just shorts out.
Comments:
Sep 04, 2007
- THANKS THAT'S WHERE I GOT TO,WHER TO START LOOKING FOR THE SHORT ANY IDEAS MOST LIKELY FROM MOVING IT ? MAYBE WATER GOT ON WRONG PLACE WHEN I LAID IT IN THE CAR ON ITS SIDE?ANY IDEAS?
Best Solution
posted on Sep 03, 2007
Rank: Wiz
Rating: 84%, 520 votes
you say tripped the switch?... are you talking about a circuit breaker???.. I was thinking maybe you have a bad breaker... If you had no problem before... maybe try in a differt plug in reciptical...
if the washer has a short.. hard to find sometimes..like looking for needle in hay stack..
Comments:
Sep 05, 2007
- Did any water spill out when u loaded it??
did you try a new place to plug in...making sure not a bad breaker?
well maybe start at the water valves... you said it started to fill and then triped the breaker?.. so that means nothing else had power at that time just the w. valves... unplug the cold see if hot will work visa virsa
Was this helpful?1 person thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
I have read some awful reviews on Ariston washing machines. They look good and have features I want,...
(More)
I have read some awful reviews on Ariston washing machines. They look good and have features I want, but are they really very unreliable?
the agitator keeps spinning after the wash ended. black pieces seen on the cloths
when started it gave a small electrical pop and triped the rcd. Now when started it gives two clicks...
(More)
when started it gave a small electrical pop and triped the rcd. Now when started it gives two clicks and goes to finnish
my washer will not spin and it will not spray rinse
