Question about Toshiba DVD Recorder
Philips dvdr3480 picture problem
Hi I bought this dvd recorder recently. I connected through the satelite, asianet.When ever I watch that channel through the dvdr via scart cable, I get a thick blue or black ribbon like line in the middle of the tv.But if i watch the same channel when the dvdr is on standby mode(off) there is no problem.Please help. Thanks
Do you find that the picture is much duller when recorded than the original also the DVD player seems to play back DVDs very dull compared to my previous black diamond DVD player.
Posted on Sep 25, 2007
Swap the scart inputs around. See if that solves it
Posted on Sep 21, 2007
4 Suggested Answers
SOURCE: Changed HDMI settings and can't now see image on screen
I did the same thing, if you hold the hdmi select button on the player (not the remote) while ejecting and inserting a dvd, it will reset so you are able to access the setup menu again.
Posted on Feb 18, 2009
  • 1285 Answers
SOURCE: Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO) you able to look at a dvd, record your show (s)
feel free to rate if helpful
Posted on May 27, 2009
  • 8457 Answers
SOURCE: My toshiba sdk990ku dvd player stopping playing
Tries unplug,replug it back like an hour later.Letting the DVD player resetting itself back to the factory setting.Tries it than,see if it work than.Not,than tries hook it up with the RCA component cable Y,R,W.If still have the same problems,the PCB in the DVD player is bad.Not worth repairing.Trash it.DVD players are very cheap these days.U can get a brand new one like for $40 dollars.
Posted on Nov 18, 2010
Why does not the philips dvdr3480 record?
I would start with the dvd format used for recording, the simplest being dvd+r and dvd-r. Does the unit play a pre-recorded dvd and/or cd? If not, the laser assembly would be the first suspect. The delay in reading discs can be a sign of a borderline laser. Is your record overwrite function turned on, this overwrites previous material when starting each new recording when using +-rw discs. Verify if a format is required for the type of disc used for recording, page 45. Is the correct country/region selected?
Oct 26, 2017 | Televison & Video
Watch tv properly with JVC DVD off
Some philips tv's have a built in aerial amplifier, perhaps if you bought a digital aerial booster it will improve the picture quality.
Apr 05, 2010 | JVC DR-MV1S DVD Recorder/VCR
Recording with a philips DVDR3480 using dvd+r
my phillips dvdr3480 will not let me record from my camcorder it states writing has failed please help
Dec 10, 2009 | Philips Televison & Video
Just got logik ldvr 1608 dvd but it cant find any
You need an aerial to tune the freeview.
However, to record from satelite you can connect a scart lead from the satelite vcr out to the dvd in and it will record vie the av "channel" on the dvd.
Depending on your location, regarding signal strength, you can purchase an indoor, boosted aerial to tune the freeview.
Also, if the scart connection on the dvd is a 2 way connection( allowing a signal to the tv as well as from the tv) you can connect the tv to the satelite and the dvd to the satelite only and the dvd will play through the satelite even when the satelite is off.
Aug 26, 2009 | Televison & Video
With the new HD transfer. We just have atenna...we just bought a HD TV. Is there a way of connecting the DVD Recorder so I can watch one channel and tape another with this new system
A lot of your question depends on your DVD recorder, but there IS a way to connect them so you can watch one channel and record another one.
First - if you have an HD compatible DVD recorder (one that will allow you to select channel 8, 8.1, 8.2, etc) then you could simply split your antenna signal BEFORE the TV or DVD recorder. Then you can select one channel to watch on your TV while selecting and recording a different channel on the DVD recorder. If your DVD recorder is connected to your TV's Video Input, you should be able to monitor DVD recorder's activity by selecting the "Video Input" on your TV.
If you DON'T have an HD DVD recorder, then you will need to get a converter box to put between the Antenna signal and the DVD recorder. You can then set the converter box to the channel you want and the DVD recorder can be set to record it.
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Recording from my v-box to phillips dvdr3480
our dvd writer does not detect in device manager ?
Jan 28, 2009 | Philips Phillips 16X External DVD 2XRW...
Need a user manual for dvd player dvdr3480
Download User Manual of Philips DVDR3480 from Philips Support.
Oct 02, 2008 | Philips Televison & Video
Viewing cable tv channels
Use an av output from your media box and plug it into the line input of your DVD recorder. It can record using the line input of the DVD recorder.
Aug 09, 2008 | Televison & Video
DVD recorder only records the channel being watched. How do you record and watch a seperate channel with satelite tv
You need to connect the TV to the aerial output socket on the DVD player. If this is not clear get back to me. Then you can record one channel whilst watching another.
May 11, 2008 | Televison & Video
Hdd recorder / recording & watching cable channels
yeah actually that is kinda simple. Like the old vcr recorders you can just put a splitter between the cable (input) and your dvd hdd and your tv.
that is an easy 3 dollar solution
Apr 23, 2008 | Philips DVDR3575H/37
Toshiba DVD Recorder Logo
137 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
