Question about Pacific Image PrimeFilm 1800u Film Scanner (35 mm)
Black output I have scanned several negatives by starting with prescan then scanning and everytime all I get is a black image. Any thoughts
  • 20 Answers
This type of issue could be related to different sources. First step I would do is check to see if the lamp is coming on within the scanner, possible bad lamp. One other possibility would be the CCD failure, it may not be moving across to capature your film. Also, when attempting to scan does the scanner sound normal or abnormal. If abnornal sound is occurring then CCD could jammed/stuck hardware failure. Last step would be uninstalling/reinstalling your scanner software, check for updated drivers from the manufacture of your scanner. At this point if none of these suggestions helped then test scanner on a different computer system.
Posted on Sep 03, 2007
I have scanned several negative images to my computer easily but naively thought they'd be put in a full jpeg image so they would look like a proper photo image not a negative image. What do I need to do...
Once on the computer in negative format, only image manipulation softawares are capable of restoring to display impressions. For example, photo softwares are capable of restorations with anti colation fillin voids to achieve image regularity. However, transforming the negative to regular image makes jpeg formating very convenient thereafter.
Jan 11, 2011 | Office Equipment & Supplies
By scanning my negetive film 35mm,allways cuts a horizontal part.
Try lower resolution while scanning & do set it at color settings. After preview then set color or monochrome......sodeep
Mar 19, 2009 | HP Scanjet 4370
Konica minolta dimage scan dual IV
Are you doing index scans or prescans? Sometimes the software gets funky - try doing at index scan if you are doing prescans, and vice versa. Also try CHTL+SHIFT+I which is a recalibration (don't that will do anything but it can't hurt). The best thing might be to just remove Dimage totally (you may have to delete the main folder if you've created any Jobs) and then reload the software. Before you do that, update your virus software, do a system check, and maybe some maintenace like a Defrag - then reboot, remove the software, reboot again and reload software.
Oct 18, 2008 | Konica Minolta Dimage Scan Dual IV Film...
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
What are the instructions to scan using Brother DCP 1000? I laid the docment face down and pressed Scan To and nothing happens but showing another selection in the glass window.
To Scan on Brother DCP 1000 you need to click on the "Paperport" Icon on the desktop. Then Click on "Twain." Lay your document to be scanned face down on the scanner glass. Press the "Scan To" button on the Brother DCP 1000 printer. On the "Twain" window click on "Start." Note: When I clicked on "Start" it initially scanned blanks. I clicked on "PreScan" and saw an image. Then I again clicked on "Scan" and it worked. I named each document I scanned and saved them in a folder for later use.
Jul 31, 2008 | Brother DCP 1000 All-In-One Laser Printer
DR-9080C intermittent stops during scanning which last 3 to 5 minutes
Do you have enough hard disk space? Reinstall your driver software. Run Scandisk on the Comp.
Is the problem coming on after a set time interval, any heating smell?
S. Mohan
Jun 22, 2008 | Canon DR-9080C Path-Through Scanner
Scanner in negative
You must have chosen "negative" output in the scanner setup. Go through the scanner options and you should be able to find a way to undo it..
May 09, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
No scan with Microtek Artixscan 120 tf
When you say -'normal' prescan you do mean you get an image? If this is so I would remove all software. Do a disc clean Reboot the computer Re install the original supplied software-ignore for the time being any down loaded upgrade, Come back tell me what you have
Aug 31, 2007 | Microtek ArtixScan 120tf Film Scanner
Pacific Image PrimeFilm 1800u Film Scanner (35 mm) Logo
263 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
Alun Cox
Argospete
Argospete
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
