VCRs
Problem for VCRs
Generic problem for all VCRs
Tape stuck in RCA VR501
By tcxu on Sep 02, 2007
We had a videotape that automatically rewound and in the process, it got stuck & at some point chewed. I'm not worried about the tape anymore. My problem is that the tape is half in/half out of the VCR. I can't pull or push it back in, and the eject button isn't working. I took the top off and could not get the loading tray to move in one direction (preferably completely ejected) or the other. What can I do?
Same Problem
Feb 15, 2008
-   The white plastic gears, i think is the take up guide for fast forward and reverse, are worn out. Cant get th replacement parts. Any idea where I can get them or get hold of a broken vcr for parts. My model is HS-U775 which i assume must have ther same parts as the 776. Thanx.-   Guest
Nov 30, 2007
-   The door is stuck open and will not close-   Guest
Solution #1
posted on Sep 04, 2007
Somewhat Helpful)
dodgecharger
Rank: Wiz
Rating: 83%, 328 votes
This could require a tech savvy person to help you, but maybe...
You might be able to remove the tape carriage assembly (this is the assembly which loads and unloads the tape). There will be 2 or 4 screws which hold this assembly in place. It is possible however, these screws are "covered up" by the tape being there.
These mechanisms are often gear or gear-like driven. If you see these gears, you might be able to turn them (or the motor which runs them) by hand, and get the tape fully unloaded. Use care- modern VCRs (since the early '90s) are easily broken, or the thin metal bent.
Also, the gears must be exactly in time- that is, exactly positioned with each other. Being off by just one tooth will result in a non-working mechanism.
Was this helpful?
Yes
No
Popular Solutions for VCRs
Questions and Unsolved Problems for VCRs
Answer
Original remote control not functioning. I would like to get a new remote control. Could one be... (More)
Answer
I need a drive belt for the "take up reel"
Answer
hOW CAN I GET A MANUAL FOR AVCR, MODEL 755
Answer
paint is very stiff what are we going to add to the paint to make it easy to use?
Answer
My AG-DV2500 is not recognized by Windows7 (64)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For VCRs:
Top VCR Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more VCR Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
