Question about Canon Pixma MP450 All-In-One InkJet Printer
Scanning mode, unrequested crop
Trying to scan an 8.5 x 11 drawing i have gone thru settings to specify full sheet, tried saving in various formats (pdf, to pc, thru application), but every attempt crops the drawing to a 3" band. any ideas ? thanks...
  • cjhuckabee Dec 16, 2008
    I have the same problem -- unwanted cropping. I have gone through the settings and see no way to alter the crop.
  • oddsapdakins Feb 13, 2009
    I am scanning a receipt 8.5 x 11 and the scanner crops to just the printed parts rather than the whole sheet. The solution listed for this problem on this site...makes no sense, english?
    Master:
  • 619 Answers
There many program to reshape or crop /adobe photo shop/corel draw.it make drawing became smaller in size to fit scanner.
Posted on Jan 10, 2008
SOURCE:
How do I scan a document to create a pdf or jpeg file?
Hi,please follow these instructions:
1.Place your documents or photo on the scanner
2.depending on your operating system that is windows or Mac, do any any of the following:
Windows:
Double click the Espon scan icon on your desktop or go to start>all programes>Espon scan
MAC Os X,Open the applications folder and then click ESPON SCAN
the espon scan window appears.
3.if the mode setting on the upper right corner is set to FULL AUTO MODE like this, click the scan button
4. the file save settings windows appears
5. You select the folder you want to save in and click OK, it starts scanning in full auto mode
6. the scanned image is saved in the specified location.
Thanks
Sep 13, 2011 | Epson Stylus CX6900F All-In-One InkJet...
How do I scan an item and send a copy to a friendI am using a Photosmart C5280 printer
Please follow the steps below to do a clean installation of your scanner.
The first thing we need to do is remove any files that have been installed and start with a fresh installation.
1) RIGHT-CLICK on the MY COMPUTER icon and click on PROPERTIES.
2) Select the HARDWARE tab, then the DEVICE MANAGER button.
3) Remove the Epson Scanner from under IMAGING DEVICE and/or UNKNOWN and/or OTHER DEVICES by RIGHT-CLICKING on it and clicking UNINSTALL.
4) Disconnect the USB cable and close all open windows.
5) Click on START, and CONTROL PANELS.
6) Double-click on ADD/REMOVE PROGRAMS. Highlight EPSON SCAN and click on CHANGE/REMOVE.
7) Restart your computer.
DOWNLOAD
Please follow the steps below to download and install your scanner in XP:
1. Go to the website http://support.epson.com
2. Under the SCANNERS heading select PERFECTION SERIES and then your scanner model.
3. Under the Drivers & Downloads section select Windows.(Make sure it is the Epson Scan utility. Download the most current version of the Scanner Driver for your Windows operating system to your DESKTOP.
Reinstall
1) Double Click on the Epson1**.exe file that you downloaded to your DESKTOP.
2) Click OK, Unzip, and then OK again.
3) The installer will copy the files to the system. Click on FINISH when prompted.
4) Connect the USB cable. Windows will tell you new hardware is found and complete the install.
5) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
6) Your scanner is now ready to use.
Use the following steps to scan with the Epson Scan utility:
1. Open Epson Scan by going into START, PROGRAMS, and EPSON SCAN.
2. If prompted, select your scanner from the list of models and click OK.
3. In the FILE SAVE SETTINGS window, you can designate the location, name and type of file the scans will be saved as.
-LOCATION defaults to MY DOCUMENTS. Click BROWSE if you wish to change this.
-PREFIX determines how the scan will be named. Type any name you like. You can also designate a start number.
-FILE TYPE dictates what format the scans will be saved in. ie. .JPG, .TIFF, .PDF, or .PICT)
-For example: if the prefix is "img", the start number is "1", and the format is "JPG", the name of the file saved in
PICTURES will be "IMG001.JPG". More settings for file format are found under OPTIONS.
  1. Click OK once settings are changed as desired.
  2. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
  3. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
  4. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
  5. Now you can use them in mail and send to your friend.
Jul 04, 2010 | HP Photosmart C5280 InkJet Printer
Which is the scan button mp520 canon printer
Easy Scanning with One-click You can complete from scanning to saving easily by simply clicking the corresponding icon.
1. Place the document face-down on the platen.
2. On the Windows desktop, double-click (MP Navigator EX 1.0).
Alternatively, on the Windows taskbar, click Start, point to (All) Programs, Canon Utilities, then MP Navigator EX 1.0. Then click MP Navigator EX 1.0.
The MP Navigator EX navigation mode screen or one-click mode screen opens.
3. Point to One-click.
4. Click the corresponding icon.
Save to PC
Scan documents or photographs and save them to a computer.
The Save dialog box opens when you click this button. Specify the scan/save settings and scan.
Save as PDF file
Scan documents, save them as PDF files and start the specified application.
The PDF dialog box opens when you click this button. Specify the scan/save settings and scan.
Attach to E-mail
Scan documents or photographs and attach them to e-mail.
The Mail dialog box opens when you click this button. Specify the save settings and e-mail software program, and scan.
OCR
Scan text documents and open them in OmniPage SE by default.
The OCR dialog box opens when you click this button. Specify the save settings and application, and scan.
May 18, 2010 | Canon MP520 All-In-One InkJet Photo...
Can you scan photos on the Epson DX6000 and save the image to the computor? If possible how do I go about it?
Starting a Scan With EPSON Scan If you want to scan an image and save it directly to a file, you can start EPSON Scan as a “standalone” program.
step_1.gif Place your document or photo on the scanner. See Placing Documents or Photos for instructions.
step_2.gif Do one of the following to start EPSON Scan:
    Windows:
    Double-click the EPSON Scan icon on your desktop.
    Or select Start > All Programs or Programs > EPSON Scan > EPSON Scan.
    Mac OS X:
    Open the Applications folder and click the EPSON Scan icon.
    The EPSON Scan window appears.
step_3.gif If the Mode setting in the upper right corner of the window is set to Full Auto Mode, click the Scan button. For instructions on selecting optional settings, see Using Full Auto Mode.
01.gif mark_no.gif Note: 01.gif 01.gif To change scan modes, see Changing the Scan Mode.
step_4.gif The File Save Settings window appears. For instructions on selecting options, see Selecting File Save Settings.
cj35003e.gif step_5.gif When you are finished selecting File Save Settings, click OK. EPSON Scan starts scanning in Full Auto Mode.
step_6.gif The scanned image is automatically saved in the specified location.
    If the Open image folder after scanning checkbox is selected in the File Save Settings window, Windows Explorer or the Macintosh Finder automatically opens to the folder where the scanned image was saved.
Please follow this link for same manual with screenshots:
http://support.epson-europe.com/onlineguides/en/dx6000/html_s/scan1_1.htm
Hope it helped.
Nov 22, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Recognizing hardware on a Mac OS X Tiger
Try just using the epson scan utility
1. Launch Epson Scan by going into your HARD DRIVE, APPLICATIONS, and EPSON SCAN.
-LOCATION defaults to HD/USERS/(YOUR USER NAME)/PICTURES. Click CHOOSE if you wish to change this.
4. Click OK once settings are changed as desired.
5. The EPSON SCAN window will open and begin scanning in FULL AUTO MODE. In FULL AUTO MODE the software makes all the decisions for you (as to what is being scanned, where it is on the flatbed, etc). This is the easiest way to scan.
6. If you want full control over the scanning process click PAUSE and change FULL AUTO MODE to HOME MODE or PROFESSIONAL MODE. In the latter two modes you can change your scan settings as desired. Click SCAN after you have selected your settings. Click CLOSE once the EPSON SCAN is finished scanning.
7. When scanning is complete, your images will be saved in the location specified on FILE SAVE SETTINGS, with the prefix and in the format you set.
Aug 06, 2008 | Epson Perfection V100 Flatbed Scanner
HELLO
Jun 22, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson
I know the error is on the printer but it may still let you scan.
Jun 06, 2008 | Epson CX8400 All-In-One InkJet Printer
Epson stylus photo RX580
When you see the File Save Settings window, you need to select the location, name, and format of the scanned image file you want to save.
  1. In the File Save Settings window, specify the file folder in which you want to save your scanned image. Click the My Documents or My Pictures radio button (Windows XP or earlier versions), or the Documents or Pictures radio button (Windows Vista or Mac OS X).
  2. If you want to select another folder, click Other, then click Browse (Windows) or Choose (Mac OS X) and select the folder. If you want to save your image on the desktop, simply click Other.
  3. Specify a file name prefix with an alphanumeric character string. A 3-digit number is automatically added to the file name, but you can change the Start Number if you like. If you are scanning multiple images at once, each image will receive a different 3-digit number.
  4. Select a file format. Depending on the format, the Options button may be available for making detailed settings.
  5. The check boxes at the bottom of the window give you these options:
  • Overwrite any files with the same name: Select this option if you want to reuse the selected file name and location and overwrite previous files with the same names.
  • Show this dialog box before next scan: Select this option if you want the File Save Settings window to appear automatically before you scan in Home or Professional Mode. If you deselect it, you must click the File Save Settings button to open the window.
  • Open image folder after scanning: Select this option if you want Windows Explorer or the Macintosh Finder to automatically open to the folder where your scanned image is saved when Epson Scan finishes scanning.
6. Do one of the following, depending on the currently selected scan mode:
  • Home or Professional Mode: Click OK. Epson Scan starts scanning.
  • Full Auto Mode: Click OK, click OK again, then click Scan. Epson Scan starts scanning.
The scanned image is saved in the file and location you chose.
For more information click here
Nov 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Scanner
There is glass platen and on its sides you can see the markings to place various paper sizes. Just follow them as per your paper size.
Oct 05, 2007 | Epson Perfection 1240U Flatbed Scanner
Canon Pixma MP450 All-In-One InkJet Printer Logo
325 people viewed this question
Clive
Clive
old marine
old marine
Ekse
