Question about HP Photosmart C3180 All-In-One InkJet Printer
Priner problems we have an hp photosmart c3180 and the check printer cartridge is blinking and we have done everything and are prinrt is not working
  • 24 Answers
Issue After you install a print cartridge, or during normal operation, the print cartridge light and one or both of the Start Copy lights begin to blink. Solution NOTE: The procedures below refer to a 'problem' cartridge. The 'problem' cartridgeis identified either by a computer message or by the Start Copy lights. If a computer message indicates a specific cartridge, that is the problem cartridge. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge. If both Start Copy lights are blinking and there is no computer message, perform the procedures below on both cartridges. Work through the sections below in order. When the print cartridge light stops blinking, you have solved the problem. Step One: Remove, inspect, and reseat the problem cartridge The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help. NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges. Make sure the printer is on. Press the Power button if it is not lit. Open the printer cover, then wait until the print cartridge carriage is idle and silent. Press down lightly on the end of the problem cartridge to release it. Slide the cartridge out and inspect it: CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Check the electrical contacts for debris. Make sure all the clear nozzle protective tape has been removed. CAUTION: Do not attempt to remove the copper electrical strip! Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer. If the cartridge is compatible, reinstall it in the printer: Cartridges marked with a triangle go into the left carriage slot. Cartridges marked with a square or pentagon go into the right carriage slot. Step Two: Clean the problem cartridge contacts If the steps have not solved the problem, clean the electrical contacts on the print cartridge and in the carriage in the printer. Gather the following items to clean the cartridge and print carriage: Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap-water can contain contaminants that damage the cartridge. Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well) Sheets of paper or a paper towel to rest the cartridges on during cleaning Open the printer cover and wait until the print carriage stops moving. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up. NOTE: Clean the contacts quickly so that the cartridge is not outside of the printer for more than 30 minutes. If the cartridge is outside of the printer for too long, the ink can dry and clog the nozzles. Unplug the printer. Dip a swab in the clean water, and then squeeze it to remove most of the moisture. The swab should be only slightly damp. Clean the print-cartridge contacts. Do not touch the nozzles. Clean the contacts in the print carriage, inside the printer. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it. Reinstall the cartridge, plug the printer back in, and close the printer cover. Try to print again. If the issue still appears, proceed to the next step. Step Three: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above. Step Four: Contact HP If the problem has not been solved by the steps above, either the printer or the problem cartridge is defective
Posted on Sep 25, 2007
SOURCE:
Region codes for France for a photosmart c3180 all in one
Well I had the exact same problem with a C3180 bought in the USA and I moved to France. I called the HP tech support and after I bought 5 brand new cartridges upon their recommendation we haven't been able to print the 10 tap test page
I recommend that you try doing that before you call them otherwise you will be wasting your time
To print the 10 tap test page you need to press simultaneously CANCEL and START COLOR COPY. I couldn't print the 10 tap test page because the printer will not recognize the cartridges bought in France (START COLOR COPY and START BLACK COPY blinking + E in front of COPIES)
If somebody knows an alternate method to print the 10 tap test page, please share it as this is the blocking point with HP support
Thanks
Feb 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
HP photosmart C3180 makes a loud clicking noise when printing first page.
After inserting new cartridges in the photosmart C3180 and closing the door it makes loud clicking sound coming from the cartridge area and won't print.
Nov 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
When try to print the check paper/ink cartridge light blinks and printer wont print.
If both the Check paper, and the Check Cartridge Lights are blinking, this indicates a Carriage Jam. Follow the instructions here to clear this error.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&rule=8471&product=1146331&docname=c01447224
Dec 29, 2008 | HP Photosmart C3180 All-In-One InkJet...
I have a hp c3180 photosmart
Printer manufacturers include chips inside the catridges.When the same cartridge is used the printer reads the chip and finds that you have refilled the cartridge and returns the error. The simplest way to get around is to have have 3 empty cartridges and rotating them one after the other. This way you can fool the printer and get around the check!
Regards,
Rajesh.
Nov 13, 2008 | HP Photosmart C3180 All-In-One InkJet...
Making my printer wireless
This printer does not support wireless connectivity according to the priner specifications. Look at the connectivity types: USB
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00649946&lc=en&cc=us&dlc=en&product=1146331
Jul 23, 2008 | HP Photosmart C3180 All-In-One InkJet...
Printer blinking
please check your cartridge is it correctly installed,check for any paper jam.
Apr 02, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
345 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
