The air suspension in the rear of my navigator isn't working properly. When I start the vehicle it usually fills up- now it's not I hear the air pump try to kick on but it goes immediately off, and it's not a smooth riding vehicle anymore. Sometimes it turns on other times it doesn't. Also having problems with the oil light going up and then down .. multiple times while driving it, when the oil is checked it registers oil and seems fine. What is wrong with my 2000 Lincoln navigator?!
My Buick had this problem and we found the pump was worn out. It just would not blow up when trying to run. They wanted a lot of money to replace it and the shocks.so I bought a kit that the air line hooks underneath the license plate Now about once every three months I use my air compressor to pump it up. My old air shocks lost air all the time. My new air shocks stay blowed up for over three months.
SOURCE: 2000 lincoln Navigator air suspension
There are level control sensors they look like little arms (with joints like your elbows) mountesd on lower control arms. They may be at fault they control the height and turn the pump off when the height is reached. try adjust height first before you replace, they can be adjusted. Good Luck
SOURCE: 96 lincoln town car "air ride suspension light"
i would scan it to make sure height sensor working.i check fuses and relays to compressor.check all electrical wire connectors .check all tubing hoses conections and check air shocks.
SOURCE: 1995 lincoln town car Rear air suspension problem
There is a way to permanately fix the solution to air ride suspension- get rid of them. Go online and there are several companies selling parts to replace everything you need- or do the smart thing and take them out and replace them with lifetime shocks. You can convert your car for a fraction of the price and never have to deal with them again.
I am sooo glad I did it on my car. It rides just as smooth too. Also, you don't have to worry about eroding boots, failing compressors/pumps, etc.
Suncore Industries is who I used and the things have been champ for 3 years running. And for only $249.00. No I don't work there!
SOURCE: The rear air ride suspension on my 98 lincoln navigator
Could very well be faulty relay, bad fusible link, or a fuse in general. You can trace the wiring or view a free repair manual at autozone.com to trace wires to find faulty device. You can use an ohmmeter or multi-tester to test relays and fuses.
SOURCE: air-spring suspension 1995 mark Vlll Lincoln
Save your self the hassle and expence of troubleshooting and replacement parts, install a suspension retrofit kit which changes the rear bags to coil springs and the front to struts. A car this old you might as well start over for less than $500.00......
