Question about Jenn-Air SCE30600 Slide-In Electric Kitchen Range
Grill outage The LED display for the Grill side is out, and grill elements do not heat up. The burners and all other LED displays work, and I already cycled the breaker. The Tech Manual Troubleshooting guide doesn't give me a clue. What's wrong?
  • 5 more comments
  • HiwyYa Sep 03, 2007
    I'm not sure I've cited the correct Model No. The manual I have lists several model numbers one of which is the SC 30600. There are also SV-series listed. In anycase, it is the Model Jenn-Air that has a Grill on the Left and a Two Burner Cartrige on the Right. I also need to mention that along with the other symptoms, it started beeping when the LEDs and Grill Elements went out.
    And...before the Grill display went totally dark, it showed what appeard to be "F5". Some sort of fault code?
  • HiwyYa Sep 04, 2007
    If you can tell me where to look for the nameplate I'll be able to verify the Model # for you.
  • HiwyYa Sep 11, 2007
    To update you on the grill problem; the fault code has changed. The LEDs now display two dashed lines (--). Also, the nameplate indicates this is a SVE87600B Model. Thank you for your continued assistance.
  • HiwyYa Sep 12, 2007
    Thank you for the link! Now, I just want to make sure before I go ahead an purchase this part; replacing the Clock Assembly will restore the operation of the grill elements? I'll be able to grill again?
  • HiwyYa Jan 11, 2008
    Okay, I finally recieved and installed the "clock" or "control head" for the Left-hand grill. Results were mixed. The display lights up again, and the Left Front Grill gets good and hot. However, when the Left Rear Grill element is put on, it shuts down after about 15 seconds and a fault code "F2" illuminates on the display. When I look this code up on the Electrical Print, the chart indicates the problem as follows: Over temperature: over 600 degrees sensed. Sensed by control in time of day mode, bake mode, or over 900 degrees sensed in clean mode." Under the Components to Check Column, it says, "Ohm Sensor. If checks ok, change power relay board."
    First off, I'm not operating the range in the Time of Day, Bake, or Clean modes to my knowledge. I'm just trying to use the grill. Secondly, I've looked over this Print carefully, and I cannot see the "Ohm Sensor". Neither can I locate the Power Relay Board either on the Print or in the range.
    Any guidance you can provide is greatly appreciated.
  • HiwyYa Jan 11, 2009
    Hello all! I am back again. I must confess, my efforts to solve this problem were overcome by other more pressing events, and I was not able to pursue this until now. To restate the problem with the grill on my Jenn Air SVE87600B Range, When I turn on the rear left element, the fan starts but an alarm sound and a Fault Code F2 appears on the LED display shortly thereafter. I looked up the Fault Code F2 on the trouble shooting chart and it directs me to check the "Ohm Sensor", and refers me to a chart for different temps and their corresponding Ohmic values. It goes on to say that if the Ohms Sensor checks out okay then the Power Relay Board should be replaced. Well, I can't seem to find this Ohm Sensor. Can someone direct me to the location of the Ohm Sensor? Thanks!
    HiwyYa
    Sergeant:
  • 279 Answers
I'm not sure what you mean by the Grill side. All the information I see for the SCE30600 shows a rather normal over with 4 burner stovetop, but nothing I would call a grill. Can you explain in more detail, or is it possible you chose the wrong model?
Posted on Sep 03, 2007
  • 2 more comments
  • Anonymous Sep 03, 2007
    Well, it sounds like power isn't getting to the grill component. Possibly the controls for it are burnt out, or a fuse is blown.
    I'm fairly certain you don't have the SC 30600, as the schematics I've found for it do not include a grill. If you can figure out the exact model you have, I might be able to find more detailed information. But regardless you're going to want to open up the top (control panel area) and test the power to it.
    You'll need a voltmeter. Basically, trace the power lines back from the grill components until you find the point where they go bad (ie, the first spot where there's no power to them). It may be something as simple as a fuse, or it may be a burnt out board, or a short in the grill components somewhere.
  • Anonymous Sep 04, 2007
    Oh, that fault code makes it much easier to diagnose. Here's what the fault code means:
    Hardware and watchdog circuits disagree
    And the suggested repair:
    Replace clock assembly (also called the ERC)
    You can find model number locations (with images) here:
    http://www.jennair.com/content.jsp?name=...
    Then you can find a local service provider here:
    http://www.servicebench.com/servlet/WebS...
    They should be able to tell you where you can get parts locally. If you prefer, I can try to find a place online to order parts, once I have the model number.
    Good luck.
  • Anonymous Sep 11, 2007
    Well, I have good news and bad news.
    The good news is, I found a site that sells parts for your model:
    http://www.appliancepartsworldwide.com/S...
    The bad news is, the part you need - the clock assembly, is $185.70. Here's a link directly to it:http://www.appliancepartsworldwide.com/S...
  • Anonymous Sep 12, 2007
    I haven't actually worked on this specific problem before.
    The documentation I have seen says that the way to repair that error code is to replace the clock. I can't swear that's accurate, but I haven't found any other suggestions on how to repair it. I'd say I'm about 80% sure that will fix it. I'm sorry I can't be 100% sure on this one.
SOURCE:
I have power but not switching on at Knob no grill or oven no fan
Beko OIF21300B Electric Single Oven not heating - Repair
www.how-to-repair.com/.../beko-oif21300b-electric-single-oven-not-hea...
Jun 11, 2015 - If your Beko OIF21300B Electric Single Oven is not heating or tripping the ... Now the cooker turns on and the display lights come on but the cooker does not seem to work and start heating up. ... The grill element doesn't work
[PDF]Download Manual - Beko
downloads.beko.co.uk/bekoupload/manuals/DVG592.pdf
Congratulations on your choice of a Beko quality cooker which ..... Before you startusing your cooker, clean ... if an appliance burner doesn't light, press again.
Dec 13, 2015 | Beko D533AW Single Fan Oven Electric...
Buners will not Fully Light
A burner doesn't work Heating elements eventually burn out. Sometimes, when an element burns out, you can see that the coil burns in two, or blisters and bubbles.
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too. Also see the "A burner works only intermittently" section, next.
http://www.repairclinic.com/0088_13_1.asp
Jun 29, 2008 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
We purchased 4 burner discovery as a built in for outside. In the Built-in unit is is requiring some brackets for the side to rest on the sides of the brick work. Where can they be purchased as they did...
If you purchased just the grill head, for a built-in installation, the Trim Kit/Brackets should have come with it. Or perhaps, they're already attached. If not, contact Beefeater, as another grill manufacturer's parts may not fit your grill head.
Jul 09, 2011 | Beefeater Discovery 4 burner Grill
None of the materials I received with my Char-broil Model 463270611 include an illustration of the gas knobs and the meaning of the symbols they display. Can anyone help?
After reviewing the Owners Manual for your grill, I see it has only 2- burners and possibly electronic ignition and an optional side burner (if you have the kicked up model). This grill is not difficult to operate, as it only has 2-burners, which translated into 2- burner knobs, which control the lighting of the burners and the flame height adjustment, once the burner(s) are lit.
But, as they say, "One picture is worth a thousand words". So I am providing a link to your model grill, that not only has the Owners Manual link, but also links on how to use, operate and cook on a gas grill. In fact, there are a couple of videos you might find of interest.
http://www.charbroil.com/ProductSupport/463270611/Quantum-Infrared-Urban-Grill.aspx
Be safe and enjoy your grill.
May 10, 2011 | Char-Broil 463232103 Grill
Only the left side of the grill heats up. How do we get the right side to work again?
Make sure the grill is clean and the burner are not clog you can use oven cleaner to clean it
Mar 30, 2010 | Ducane 455 inch 2 - 3 Burner with...
The gas is coming through, but does not light.
I have the same grill,and sometimes the same problem.First,with the gas off or completely disconnected,remove the grill grates and the flavor bars from the grill.Now you can see the heating element.A small wire brush will do the trick.Gently clean all the little holes in the element where the gas comes out.Then,with compressed air or even canned air(like what you use to clean a computer with)blow out the holes you just cleaned.Reassemble the grill and light.Should work fine after that.
Dec 28, 2008 | Weber Genesis Silver B Grill
Grill, top oven and all lights not working after grill element blows
Brinkmann has a terrible customer service dept. You are better off with a new unit.
Jul 30, 2008 | Grilling
Rangemaster Toledo 110 oven/Grill element
How easy is it to fit a new grill element. The element on the left hand side of the grill is not working so I need to replace this. I'm just wondering if this is easy to do myself or do I need an
electrician
Regards
Sandra
Dec 15, 2007 | Kitchen Ranges
Jenn-Air SCE30600 Slide-In Electric Kitchen Range Logo
198 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Paul Carew
Ismael Rodriguez...
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
