Question about Proscan PS56670 56" Rear Projection Television
Proscan ps56670 My proscan will not turn on. I hear somthing when I plug it in the wall outlet, by when I turn it on from the remote or the tv nothing happens.
  • 5 more comments
  • derkdg Jan 07, 2008
    My TV is doing something similar. Did you ever get your issue resolved? If so, how? There is a little buzz sound in the back of my TV when I try to turn the TV on, and the power button flickers light green, but the TV never turns on.
  • Anonymous Apr 16, 2008
    Hello. My television will not turn on with and without the remote. Would you help me please. It is an older model, maybe 1996. I put $600.00 into it a few years. Thank you.
    Hello my television will not turn on. Help Thank you.
  • nerwin Apr 20, 2008
    tv wont turn on i hear somehting when i plug it in but nothing happens when i use the remote or the button on the tv i have a proscan 50670. it was working just fine and then bam nothing at all.. thank you please help me
  • robnaulty Aug 02, 2008
    Our Tv made a sizzling sound then the picture started at the bottom and worked it's way to the top with fuzzy lines. There was a popping noise then no picture at all, still had sound and I could her a very low beeping sound that slowly fades as you turn the tv power off.
  • moneyball Nov 15, 2008
    tv will not turn on
    did anyone ever get an answer here?
  • Anonymous Mar 13, 2009
    tv won't turn on. Since it won't turn on the remote won't help
I just had the same problem where my Proscan would not turn on either, even with the remote. By fluke we held the power button down on the TV (less than a minute) and it powered up again - it seems that it almost needed to be reset and the process we used worked - Try that :)
Posted on Jul 28, 2009
    Problem Solver:
  • 24 Answers
Power problem
Posted on Sep 03, 2007
SOURCE:
Will not come on. Has power from the outlet.
mine did the same thing finally i tryed unpluging it from back of tv well still plugged in and then pushing in the power button on the tv and mine turns on but i cant use a remote to shut it on or off and cant seen to find any info on this tv anywhere so for last 3 months that is how ive been turning it on and off any ideas ??
May 19, 2010 | Proscan 32LA25Q 32 in. LCD TV
40'' proscan lcd will not turn on
Could of gotten voltage surge
Try anther outlet
Dec 05, 2017 | Proscan 42LA45H 42 in. LCD TV
The list button doesn't work and I am unable to
turn off your cable box
turn off the dvr
disconnect cable box from wall outlet
disconnect dvr from wall outlet
unplug e-sata cable from dvr
replug e-sata cable back in to dvr
plug dvr into wall outlet
turn on dvr
plug in cable box to wall outlet
turn on cable box
wait for cable box to go completely thru startup procedure
...then try your list button again.
Mar 01, 2010 | Televison & Video
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Tv won't turn on at all
no remote but tv was working with front power key? unplug from ac outlet and plug back and listen for any type of indication (noise or chirp) that something energizes inside if theres nothing then suspect a power supply problem, main fuse blown, shorted low volt rectifiers other components could be at fault.
Aug 05, 2009 | Panasonic CT-32SL13 32" TV
Do i need a remote to operate tv
once you have front panel in the tv and this one shows power channel +- volumen +- menu then your tv has to work with those ones and the remote is a second option to do the same. With this i mean you tv has to respond and at least show menu when you push that button " if no signal (cable DVD VCR) plug in"
Then if the tv is dead you should try to repair or sent it to repair. and then get the remote control and it can be universal too.
May 01, 2009 | Protron PLTV3250 32 in. LCD Television
Panasonic Problem
replace the fuse of the tv device (in the primary main power section),or contact the nearest repair shop.
Jul 18, 2008 | Televison & Video
Remote not working
If this TV came with an universal remote, try pressing the TV key. Sometimes it works.
If that did not work any other RCA, GE, Proscan universal should work.
Feb 07, 2008 | Proscan 26LA30Q 26 in. LCD Television
TV wont come on
Try changing the fuse located inside your tv cabinet.
good luck---------------tomtaso
Dec 01, 2007 | Televison & Video
TV won't turn on
I am having problems turning on the tv. I had lost the remote control so I bought a universal remote which was not working at the time I unpluged the tv form the powersocket then I tryed to turn on the tv the green power light stays on for a few seconds then it blinks two times then there isn't a power light on after that what is wrong
Jul 26, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Televison & Video Logo
768 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
