Question about Panasonic CT-32SX31 32" TV
Tv will not turn on
I turned my tv off today and then tried to turn it back on with no luck. I have checked the power. There is nothing around the tv to cause the failure. Could it possibly be a fuse and if so how would I change it? Any other ideas. Thank you.
  • aaggreen Sep 02, 2007
    TV is a panasonis CT 32SX31 that is 4 years old.
  • 398 Answers
Yes, it is most likely the fuse. I have seen many of the fuses in those Panasonics "pop" for no apparent reason. If you feel comfortable, you can replace that fuse yourself. Carefully remove the back, follow the AC power cord and where the AC cord attaches to the PC board will be a small glass fuse. It is most likely a GMA 6.3A fuse. Replace that fuse and the set should work. If the original fuse is good or if the new fuse blows out too, have the set serviced by a qualified tech.
Posted on Sep 03, 2007
Last night about 3 am I turned off my tv. when I usewd my remote to turn it back on it would not ( t v) come on and no picture or sound . I turned it around to see the back of it but it has no reset
Your TV have faults on Horizontal deflections, the oscillator and the Flyback might be the problems. If you are not familiar with TV circuits?... call tecnician to check your set.
Oct 03, 2014 | Televison & Video
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
It won't turn on
Check the fuse inside the TV . Also check the power cord for firm fit, if it is using plugable wire. Like in desk top PC
Jul 09, 2010 | Mintek DTV-263 26 in. TV/DVD Combo
Unable to solve Blank screen
hmm confusing but try turning your ps3 off at the wall give it 5mins and try again if nothing happens try it on another tv
Sep 25, 2009 | Sony PlayStation® 3 (80GB) Console
SONY KV-32FS13 No Power.. No nothing
has a power supply or deflection fault requires service
Mar 16, 2008 | Sony KV-32FS13 TV
37" polaroid lcd tv won't turn on
I have the same problem, very unreliable, just tried solution posted on this board and it worked. Turn on - while LED Bliinks push the channel button - also tap back a few times not too hard not too soft - possible problem(s) here, as suggested on tyhis board, capacitors (sic?), poor soldering connection, (In which case tapping might make it worse, but if you have no pic, nothing lost nothing gained), good luck, repair work suggested at about 200 bucks on this board.
Mar 02, 2008 | Televison & Video
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
Proview LCD TV
I am having the same problem. If I play with the power button on the back it will come on sometimes. I was looking for a solution here but looks like I will have to take it apart and check for loose solder joints.
Aug 01, 2007 | Proview HV-207 20 in. HD-Ready LCD...
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Panasonic CT-32SX31 32" TV Logo
340 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
