Question about Sony Cyber-Shot DSC-T3 Digital Camera
UNABLE TO TAKE PICTURES
THE CAMERA SCREEN IS BLANK (DARK, WITH ICONS SHOWING) WHEN I SET IT ON CAMERA OR VIDEO MODE .I'VE TRIED SWITCHING IT ON AND OFF,RESETTING IT ,INSERTING AND RE-INSERTING THE MEMORY STICK TO NO AVAIL. PLEASE ADVISE. THANKS. Sella
  • SELLA Sep 03, 2007
    DEAR SLOBANS,
    THANKS FOR THE TIPS.WILL TRY TO SORT IT OUT.
    BEST REGARDS
    SELLA
  • 39 Answers
My guess ccd chip is faulty.check sony site,they admit that they had problems with certain models.good luck. ps i had similar problems with my p10,it was ccd that died...
Posted on Sep 03, 2007
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Hi, When the camera is turned on, the LCD diaplay screen is blank (dark) and just displays various information icons for batterly level, megapixels, quality, flash-on, etc. When I try to take pictures, the...
The display being blank can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the images/picture is seen to be of good quality, then the LCD can be faulty, fault on the linking cable or the control board.since you are able to seen the ICONS the LCD is good , Now if the picture taken are seen well the CCD is also OK and the fault seems to be a digital logic gate failure as there is no switching of the circuit .
This might require a probe and it might be a relative issue in the motherboard circuit or the processsor. Remove battery , press down all buttons to drain off voltage and see if the camera resets.
Thank You for using fixya
Sep 27, 2011 | Vivitar ViviCam 4345 Digital Camera
Camera switching on ok but lcd sceen blank
Your problem can be the result of a number of causes - two common ones I will list here.
Most common cause would be a failed printed connecting cable between the main camera electronics and the flip out display panel. This special cable passes through the display hinge and is sometimes subject to failure.
A second possibility is a faulty display backlight.
You can check that the camera is still producing video output by using the AV cables conected to a TV display with the camera set to CAMERA mode.
I trust that this information is of assistance. RHN
Jan 02, 2010 | Sony Video Cameras
Blank screen
Try this...if you can still get into the setup menu, scroll to "reset" and follow the on-screen instructions. If not, remove the memory card and battery...press all the buttons...leave the camera alone for 20 minutes...insert the card and then the battery...turn it on. Did that help?
Sep 28, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
LCD Display Blank
I have a sony cybershot DSC-S650, the LCD was very dark and could not see anything except if I pointed it at a bright object, everything else worked ok. I could take pictures but could barely see them in playback as well.
I took it to Sony authorised repair outlet and was told the CCD was damaged, they charged me USD $55 to repair it (in Quito, Ecuador)
Jul 31, 2008 | HP Photosmart R607 Digital Camera
LCD Display Blank
CCD malfunction, common with Sony manufactured CCD chips. You are in luck, its a free repair regardless of warranty date.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=223&modelid=8044#
Feb 12, 2008 | Cameras
In the camera or video mode my phone freezes,,,help!!!!!
this  is camera software problem try to reinsatll ur camera software .. then try to click the pictures
Oct 21, 2007 | Motorola Mobility RAZR V3
Blank screen
This sounds like CCD sensor is faulty and should be replaced . Camera works fine in playback mode generally with this problem but not in capture mode ( camera has gone 'blind'). Should be repaired free of charge if the camera is as old as you say.
Aug 16, 2007 | Olympus FE-170 Digital Camera
Sony Cyber-Shot DSC-T3 Digital Camera Logo
46 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
