Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Freeagent tools is not working
I am running Vista and just installed a Freeagent Pro 500GB, Esata and USB. After installing the software I have been unable to get the tools working. Vista give me a dialog box saying Freeagent tools is not working. I am using the usb port since I know that is doesnot work under Esata. I have reinstalled a number of times without success. The back up program is working fine and the drive is recognize. Thanks.
  • 1 more comment
  • longhorns Sep 09, 2007
    I found that you have to really push the cable in very hard in the drive for it to recognize the eSata.
    I found that you have to press the cable in very hard into the drive for it to recognize it. If I move the drive on my desk it sometimes loses the connection. Good luck.
    Being a tech you probably already have done this but have you checked the bio to see that the eSata port is enabled? Windows should detect the HD with only the eSata cable. Are you running XP or Vista?
It is all about pressing the eSata cable into the back of the external HDD hard. I have been working on this all day and I finally figured out this was the problem. Let me know if you need more help!
Posted on Mar 31, 2008
  • 1PoochHoward Mar 31, 2008
    I actually just called seagate...what a bunch of bone heads. So I cut up my cable to see if it would work without me having to push the cable hard into the back, and it worked. So if you want you can cut up your own cable and it should work. Seagate owes us ALL free esata cables that work!
    Problem Solver:
  • 8 Answers
I am having the same problem with the esata feature not working. The cable is brand new, seems to be making a secure connection, and works fine connected by USB only. My e-sata port is onboard (ASUS M2N32-SLI DELUXE) and drivers are installed and verified. I plugged it in USB, ran FreeAgent Tools installer, and seems to work fine under USB connection ONLY. I need to get this up and running under XP Professional. If you have any other ideas PLEASE let me know. Tim timtech@cfl.rr.com
Posted on Sep 09, 2007
  • 1 more comment
  • Timothy Pearce Sep 09, 2007
    I forgot to mention that the drive is not recognized when I plug in the e-sata port, nothing happens at all. Works fine through USB.
    Tim
    timtech@cfl.rr.com
    I have the e-sata cable seated pretty well. Just to double check, I had someone help me to press the cable into the HD and the onboard e-sata port at the same time, no luck.
    Windows should be detecting the HD with ONLY the E-sata connection, right?
    I am a technician, usually very hard to stump me. 10 Points to who can figure out whats going on here.
    Windows XP Professional.
    I will try to update my bios today, as I didnt see a specific option to enable e-sata.
    (That was when I originally checked)
Freeagent Pro hardware works with Vista, but the software does not. You can find this information hidden on the Seagate website. I just spend hours making my drive to work. It now does using Vista and eSATA. I did the following: 1. Connected the drive to an XP computer via USB, installed the tools and changed sleep time to never. (in contrast to USB eSATA seems to handle this incorrectly) 2. Check your eSATA cables and connectors. They have to be inserted completely. I had to remove 2 mm from the plastic casing of the FreeAgent in order to insert the connector properly. Check the connector on the computer. I had to remove two small metal stripes to insert the connector properly. If not fully inserted they don?t make a proper connection resulting in various errors. 3. Select the proper settings in the BIOS. Enable eSATA and check the boot order. Good luck!
Posted on Sep 02, 2007
Will only run on 32b windows vista or xp
if your computer is 5 yrs or older it might not support windows 7 also you will need a minimum of 1 GB of RAM for 32 bit or 2GB of RAM for 64 bit to install windows 7
hope this helps
http://windows.microsoft.com/en-AU/windows7/products/system-requirements
hope this helps
Aug 12, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to use
its just plug in play . put the USB cable ( ready for xp , vista n windows 7 ) it ll auto install the application and hee u go ...please comment.
Feb 25, 2010 | Seagate FreeAgent Pro 500GB External USB...
I have just purchased a Seagate 500GB Desktop hard drive
There is software preloaded on the disk. If you have AutoPlay turned off in your system, it won't start automatically when you connect the drive. Just go to MyComputer and open the drive and you will find a setup file there to install the backup software (I think it's called Launch.exe).
Oct 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Lost FreeAgent Pro power cord...where do I get
You can pick up a replacement cord at radio shack. they have universal cords that match the power rating.
Sep 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Freeagent with server 2003 not working
Seems that Seagate did not release a version of software which could be used on a Windows Server 2003 platform. I checked their web site at the following link & didn't find any software supported on Windows Server 2003:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=freeagent-downloads&vgnextoid=3723b5b59b7d5110VgnVCM100000f5ee0a0aRCRD
Sorry, but I can't help you with this one. Try contacting Seagat for this & see if they have a solution to your problem.
Jul 24, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Trying to install FreeAgent GO 500G as backup for Server 2003
Installation isn't possible directly from the Harddisk.
Try download from http://www.seagate.com/staticfiles/support/software/FreeAgentCN.zip
Good Luck.
Uwe
May 23, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro 750GB
try checking ur USB ports.May be the drive is not supported by ur usb .Try connectin to another system with same OS
Aug 28, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
With your XP problem..
Goto My Computer and right click.
Select Manage
In the window that opens select Storage and then Disk Management.
Your drives will be there, but need to be mounted. Right clicking on the drive will give you your options etc.
Your Vista problem I will have ot contemplate, though it's probably a software compatability issue more then anything.
Try running the EXE file under XP compatability, or check the website for an updated version. Be sure to get the 64 bit or 32 bit version as required.
Apr 21, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
PARTITIONING MY FREEAGENT PRO 500GB
why dont you just make use of win98 bootable disc or smart installer to partition the stuff?
Feb 05, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
476 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
