Question about Radio Shack Pro-97 Handheld Scanner
Pro-97 20-527 scanner
I just bought this pro-97 scanner and the display wont work the scanners on but no numbers show . Is there a way to reset it or fix it
    President:
  • 1,114 Answers
You can download the manual from the link below: http://support.radioshack.com/manuals/ome20-527.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Sep 03, 2007
  • 3 Answers
Mine did this over the weekend.
I selectively wapped it with the palm of my hand on each of the 6 sides until one of them made it work again.
A hit against underneath the keypad did the trick.
I believe there is a ribbin cable underneath the keypad at the base of the radio that gets dirty, or comes loose. That worked for me, your results may vary.
I seen this complaint also mentioned by others on yahoo groups PRO-97, they took theirs apart and reported a ribbon cable as the cuplrit.
search for: q-tips and grease, I think.
Posted on Sep 06, 2009
  • texascert
    texascert Jul 20, 2012
    Yeap!, I opened the back cover and yes there was a ribbin cable a little loose. got small eyebrow puller and that got it back in place. I also used dry air blower inside the circuits. No q-tips or grease located.
SOURCE:
Reset factory settings
Turn printer 'OFF'.
Hold Cancel button and start/Copy button at the same time.
Turn printer 'ON'.
Release the buttons after display shows "Permanent Storage Init".
Wait till the display shows "Ready"
Jan 10, 2014 | HP LaserJet Pro M1212nf MFP -...
Scanner pro 93
reset it one more time and let the scanner boot before you do any thing else chill out for while dont be so egor
Sep 26, 2013 | Radio Communications
Reset scanner
Please try this:
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Hope that helps.
Happy Scanning!!
Oct 24, 2012 | Radio Shack Pro-97 Handheld Scanner
My pro 94 scanner shows the code luired when turned on. How do I fix this?
I'm guessing that the display shows "wired" and not "luired." This mode, along with the code, is supposed to clear when the computer programming cable is disconnected. If you don't have a cable connected, your only option is to RESET the scanner to its original factory settings. Just a caution: resetting the scanner will erase/delete all programmed information -- you will have to reprogram all of the data that you've previously entered. To RESET the PRO-94:
1. Turn the scanner OFF.
2. While holding down the 2 and 9 keys, power the scanner ON. The message "CLEAR" will flash for about 5 seconds while the scanner resets.
NOTE: Do not turn the scanner OFF until "CLEAR" stops flashing.
Bill B.
Listening in since the 60's
Oct 27, 2010 | Radio Shack Pro-94 Scanner
How do I reset defaults on pro 137
To reset your scanner to its original factory defaults:
- Power the scanner OFF
- Press and hold the 2, 9, and SCAN keys and power the scanner ON
- The message Initialing ... Please wait will display during the RESET. Do not power the scanner OFF while this message is showing.
Need the manual for your scanner? You can download and print it here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-137%20OwnersManual.pdf
Bill B
Aug 13, 2010 | Radio Shack Pro-97 Handheld Scanner
Locked on search
You may have inadvertently locked the keyboard. If a key-shaped icon is showing on the display, press and hold the FUNC and KEYLOCK keys until the icon disappears. If that doesn't work, you may need to reset the scanner to restore normal operation. NOTE: this operation will delete all information that you have programmed into the scanner. To RESET the PRO-83, power the scanner OFF. Press and hold the 2, 9 and HOLD keys, and power the scanner ON. After about three seconds, CLEAr should appear on the display to confirm the RESET.
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-83/pro83.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Jun 07, 2010 | Radio Shack Pro-83 Scanner
My pro-2096 does not display any letters or
If all else fails, you can RESET or INITIALIZE the scanner to bring it back to normal operation.
To RESET:
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 after the scanner completes its boot routine
- Press 1 after the menu appears
- Press ENT
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Jan 22, 2010 | Radio Shack Pro-2096 Base Scanner
Scanner not receiving
Performing a RESET will not clear/erase frequencies or other data programmed into the scanner. If the RESET doesn't work though, you may need to INITIALIZE the scanner. That procedure will clear all programmed data and return the scanner to its "as new" state. Need the manual for your PRO-82? You canb download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
Nov 02, 2009 | Radio Shack Pro-82 Scanner
Have PRO95 scanner lost showing readout of agencys on radio
You need to Reset the display,
Turn off the Scanner, wait 10 seconds then turn it back on,
Now Insert a pointed object, such as a straightened paper clip, into the reset hole on the left side of the scanner above the PWR DC 9V jack.and hold it for 5 seconds.
The display should return to normal operation..
Note this will not erase the frequencies in the scanner it will reset the display processor.. Let me know how it goes.. :-)
Jan 25, 2009 | Radio Shack Pro-95 Handheld Scanner
PRO 96 SCANNER
you have set for mot, it needs to be on fm
Oct 17, 2008 | Radio Shack Pro-96 Scanner
Radio Shack Pro-97 Handheld Scanner Logo
1,330 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
Jason
Perry Mellott
Perry Mellott
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
